Question about Refrigerators
My Rangemaster Refrigerator SxS keeps blowing the 1amp fuse. The electricity was off the other day and when it came back I put on the fast freeze to geet the temperature down to -18 but it blew the fuse straight away
4 Suggested Answers
SOURCE: The Fridge of my Rangemaster SXS Fridge Freezer is freezing up
my ice depenser is only making a couple of ice cubes the others are staying iin the ice cube tray
Posted on Dec 23, 2009
SOURCE: rangemaster sxs u109100 fridge freezer temp in fridge +15
Hi - can't solve it but ours has started doing the same - ours will only work if the fridge temperature is selected to 9 C (press the button under ~Ref Temp until cycles round to 9C) then it controls to 9 - if the temperature is set to 5C then it seems to give up and goes back to 15 - don't know why but will investigate more
Posted on Apr 04, 2010
SOURCE: wate light onfront of rangemaster sxs fridgefreezer turned red
After you have changed the filter, select water then hold the select button down and it will go blue again.
Posted on Apr 11, 2011
Can't find a fuse for Garmin 220 Zumo
The voltage is not really important. Its the size and the current (amps).
Take the one you have to Radio Shack, Autozone, or Pep Boys... somewhere like that. The A2211 does not sound like a fuse number.
It looks to me like a GMA size, and the manual says its a 1Amp Fast-Blow. Available lots of places.
If it keeps blowing fuses, it could be the in-car charging cable unit, or it could be the Garmin itself. But most likely the charger.
A new charger is $25 from Garmin, and a lot less everywhere else.
Dec 17, 2013 | Garmin Zumo 220 35 in Car GPS Receiver
Fuse keeps blowing on rangemaster
It sounds like you may have a wire or connection that has become grounded. Unplug it, and if you have the know how and ability, dig into it and see if you can find any evidence of it (burnt smell, blackened/melted wire insulator.) Above all, keep it unplugged until it can be properly diagnosed.
Aug 23, 2012 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Hatco c-9 booster heater won't heat, 1 amp fuse keeps blowing
that is in the control cicut the contactor might be bad and taking out cntrl fuse.unhook contactor control voltage by unplugging from contactor tape off the two wires put new fuse in turn on power if fuse does not blow replace contactor.if it does blow you will have to isolate the next thing in the control circut maybe the light.you can buy resetable 1amp circut breakers at grainger for test purposes.sometimes on people I know I will wire in those breakers for them no more buying fuses.
Apr 11, 2011 | Hatco Corporation Compact Electric Booster...
Wate light onfront of rangemaster sxs fridgefreezer turned red
Jul 08, 2010 | GE PDS22LBN Bottom Freezer French Door...
36" SxS not cooling
unplug it for five minutes... if it dosent come back on the pc board must be replace....
Apr 09, 2010 | GE Monogram® ZISS420DMSS Side by Side...
Rangemaster sxs u109100 fridge freezer temp in fridge +15
Jan 17, 2010 | Refrigerators
You probably have one of the following problems: A failed defrost system, meaning the defrost timer and/or element has gone out and your evaporator coil is frozen over; you are low on freon and this too will cause your evap coil to freeze over until the freon drops so low all cooling stops; . Unless you have gauges, a licence to buy freon and service valves (or a buddy with such) you are limited to what you can do. Here is my advice:1. unplug the frig and let it defrose over night, or unplug the frig and empty the freezer to remove the back cover to look for ice, a frozen fan and if so get your hair dryer out and melt the ice so you can test the fan and the defrost element (you will need a volt/ohm meter to do the element check. You can do it.
Oct 27, 2009 | Refrigerators
Samsung fridge RS2545SH every 7 days freezes fridge coil.
Hey how yo doing? on most refriderator there are two important parts to keeping freezer from freezing over, they are the bimetal thermostat and ice pipe heater. The bimetal therostat is a preset thermostat that ranges from 54degrees farenheit to about 60, when the coils (inside the freezer compartment behind the back panel) reach the preset temp. it closes a circuit and send electricity to the ice pipe heater, to warm the freezer coils preventing from freezing over. if any one of those components fail, your freezer will continue to freeze solid until there is no more space for ice to build on coils decreasing air flow from the evaporator fan blowing air into your fridge.To test you will minor knowledge on using a multimeter.(REMEBER TO UNPLUG REFRIDGERATOR BEFORE SERVICING, IF YOU UNCOMFORTABLE WORKING ON APPLIANCE PLEASE CONTACT A PROFFESIONAL REPAIR SERVICE..) If you'd like to continue please respond.
GOOD LUCK, WORK SAFELY..
Aug 12, 2008 | Samsung RS2630SH Side by Side Refrigerator
Sumsung top fridge and bottom freezer
Hi, The infeller struck to build of ice , causes the the beep sound ,defrost manually by two hours put electric fan to fast defrosting ,set rotate knob to defrost , you hear sound cracking of ice and smell burning that was could heating element for defrost if you hear sound like that in manual , later set automatic if timer will not turn you may replace timer .
Jan 20, 2008 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
