Question about Air Tools & Compressors
I have a Lefoo LF10-4h Pressure swith that I can't assemble (from and air compressor). Can you help with a diagram or anything?
2 Suggested Answers
  • 54 Answers
SOURCE: When my compressor cuts out, it starts losing air
The air is probably coming through the unloader on the pressure switch. This is designed to vent the pressure between the compressor pump and the tank so that the compressor starts easier. This venting should only take a few seconds (5 to 10). If it bleeds air continuously, until the compressor restarts, then the tank check valve is bad. This is usually a fitting that extends into the tank. The small tube to the unloader usually goes directly from the pressure control switch to the tank check. Depressurize the tank, remove the check valve, and try to clean it. If that doesn't work, replace it.
Posted on Dec 29, 2009
Testimonial: "I cleaned the check valve and it's working like new. Thanks a lot!"
WHAT IS CUT IN AND CUT OUT PRESSURE
Generally 95 to 125 PSI. Take off the top cover. The factory setting will be written on the inside.
Mar 29, 2013 | Emglo LEFOO Pressure Switch LF10
Lefoo pressure valve leak
Where is it leaking from? If the unloader hisses for a few seconds when the compressor shuts off, it is working fine. If it hisses all the time when the compressor is stopped, it is still fine, but your in-tank check valve is toast. If it hisses when the compressor is running, you need a new switch.
Mar 03, 2013 | Emglo LEFOO Pressure Switch LF10
I have a LEFOO LF10-4H pressure regulator that I tok apart and it fell apart before I had a chance to see where all the part went. Can you show me a diagram of the switch?
I too am looking for a diagram. I am still trying just fit it back together and I have tried to get a diagram from Lefoo, no response to my repeated emails. If I do get it together I will post pics.
Dec 29, 2012 | Air Tools & Compressors
Wiring diagram for e350 ford van air conditioner
You seem mechanically inclined, so I want you to try this before you do anything else; let's decern whether or not the clutch is any good .
I want you to unplug the the plug that plugs into the compressor . Just in case there is a possible short somewhere, clip the wire's to the plug, but leave enough wire to reconnect them back . Attach two pieces of wire to the wire's on the plug that you just clipped, making them long enough to reach the battery . Plug the plug back into the compressor . After skinning the wire's on the other end, touch one to the positive (+) side of the battery, and the other to the negative (-) side of the battery . When you do this, you should hear a click from the clutch of the compressor, if you don't then the clutch is bad, if you do; then you are low on freon, your low pressor swith is bad, or you have wiring problem's .
Sep 10, 2012 | Ford E-Series Cars & Trucks
Unit has developed a continuous leak
need to replace pressure switch as the leak is a worn needle valve assembly. it usually unloads from there when the machine stops
Sep 06, 2012 | Clarke Power Products Inc AC2001 2HP 4...
Sperre air compressor lp safety valve blowing pressure 15 bar normal pressure is 8 bar hp valves and gaskets new
sir i need control drawing for sperre compressor electrical schematic(415 volt motor,pressure switch,thermo swith,drain valve,level switchand alarm( iacms)
Dec 19, 2010 | Air Tools & Compressors
When my compressor cuts out, it starts losing air by the auto pressure control (LEFOO LF10). I removed the plastic cover and felt the air coming out a little valve.
Dec 29, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Porter cable compressor will not restart once it is under pressur
This is likely a bad check valve which is allowing pressure from the tank to leak thru back to the compressor. The compressor won't start because the compressor cylinder has air pressure on it.
The check valve is about the size and shape of a .410 shotgun shell -- it's in the copper line from the compressor to the tank.
May 27, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
714 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
