Question about Samsung Galaxy Tab Tablet PC
HI.I have some problem in orientation of menus in my galexy tab! For example,In the first, orientation is perfect and work correctly,but after working with other programs, or even when a call anyone to talk, the orientation of menus doesn't work any more. I didn't find any option for orientation. Please if there is a quick solution, let me know. Best regards, Mahdi Shabani
My galaxy tab A keeps booting on start up like it keeps showing Samsung and keeps repeating? How do I fix it?
Plug into charger hold power button down until device powers down
charge fully then disconnect and power up
might work or look at this site to erase cache entirely
https://appauls.com/how-to-fix-the-samsung-galexy-tab-reboot-loop/
Nov 04, 2016 | Samsung Tablets & eReaders
How can I get the screen to rotate over to the correct position?
You might have your Orientation Lock on. If you are using iOS 7 or 8, swipe up from the bottom and disable Orientation Lock (http://cdn.osxdaily.com/wp-content/uploads/2013/10/stop-screen-rotation-orientation-lock-ios-7.jpg)
Alternately, the switch on the side of your iPad might be set to Lock Rotation, so go to Settings > General and see if Use Side Switch To: is set to Lock Rotation. This would mean that whenever the switch above the volume controls is down, the orientation is locked.
Sep 30, 2014 | Apple iPad Tablets & eReaders
I have galexy tab 3 7.0 SM_T210R when it's on standby mode charging normally but when i turn it off it doesn't charging anymore what's the problem??
The charger has a function that restores the battery operation parameters by discharging then charging the battery a number of times. Refer to charging instructions in the pack but I think the cycle is a 3 hourly one, time to charge from a full discharge. If the charger thinks the battery is dead then it will try to recover the battery using this process. You may have left the charger on long enough to charge then also discharge the battery.
Start again and charge for the time in the instructions ONLY, if you are not sure of the time try it for an hour, then without disconnecting the charger turn the unit on and take particular note of any screen messages, if any.
You should be able to continue as normal now, but still be aware of the time you are leaving the charger connected for, as it may take some time before it returns to normal operation and stops trying to recover what it thinks is a dead battery.
Apr 01, 2014 | Samsung Galaxy Tab 3 7.0" - White...
My samsung galexy Tablet is full charged but not responding when I try to turn it on
Does it do anything at all when you press and hold the power button? Hold the power button in for about 15 seconds. That should force it to reboot.
If you get nothing from doing that, then that usually means one of two things: either the tablet is not charged and the battery is completely depleted, or that the tablet is broken and will not boot. Try charging it with a different cable, try a different charger, or try plugging it into a PC USB port with the PC turned on. Leave it plugged in overnight. It should trickle charge that way and give you enough power to boot up.
Jan 14, 2014 | Samsung Galaxy Tab 7.0 Plus GT-P6200 3G...
Unlock codes tablets
the best way to do this is to get a unlocking subsidy pin.
on the back of the device there should be a network operator who the phone/tab is branded to. you will need to contact them direct and put in a request.
this code usually cost about 20.00 but once you have the code it will unlock your device forever and its the safest way to unlock it rather then go to the market where they may damage the software that is installed on the device.
Oct 19, 2013 | Samsung GT-P7500 Galaxy Tab 10.1 UNLOCKED...
Amy samsung tab is stuck while playing games and unable to switch it on
Plugin in Power Cable Then Hold Volume down + Power button for 10 to 20 secs Your tab will Turn OFF. now turn it on using simple power button it shd work perfectly
Apr 04, 2011 | Samsung Galaxy Tab Tablet PC
My galaxy do not rotate anymore...what do I do?
Try pulling down the notifications drawer (drag down on the status bar at the top of the home screen and ensure that Orientation Lock is not selected (if there is no toggle in the notifications drawer, try downloading an orientation lock widget from the Market and toggling that on and off to see if that fixes things.
Other than that, you might want to have the device checked to ensure that the sensors are still functioning correctly.
Hope this helps, Alistair
Feb 23, 2011 | Samsung Galaxy Tab Tablet PC
How does the Samsung Galaxy Tab get firmware updates? I am unable to see any where on the screen menus. Thanks in advance!
Download and install Samsung Kies on your PC then connect the Tab via USB. Kies will detect the device and will automaticly notifies you on the screen if a new firmware update is available. Cheers.
Feb 01, 2011 | Samsung Galaxy Tab Tablet PC
Faulty HP laptop
It mainly comes due to improper mouse orientation. U can download a lot of softwares to orient your mouse. Even after that it is not getting corrected better you consult the HP service center and u can find the nearest service center in www.hp.com. Dont try anything like removing the mousepad by yourself or something like that. For urgent purpose u can use the external USB mouse which is very cheapily available.
Thank U
Dont find a fault ,find a remedy-Henry Ford
Please rate me as it wil just one click for u
Oct 26, 2009 | Tablets & eReaders
Samsung Galaxy Tab Tablet PC Logo
22 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
