Question about Everex GA3400 Refurbished AMD Desktop Computer - AMD Athlon 64 3400+ 2.2GHz , 512MB DDR, 120GB HDD
To run or not to run?
Sometimes when you push the power button on the only thing that comes on is the light in the button,or the button and the internal startup fan (which stays running without slowing down).With either one of these there is no out going signal.You have to keep rebooting until it properly starts up.And when it does start up(I dont know if this is normal for this computer,its done since I bought it new)it lets out this really low growling noises like an old time fax or copying machine.It also recently has ben making some really low crackling noises.All these noises have been coming from the component thats in computer the case right behind the power button.And is it possible to get hardware schematics of the internals of this computer?
  • 3,153 Answers
DO NOT RUN IT
I have a computer in right now that had the same issue.
It was a build up of dust etc in the power supply that actually cause arcing in the power supply and pretty much wiped out the computer.
Posted on Sep 14, 2009
  • Project NOMAD
    Project NOMAD Sep 14, 2009
    It does sound like an overheating computer they are designed nowadays to shut themselves down if there is a problem
    What you should do is check the fan assembly If you see a build up of gunk and debris then get yourself a can of compressed air used for cleaning computers and take the unit outside.
    Whilst wearing glasses use the nozzle on the can to blow out any debris from the CPU and power supply.
    If everything went to plan you should now be back in business.
    Another consideration is that many cases have places in them for extra fans and usually extra connections on the motherboard too.
    They are quick and easy to fit.
    Quite often I will fit TWO in what is called a push/pull configuration. One pulls cool air in while the other pushes hot air out.
    These will not only help keep the computer cooler but also cleaner
  • 700 Answers
Seems to me a fan is place beside or behind your power button. And making the growling sounds, might be needed some oiling or its wires is touching its blade when it runs(crackling).
Powering without signal to monitor could be attributed to dirty memory contact or failing RAM card.
Some symptoms could be attributed to shorted to chassis component, power supply, and BIOS problem(constant rebooting to turn it on).
  • 36 Answers
He interior of your PC is basic enough that an idiot like me can navigate through it with a good how-to book or tuorial. TechRepublic, CNET, PC Hell, PC World are just a few of the sites that have good articles and info. I also look for discussion groups and forums since they ofen have links posted inside that I may find interesting. Also check the website of the makers of your PC, Mother Board or whatever you want to know about.
Posted on Nov 13, 2008
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Compaq Presario CQ50-139WM will not boot.
first thing i would try is to unplug the powercord from the surge proetctor and from the computer. turn the computer over and take out the battery.
with the battery out, press on the power button for 30 seconds.
now put the battery back in and plug in the computer and try booting it.
sometimes static electricity builds up inside the computer and this will dissipate it.
Oct 02, 2009 | Compaq Computers & Internet
1999 RCA mm36100 TV The buttons on the front panel are all messed up sometimes they work and sometimes not. The menu keeps popping up from time to time randomly and sometimes runs though the menu items all...
Bad push button board, best thing to do is just unplag the board and use remote to operate TV, board is mounted under front cover where button are.
Aug 09, 2009 | RCA MM36100 36" TV
System does'nt always start up, push power button and power light comes on, HDD light flashes,nothing else happens. Push power button to shut off sytem. Power up again and computer might start and run for...
You might try the battery first. If it's not getting properly charged then it won't start.Then if you let it sit for hours (or days) it gets enough charge to start. It could also be that the power cord or connection point is faulty. I would check these things before looking at the mother board. Most laptops will give you a "blue screen of death" if the mother board is going out.
Aug 02, 2009 | Acer Aspire 9300-3716 Notebook
Qosmio G35-AV600 boot problems
You will have to reinstall both its BIOS and operating system, only that can properly solve the problem. I my solution was helpful, Kindly accept it.
Thank You, Arjun
Apr 01, 2009 | Toshiba Qosmio G35-AV600 Notebook
Blinking green reset light
Can you please supply us with the make and model as well as the blink count of the green light. That count should be indicating the problem circuit. Once that info is posted, we should be able to give you more details and possible solutions.
Dan
Jun 19, 2008 | Televison & Video
Power Problem
power down only apply if you power down button put the hold 5 second printer automatic power down after that u unhold
Feb 26, 2008 | HP PSC 1610 All-In-One InkJet Printer
The Dreaded Blinking red light
what actually happens when you try to reboot?
Dec 07, 2007 | Computers & Internet
Everex GA3400 Refurbished AMD Desktop Computer - AMD Athlon 64 3400+ 2.2GHz , 512MB DDR, 120GB HDD Logo
71 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
