Question about LG 32LE5300 Widescreen 32 in. HDTV
Backlight bleed/clouding LG LCD model 32LD650
3 Suggested Answers
  • 458 Answers
SOURCE: Big white blur, cloud like, Center of LCD TV
I have seen similar effects like this & it is usually due to a flaw in the screen. A replacement screen is the only cure.
Posted on Oct 05, 2009
  • 8457 Answers
SOURCE: confused between lcd's!!!
All LCD,Plasma tvs these day are very similar designs and qualities,but don't buy unknown brands,because when u require boards for defective tvs that require electronics boards replacement.Better chance to find refurbishes pcb boards.If u have name brand tvs models.U like the LG model,think it better buy the LG models.
Posted on Jun 15, 2010
On an LG TV model # 50LN5700 UH , is the backlight inverter part of the power supply board?
Yes it is, this is a LED TV so there isn't an inverter board, they're only used on LCD sets...don't you have backlights but can see an image with a flashlight?
Jan 21, 2018 | LG Televison & Video
Sanyo DP46142 TV comes on for approximately 30 seconds and then screen goes black. Power LED stays on.
Sounds like a backlight problem to me. If you input a signal to the HDMI or Composite input and then it goes black have you tried taking a flashlight to the screen to see if the picture is still there but just dark? That would indicate a backlight issue. That model appears to be an LED edge lit backlight, so if the picture is still there after going black your going to have to trace out the backlight circuit and see whats going on. Usually with LED backlighting if it comes on at all then the LED's are good, its just the driver supply thats failing to keep them on. Some TV's have a small separate board that provides the backlight control, but i suspect with this model its on the power supply board and not the motherboard. Have you checked that board? It could be bad caps on the power supply board, check the voltages to the backlighting when it lights up and then when it goes dark. It could just be some failed capacitors on the power supply causing that voltage rail to drop off.
May 04, 2017 | Sanyo Televison & Video
I have an LG 60 inch plasma model 60PV450 that has no picture but does have sound
It is probably the backlight inverter board. These are common problems on all LCD and Plasma units that use fluorescent backlighting.
Jan 20, 2015 | LG 60 60PV450 Plasma TV
Hello, I have an LG LCD TV Model : 37LC2RR-2L, I can get sound on th tv, the screen is on but no image appears.
You're backlight inverter is faulty.
You first need to check your power supply and ensure you have 24v output to the backlight inverter.
If you lack the 24v you will need to replace capacitors in-line to the 24v rail to get power back to your backlight inverter.
Look for these:
If your 24v is OK then you will need a replacement inverter to restore your picture to your tv.
Best of luck!
Apr 18, 2011 | LG 37LC2RR 37 in. LCD TV
I just bought a LG 55LX6500 TV, but I found when in dark scene or no signal, the screen showing very uneven darkness, espcially the 4 corners, the most the upper left corner a lot lighter than the rest...
it may be a problem with the backlight system.the leds use a edgelit led backlight instead of placing them directly behind the lcd panel. i suggest if it is very new take it back to the store otherwise you will need to call service technician LG should be able to give you contact info for authorized servicers in your area.
Dec 23, 2010 | LG Televison & Video
My flat screen Poloroid TV went black, it hissed and cloud of gas or smoke escaped from the back of the TV and now I have no picture just sound. Is it dead?
No troubleshooting needed for this issue. Check the tv's warranty then call the manufacturer to get this tv replaced or fix. If tv's out of warranty you still need to call the manufacturer to ask where is the closest Service center that can fix your tv.
Sep 09, 2010 | LG 42LC2D 42 in. LCD HDTV
Confused between lcd's!!!
Jun 15, 2010 | LG 32LD450 32 In. LCD HDTV
I have 140 LG 32LC7DC LCD TV's. 14 out of 140 failed. They would not power up. Have you heard of this problem with this model of LG?
Power Supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 02, 2010 | LG 32LC7DC 32 in. LCD HDTV
Blue cloud in the screen
I believe you need the Optical Block replaced. It is not a simple fix and if it is out of warranty, it will be a expensive one. I would call LG at 1800-243-0000
and see if they could help with the repairs and also to get you in touch with a local repair facility.
Hope this helps,
Skyassoc
Oct 22, 2009 | Televison & Video
Oct 05, 2009 | LG 42LH30 42 in. LCD TV
LG 32LE5300 Widescreen 32 in. HDTV Logo
245 people viewed this question
Computer Repairing
Computer Repairing
