I get power cuts fairly often. Sometimes the HP 2410 shows the egg timer symbol, as if it's working on printing something, but there is nothing in the print queue. When it starts up, it goes into a 'hunting' mode, with what sounds like gears slipping, repetitively. I have tried the "Hold OK and Cancel, take the power plug out, then plug it back in" rote several times. A message saying "Deriv cleared" comes uo, and "Turn power on"...but it doesn't fix the problem. It seems to be an intermittant prblem...sometimes it clears itself if I leave the power off, other times it doesn't. Can you advise? Cheers and thanks Short
  • shortallerto May 25, 2011
    I have found the answer elsewhere, but I will pass it on to you, gratis. "Hold the cancel button down throuightout the printer start-up sequence".
    Thanks anyway.
  • 151 Answers
SOURCE: HP Deskjet 3845 print queue not clearing
Have you tried going to safe mode, turning off the printer and manually opening it at the control panel>printers... try and delete or cancel prinitng at these settings...
Posted on Dec 09, 2007
  • 1879 Answers
SOURCE: Printer hangs up.
1. check the printer, make a copy
2. check connectivity, open device manager - USB Printing Support(under Universal Serial Bus Controllers) must be there - swap cable/port if it´s not
3. uninstall, reboot then re install printer driver
Posted on Jan 04, 2008
  • 16 Answers
SOURCE: my hp psc 2410 photosmart printer will not print - only copy
Check to make sure your PSC 2410 is in fact the default printer. If it is, make sure your cable is firmly plugged in to your printer and CPU. Clear the print queue. Turn off and restart printer. I have found that your problem is basically a communication problem between the computer and printer. Also check Good luck.
Posted on Mar 01, 2009
SOURCE: hp psc 2310 is "stuck"
This has been solved in the forum. Clean the bottom of the scanner glass. You have to take a bit of it apart but it's not hard with the help of this HP site:
Good luck.
Posted on Apr 29, 2009
  • 4041 Answers
SOURCE: To my disappointment I called Hp and spoke with
Hi ok try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
Hp psc 2410 photosmart driver win7
HP no longer provides support for drivers for this printer. The newer Windows OS will support the printer natively, but sometimes it requires a little finesse from the user. Here is a link to an HP forum where folks tell how they worked out the communications issue for the print and scanning functions. Hope this helps!
adding hp psc 2410 printer to windows 7
Aug 01, 2016 | HP PSC-2410 PhotoSmart All-in-One Color...
Screen on hp psc 2410 shows picture of hour glass
I too have this problem and I have found how to correct it. It worked for me and hopfully it will work for you and others. Turn off your printer. Open the scanner cover. Turn your computer back on. That is what I did and it fixed it for me for now. Please send me an E-Mail if it fixed it for you. I have a sneaky suspecion that it just started working again and me opening the scanner cover was not the fix. Thanks, Wayne
May 23, 2010 | HP PSC 2410 All-In-One InkJet Printer
HP psc 2410 photosmart all-in-one not piking up paper
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Sep 16, 2009 | HP PSC 2410 All-In-One InkJet Printer
HP Director
NOT ONLY UNISTALL IT , you have to go to : START , SEARCH , then write HP psc 2210 , whatever appears DELETE them , you have to be sure that is clean and no left files of the program , then try again and INSTALL using the provided CD disk , I own the
HP 2410 , and it happen to me before . good luck , AJ
May 19, 2009 | HP PSC 2210 All-In-One InkJet Printer
Busy or hourglass object appears in screen. Won't work
If there still pending job to print. Cancel all printing job until all printing job is clear. Then power off the printer and then power on again to refresh its print que.
Hope this one helps
Apr 14, 2009 | HP PSC 2410 All-In-One InkJet Printer
Will not find home position after switching on makes clicking noise screen 's got egg timmer showing after afew minutes it stops clicking but remains with egg timmer showing help?
The carraige is moved by a toothed rubber belt and plastic gears. Unplug the machine, open the front cover, and manually relocate the print carraige to the far right. Close the cover and plug machine back in. Hope this helps.
Feb 18, 2009 | HP PSC 2410 All-In-One InkJet Printer
My hp 2410 printer always needs to be rebooted before it prints
Are you using a high speed USB cable? The old serial cables do not work as well and can sometimes balk at data transfer.
Documents are printing slanted on page
It sounds like need some technical maintenance and at that point you have two options.. take it to a service center, or buy another printer (or if whithin warranty talk to HP about your problem, your attempts to fix it and possibly get it replaced). sounds like a component inside your printer may be either not working properly or there's something inside keeping the rolling componentes from keeping the page straight as it goes through your printer.
It does not sound like a driver problem...
btw.. did you mean carriage jam or cartridge jam??
if it was carriage:
if it is a cartridge error try check the following:
Nov 26, 2008 | HP Photosmart 2410 All-In-One InkJet...
Fax HP PSC 2410
I HAVE PSC 2410 XI All-In-One AND Fax HP PSC 2410xi does not work PLEASE HELP
Feb 01, 2008 | HP PSC 2410 All-In-One InkJet Printer
49 people viewed this question
