Question about Husqvarna Garden
2008 125E edger starts and runs for a bit (10-30 sec) then stalls. New ZAMA crab, new fuel line and filter pick up, fresh gas in clean tank. Any ideas? Carl
  • Husqvarna Master
  • 1,807 Answers
Check ignition module and the timing gap between the ignition module and the flywheel. Does it also have good compression.?
Posted on Aug 02, 2013
3 Suggested Answers
AUTODOC01
  • 216 Answers
SOURCE: Edger #125E stalls after 3-4 second of starting.
sounds as thou the carb plate gaskets are torn these are sandwiched on eithewr side of the carb and they let it pump/**** the fuel a rebuild kit will have theses new gaskets depending on how mech/ inclined you are you may just want to let a shop fix it $75?? thats what i charge
Posted on Aug 26, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I have a aCraftsman Edger/Trimmer Modle
Check your fuel filter if you have one.
It may need replacement or cleaning.
Also check your fuel tank for debris/trash and clean it out if necessary.
If the mower/weedeater is over a year old, then I recommend that you buy
and install a new carburetor repair kit,because the diaphragm will get hard
and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor
internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small
rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid
and letting it run a few times like that and it will flush the gunk out of
the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to
reassemble the carburetor or follow the instructions you get with the
carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need
to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes
to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first
and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Jan 16, 2011
Husqvarna 455 Rancher loses power, have tried the following: fresh premium gas with ams oil 2 cycle oil, new plug, cleaned air filter, runs for a little while but starts stalling out after using about a...
check your fuel filter/gas line in tank you could have a crack in your line that in the fuel till it gets below half tank then sucks air through crack, It's a possibility, other than that, check your exhaust port, but sounds like a fuel problem check your fuel tank vent also to make sure it is venting. Good Luck
May 03, 2011 | Husqvarna Garden
For awhile would only run on middle choke setting, then would start but wouldn't stay running, now won't start at all. has new plug, fresh fuel, clean air filter, seems to have spark. do these units have...
Yes they do have a carb,very small,normally buried near the fuel tank,the diaphram may need replacing on ebay try smallplantsalesuk they will have a carb kit quite cheaply,very helpful,have you got your fuel mixture correct,rgds
Sep 26, 2010 | Craftsman 25cc Gas Line Trimmer
The trimmer will not start, the prime bulb sticks when pressed, gas is not flowing through the carburator
Many things can cause the unit not to start (see www.zama.com) for troubleshooting their carbs and what causes a no-start condition. If the purge/prime bulb is sticking..there could be a bad fuel filter in the tank with a side condition of bad fuel lines...ruining the vacuum action needed to operate the bulb correctly. It helps to understand (and you may) just what the purge/primer bulb does. It "pulls" fresh fuel into the body of the carb by "pulling" out any air and old fuel in the body of the carb...then it "pushes" this air/fuel mixture (with new fuel lines you can see this) back to the fuel tank. ...and it sounds like you need new fuel lines also.
Jul 14, 2010 | Troy Garden
The Craftsman Sim-Pul string trimmer starts and runs for one sec.
The larger line is the fuel return line from the purge bulb and should have the nylon connector (funnel thing) on it holding it in place inside the tank so the line won't pull out.The smaller diameter fuel tank line goes from the tank to the lower pipe fitting on the carburetor (fuel intake line). This line has a weighted fuel filter inside the tank on it.
New fuel lines are recommended every so often as the ethanol added to our gas nowadays wreaks havoc on the lines and carburetor as well. Get new lines...cut them long....feed them thru holes in fuel tank...grab with tweezers or needle-nose pliars....put on either the fuel filter or the nylon retaining nipple and pull the one with nipple down to bottom of tank...one with fuel filter can stay long to help draw fuel in the tank (yes, it moves around and is supposed to).
Jun 06, 2010 | Craftsman Convertible 25cc. Gas Line...
Weed Eater Problems
If it runs with the choke closed then it's not getting enough gas. Check the gas filter on the end of the gas line in the gas tank. Remove the gas cap and using a piece of wire with a hook on the end, reach in the tank and pull the gas line out through the opening. Check the filter on the end of it. You could also have a burst-ed diaphragm in the carburetor. This sucks the gas from the tank to the carb. If that's the case a new weed eater may be in order unless you can find someone with the parts to repair it. Also check the gas lines for leaks or breaks, 2 of them.
May 17, 2010 | Troy Garden
My string trimmer will not start
Possible solutions:
-Kill switch is shorted out-check the wire and connections.
-Buy a new plug.
-Primer bulb needs to be replaced.
-Fuel filter needs to be replaced, and it's located inside the gas tank so it's a bit tricky to replace.
-Try starting it without the air filter attached.
Is it possible an incorrect mix of gas/oil was used (or straight gas) which in turn ruined the motor?
Jul 29, 2009 | Garden
Gas trimmer hesitates when I try full throttle
Hope my suggestions solved your problem.
Jim
May 18, 2009 | Garden
Garden Logo
105 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
