Question about Xerox DC440ST Copier
Print engan falt - Xerox DC440ST Copier
    Sergeant:
  • 372 Answers
Disconnect the ferry .
Posted on May 26, 2011
I have a 2004 l300 diesel van. The alternator has stopped charging and I have 3 warning lights on the dash.The battery light , fuel filter light and the low oil light.
Hi if the alternater has packed up then the ecu has put these falts up becouse it sees a falt in the system ,get the alternater fixed and then the other falts should wright there selves,hope this was some help.
Nov 16, 2016 | Cars & Trucks
What could be the problem if the fuel Guage isn't working?
HI CHECK THE FUEL GUAGE SENSER IN THE ENGAN AND THE FUSE
Apr 05, 2016 | Cars & Trucks
Trans keeps filling with fluid,don't know where its coming from any idea transfer case is new
Hi,it sounds to me like this is a internal falt a internal seal falt.
May 01, 2015 | 2004 Cadillac SRX
Supply falt
Try English language please
May 11, 2014 | IBM Computers & Internet
No spark
Have you checked the auto shutdown relay ?
Jan 05, 2014 | 1994 Dodge Caravan
I have a 98 Nissan Pathfinder that will not pass emissions because of all these sensors that arent working. I was told they possibly have a bad wire. Like they all share a common and i have a short...
The first thing to do is to add an additional hard wire ground. Its easy, inexpensive and will help to ensure that a system ground falt is not causing random sensor falt signals to the computer resulting in check engine codes. Attach a new wire from the battery to the block to the intake manifold.I have had this problem and it took a long time to figure it out especially if you have multiple sensors falting. Would'nt think of a central ground falt but it does happen.
Dec 15, 2012 | 1998 Nissan Pathfinder
I have falt codes on air cinditioner screen after a battery change, how do i reset?
scan the ob2 port, verify trouble code, then clear with scan tool
Mar 17, 2012 | 2001 Jaguar S-Type
Wont start engine does not turn over
if it dont spin no mater what the engan probubly thruo a rod or starter frid
Jan 25, 2010 | 1991 Mercedes-Benz 190
2002 Intrepid 2.7 motor just shuts off when stoping check engan light came on and code was a map sensor changed it still stoped running hade the light reset and it just came right back on this time...
check for vaccum leak at map sensor or anywhere else no vaccum to map will show up as bad because the computer watches the voltage on it and the vaccum changes that voltage , no vaccum meens no voltage change and computer throws the light on to let you know there's a problem somewhere.
Dec 27, 2009 | 2002 Dodge Intrepid
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
