Question about GPX KCL8806DT 7 in. Portable Television
Clock display The time on my under cabinet tv ( is this called portable?) keeps gaining time and is now about 45 minutes ahead of the real time - how do I reset the time?
Power/standby must be off. Press and hold "Timer/CLK" for 2 seconds. Use the up/down buttons just to the left of the Timer/CLK button to select 24-hr or 12-hr mode, then cycle through hours, minutes. In each case u can use the up/down buttons to set the time.
Posted on Aug 30, 2008
Sony IFC-218 clock radio runs 8-9 minutes fast
Hold the 'Clock' button until the display flashes. It will first show the year, next press on 'Clock' with show the month, then the day, then the time. Use + and - to set your time and press 'Clock' again.
Don't expect this clock to set the time by itself. It is not an atomic clock.
Nov 29, 2011 | Sony Audio Players & Recorders
Can anyone help me please with setting clock on my Panasonic car stereo model no CQ-RX102W. I have misplaced the manual and cannot intuitively work it out! Any assistance would be most appreciated
Here is the user manual here :
http://www.5starcaralarms.co.nz/manuals/CQ-RX101W%20Operating%20Instructions.pdf
And to save some time here is what i found for setting the clock:
The 24-hour system is used for the clock.
1 Press [DISP].
(clock display)
2 Hold down [DISP] for more than 2 seconds.
Hour blinks
3 Adjust the hour.
Hour entered
[>>]: sets the hour ahead.
[]: sets the hour back.
4 Press [DISP].
Minute blinks
5 Adjust the minute.
Minute entered
[>>]: sets the minute ahead.
[]: sets the minute back.
6 Press [DISP].
Completed
Notes:
• "ADJUST" is displayed before adjusting the clock.
• Hold down [ or [>>] to change numbers rapidly.
• When "NO DISC" is displayed, the clock cannot be
adjusted.
Clock Display at Power Off
Press [DISP] to change the display.
Display off
Clock display (Default)
Jun 23, 2011 | Panasonic Car Audio & Video
Spacersaver Model 7-4285 the clock is changing the minutes in 45 to 50 seconds so in time it will be hours ahead were it should be. How do I fix it to change the minute in 60 second rather than 45...
It's not clear how 'digital' the clock really is sincet hey don't really post the minutae about these things. Could just be the display. If you put your ear against it and hear a hum, there's a motor. As long as the line voltage is +-10% most electronics will do just fine. Line frequency only affects AC motors. That it has a frequency spec is telling. If the motor was DC they'd get away with 50-60hz.
May 23, 2011 | GE Spacemaker (74290) Clock Radio
How to set time on jvc kd-r210
Setting the clock
  • Press and hold SEL (select) for more than 2 seconds. "DEMO", "CLOCK H", "CLOCK M", "DIMMER", or "AMP GAIN" appears on the display.
  • Set the hour.
  • 1. Select "CLOCK H" (hour) if not shown on the display.
  • Set the minute.
  • 1. Select "CLOCK M" (minute).
  • 2. Adjust the minute. Using the Control Knob
  • Finish the setting. To check the current clock time or change the display mode.
  • Press DISP (display) repeatedly. Each time you press the button, the display changes as follows:
  • • During tuner operation:
  • • During CD operation:
  • • During power off:
  • The power turns on and the clock time is shown for 5 seconds, then the power turns off.
Nov 11, 2010 | JVC AM FM CD DET FACE CAR STEREO
Two clocks are set at 6am one clock gains 30 seconds every hour and the second clock loses 1 minute every hour. at what time will the faster clock be 30 minutes ahead of the second clock
Compute the difference in clock-speeds, namely 90 seconds per hour.
Convert the units of time: 30 minutes becomes 180 seconds.
So, divide 180 by 90 to get '2', namely 2 hours after the 6 o'clock "start" time, which makes it 8 PM.
P.S. There is at least one error in the above solution. If you truly understand the solution, make the necessary correction, and submit the corrected "homework" to your teacher.
Jan 07, 2010 | M2K Garfield: It's All About Math Math...
I need to change the time on it.
You can try the following steps
Setting the clock
1 Press and hold SEL (select) for more
than 2 seconds.
“DEMO,” “CLOCK H,” “CLOCK M,” “DIMMER,”
or “AMP GAIN” appears on the display.
2 Set the hour.
1 Select “CLOCK H” (hour) if not shown on
the display.
2 Adjust the hour.
1 2
3 Set the minute.
1 Select “CLOCK M” (minute).
2 Adjust the minute.
1 2
4 Finish the setting.
display mode
• During power off:
Thanks for using Fixya
Proton
Jul 27, 2009 | JVC KD-G200 CD Player
Sony radio/cd/clock under the cabinet. Lost
On the right side there is a push button switch labeled "Clock". It is springloaded so you have to push it in and hold it for a couple of seconds until the unit beeps and the hour position starts to blink. The volumn up and down buttons will control the changing of the numbers up and down and PM/AM. Pushing the clock button again will change the clock to the minutes position and you cann adjust the numbers up or down just like the hours. Push it one more time will lock-in the new time. Your done.
Jul 20, 2009 | Sony UNDER-CABINET LCD-TV DVD/CD CLOCK...
Brookstone smart set alarm clock. It is about 20minutes ahead
I've noticed that manually setting the clock forward or back by any number of minutes, results in the same time offset being displayed after unplugging - plugging back in. So, if it's 9pm and you set if 5 minutes fast (9:05pm). Then unplug it and plug it back in 30 minutes later (9:30pm), the clock will maintain your setting of 5 minutes ahead of the actual time (9:35).
I like to set my clocks 5 minutes fast, just to make me always think I'm running a bit late (sure, maybe I'm a bit crazy). But this "sticky" manual setting is kind of a nice feature in my opinion. I'm wondering if it's not intentional?
Anyway, just manually set it back to the real time, and it sho
Feb 18, 2009 | Brookstone SmartSet Alarm Clock
GPX KCL8806DT 7 in. Portable Television Logo
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
