Question about Dirt Devil Featherlight Bagless Upright Vacuum
Operating Question Where is the switch to switch from the floor to wand mode on the Featherlight bagless model? Thanks.
  • msexton Aug 16, 2008
    So what you are saying is if I take the wand out it will work instantly or do I have to attach the wand hose to the top of the base. The wand and base inlet appear to be different sizes. The wand does not have any suction if used as is.
    The humidity may be getting to me but I am still confused. Help!
    Marilyn
  • Anonymous Jan 14, 2009
    How do I use the wand on the Dirt Devil Jaguar upright bagless machine. There is no place to connect it that I can see, and it has no suction where it is now?
    Novelist:
  • 97 Answers
There isn't one. The wand is always active, because it is the only air inlet on that machine. When it's plugged into the side of the machine, it's pulling dirt from the nozzle. When you pull it out, it just functions as hose attachment.
-R
Posted on Aug 16, 2008
  • Rob Ristin Aug 16, 2008
    The hose should be permanently attached to the back of the body, which means you shouldn't have to attach anything. You should be able to simply pull the wand out from the base and vacuum away. If it's not getting any airflow, you may have a clog somewhere. (A common problem in these.)
    I also just realized that there are several models all with the name "Featherlite." I should have asked for clarification. If you've got the old one with the hose that isn't permanently attached to the back of the body, you can open the little hatch on the hood and connect the hose end into it. (The end that the tools won't fit on.)
    I highly recommend against using the tools on that machine though: the hose dumps everything you pick up directly into the fan, which can result in the fan shattering. Be very careful about what you pick up with it.
    -R
SOURCE:
How do i use the hose on featherlite bagless
Hello! To use the hose on your Featherlight follow these simple steps below.
· Cleaner must be in its upright position. Remove lower hose from the side of the cleaner by twisting to the right and then pull off.
· Remove the hose from the tool caddy.
· Slide the tool hose into the lower dirt hose with the notch facing up. Push together and twist to secure.
· Choose any of the handy accessories or use the hose alone. Simply push the attachment firmly onto the end of the wand or hose handle. To remove tool, twist and pull apart gently.
I have also included a link to the instruction manual if needed. Hope this was helpful!
http://dirtdevil.com/file/661/
May 17, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Wand pulls out but sticks when there is still about 2 inches to go before able to close cap on wand
You might have an obstruction somewhere or something is keeping a valve that directs the airflow from the floor to the wand from moving properly. You will need to investigate all these areas to determine what is nor operating properly.
Feb 23, 2014 | Dyson DC25 Animal Bagless Upright Vacuum
Dyson DC28 - when using this in "carpet mode", I can hear and feel tons of suction being pulled through the wand, even though the wand is properly stowed as the handle for "carpet mode". And when this...
There's no switch per sey, but there is a clutch activation knob, on the right side of the base, as you're standing behind the unit. There should be a Carpet or Hard floor setting, just two. Twist it to change from one to the other. However, all this is meant to do, as far as I know, is to turn on the brush roll or turn it off, by means of a clutch system. I don't think it has anything to do with the wand assembly.
Oct 21, 2013 | Dyson DC14 All floors Bagless Upright...
My Dyson dc 18 slim extender wand has NO suction. There is a plastic white cylinder object blocking.
If the floor head has suction and the wand does not, or vice-versa, the white cylinder you are referring to diverts the suction between the floor head and wand. If the flimsy plastic switch used to turn the cylinder is broken, you may need a new under carriage or just set the cylinder to wand or floor manually and use it as a one dimension cleaner. Depending on your ability, perhaps the switch can be purchases and replaced by a DIYer, but the job looks moderately difficult.
Jan 31, 2010 | Dyson DC18 Allergy Bagless Upright Vacuum
No suction below when carpet mode or bare floor mode selected Lots of suction with wand
it is probably clogged near where the floor part picks up
that is why the wand still works
Jan 06, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Suction
make sure the brush roller is turning.if not the belt ie either broke or it might have come off the motor shaft.feel free to call me at 314-628-9153
Jan 26, 2009 | Dirt Devil Featherlight Bagless Upright...
Knob won't lock in when switching from "floor" to "hose"
if you can remove the knob spray a little wd40 in there fi there is any kind of space.that might free it up
Jun 24, 2008 | Dirt Devil Featherlight Bagless Upright...
Dirt Devil Featherlite Bagless Upright
Check the brush roll, are the bristles worn down? Check the belt also, if it is stretched, then it won't drive the brush roll like it should.
Oct 02, 2007 | Dirt Devil Featherlight Bagless Upright...
Dirt Devil Featherlight Bagless Upright Vacuum Logo
79 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
