Question about E-Machines T5026 (RBT5026) PC Desktop
My T5026 emachines has a hard time when turned on it makes soem beep noises over and over again and the fans are running , The monitor screen won't come on.. And it doesn't boot into windows ..
  • Patrick Casey May 27, 2011
    Thanks alejandroll1,
    It was indeed the memory module .. I took it out and checked for crack and possible damage to the memory card .. Cleaned it up and put it in another memory slot..Rebooted my computer and it boots up right again ..
    Scholar:
  • 79 Answers
Hello, When computers "beep", they're sending the user the signal that there's some hardware problem, sometimes damaged hardware or dirty hardware, first you have to identify the piece of hardware that is giving you problems, I would go after memory in the first place, open your computer an you'll see the internal parts. Remember to turn off your computer first.
This are the memory modules, if you have more than one take only one first, unlock the memory module by pressing the small plastic tabs on both ends of the slot, then take out the memory module. now turn on your pc.
If the pc is still beeping, turn off the pc again, take the second memory module out and put back the one you took out, tu put a memory module remember to force the memory into the slot the right way, if the memory is not fitting into the slot turn it down side up and push it into the slot until you hear two "clicks".
If both memory modules doesn't seem to respond, turn off your PC and take both memory modules off, clean the contacts using a pencil eraser, be gentle while cleaning the contacts as a lot of pressure will damage the memory modules, put them back in and turn back on your PC.
Take the dust off the memory slots by using a paint brush.
I would try cleaning both memory modules first and putting both in once the contacts are clean.
Try this and if you're still having problems I would recommend you to seek for a professional to solve your problem.
Hope this tip helps and have a nice day.
Don't hesitate to reply if you're still having problems.
Posted on May 25, 2011
    Thanks
    I took the memory module out and checked for cracks and cleaned it off with a qtip .. rebooted my computer and it works again.. then I put the memory module in another slolt and it still works great .. Thanks for your help ..
    Sergeant:
  • 228 Answers
Try to reinsert the memory module/s if loose or replace if faulty. You can also do it with the Harddrive and other components just to isolate what hardware is causing the destop not to POST (power-on self test).
I hope this helps.
    Thanks I took the memory module out and checked for cracks and cleaned it off with a qtip .. rebooted my computer and it works again.. then I put the memory module in another slot and it still works great ..
  • techiscool May 27, 2011
    Nice to hear that.
Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply: my cpu fan is running but at a low speed. When i t...
In my opinion you have a faulty power supply, replacing only the fan may not solve your problem. Try replacing the power supply.
May 16, 2010 | E-Machines Emachine T5026 power supply **...
When I turn on my machine, I get 3 beeps and my monitor tell me no signal, the model is a T5026 emachine, please email me any suggestions
First use the following steps:
Turn off the system and disconnect power cables
Press and hold the power button for 10-15 seconds.
Reconnect power cables and try to turn it on.
If it remains same, the next step will be to:
Open the case and re-seat memory modules
If you have more than one modules installed, try to test the system with a single module at a time.
Mar 12, 2010 | E-Machines Emachine T5026 power supply **...
EMachine T5026 no boot
This just happened to my t5026. I had to replace the power supply to fix.
Mar 08, 2009 | E-Machines Emachine T5026 power supply **...
Power Supply
Check all power cables plugged into M/board if these are correct
remove all hard ware
hard drives / cd player and anything else
except for video and memory and test to see if it boots. If it does, one of the removed hardware is faulty if it does not then you have M/board failure
Aug 02, 2008 | E-Machines Emachine T5026 power supply **...
Unit will not Boot up
Make sure your monitor is plugged in and try again
Jul 07, 2008 | E-Machines eMachines Desktop PC
Lg pilot amd athlon system
How long are the beeps? If they are shortish then it suggests that the ram on your motherboard isnt working properly. Try removing it and reseating it. Make sure all the power is turned off before doing this.
Also there is a jumper located near the bios battery for resetting the bios. Move that to the clear position then back again after a minuter or so. That will put it back to default setting.
How did the problem start? Had you been adjusting anything in the bios at all?
Dec 29, 2007 | E-Machines Emachine T5026 power supply **...
Emachine t5026, 3 beeps
try a cheep video card from your local used computer parts store they're every where, you'll ask for a pci video card.
Mar 28, 2007 | E-Machines Emachine T5026 power supply **...
Emachines 1900+ gets power to the monitor and computer but wont boot
There could be a number of causes. Do you hear any beeps when the computer starts up? Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board. Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
E-Machines T5026 (RBT5026) PC Desktop Logo
149 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
