Question about Evenflo Easy Swing Gate
The latch on my evenflo gate is broken. The gate is 7 yrs old and fits an odd space. The latch is plastic. It is a wooden walk through gate.
2 Suggested Answers
  • 10865 Answers
SOURCE: I am trying to install an Evenflo Summit Gate and
hi double mom... if i was nearby i would stop in and take care of this for you. the screws are spinning because they are only in sheetrock. go to any hardware store, lowes, or home depot and get some wall anchors. take one of screws with you and show it to the clerk so you get the correct wall anchors for the job. Joe
Posted on Apr 18, 2011
Where can Ibuy the latch housing and the bracket hinges for Evenflo safety gate. I'm in Canada.thank in advance
GO to evenflosecurestep.com, they will have parts listed on website. Usually they will send the part free of charge if you tell them it was defective. There is a recall on some models here is the link. http://article.wn.com/view/...recall_of_Evenflo_TopofStair_Plus_Wood_Gates
Jun 09, 2014 | Evenflo Secure Step Top Of Stairs Gate -...
What is perfect gate closer for garden gate?
Latching gates most popular gate in garden. Gate closer Chain connect to gate pipe with a eye hook. we provide best solution for latching gates in garden.
Jul 04, 2013 | Garden
How do i open a evenflo walk thru baby gate
There is a small slider under the handle that you slide back with your fore finger while lifting the handle.
Oct 05, 2012 | Evenflo Easy Walk-thru Child Gate 4482200
We lost the directions to install the gate and can't figure out the handle/how to latch and unlatch?
from evenflo.com
Evenflo Child Safety Gates
  • New one-hand Lever-Locâ„¢ mechanism -- simply squeeze the buttons and push down to open
  • Smart design cuts installation time by 75% -- pre-assembled for 5 step installation
  • This child safety gate swings in one or both directions for easy walk-through
  • Red/green indicator shows whether gate is properly locked
  • Adjusts from 29" to 42" wide, 30" tall
Jun 14, 2011 | Evenflo Secure Step Top Of Stairs Gate -...
We have a 10 ft. wooden even flo baby gate but have no directions for set up we can't figure out what the door of the gate connects to
Here you go. Just enter the model number in the search box and you'll be good to go!
https://plweb.evenflo.com/replacement_parts.aspx
For quick reference, just open the link below to see if your gate is listed, click on it and it will tell you the model #
http://www.evenflo.com/category.aspx?id=45
May 09, 2011 | Evenflo Toys
How to install the Evenflo 42'' position and lock gate
  1. Measure the opening where you want to place the Evenflo gate. An Evenflo pressure-mounted gate will work for an opening between 26 and 42 inches wide.
  1. Pull the cross bar up on the Evenflo gate so that the small metal sizing bar is movable.
  2. Place the metal sizing bar into the slot that matches the measurement of your opening. If your opening is not a full inch, round up to the next full inch and place the sizing bar in this slot.
  3. Set the Evenflo gate in the opening with the cross bar facing away from where your child will be. Make sure the pressure points are above your baseboards.
  4. Press down on the crossbar until the metal U-shaped clamp catches the bar.
  5. Test the gate by gently pushing and pulling on it to insure it stays in place.
Feb 28, 2011 | Evenflo 42" Position & Lock Gate
Broken sienna gate latch (2000)
I have the 2002 sienna and have had to replace mine twice. The second time the toyota parts guy said they upgraded the latch we lookede at them side by side and no noticible change. Once you get the latch off you will see why it breaks, plastic lever arm. It is really not a hard replacement. The rear cover needs to come off of the inside of the gate. and you get easy access to the gate latch. The first time replaced it the sales lady said "you don"t want to do this do you?". Of course I did. Not sure what they would charge but its not worth it. The part just seems to last 2-4 yrs depending on use. There is a cable similiar to a bike break cable that releases the lock you must unhook and rehook once you have replaced the latch. The license plate light assembly comes out with the latch. If you have a basic socket set you can do it in two hours.
Feb 07, 2011 | 2000 Toyota Sienna
2000 Toyota Sienna tail gate latch is broken and can not open
Had this same problem on my 2000 Sienna. You have to purchase a new handle mechansm and install it from the inside. To do that you will need to crawl into the back of the van and remove the plastic cover. Once this is done you can snake a screwdriver in and pop the broken latch open. Then it is just a matter of unscrewing the old latch mechanism out and screwing in the new one, making sure to replace the latch wires appropriately.
Jan 29, 2011 | 2000 Toyota Sienna
Tailgate latch is broken, can't open tailgate. Window is open.
unfortunatly there is no way to open the tail gate(without breaking the inside cover )but once you do that,your hand can fit inside the gate and all you have to do is feel around for the gate latch,pull it,then the gate will open. hope this helps(i have a 1996 blazer i had to do the same thing)!!
Dec 17, 2009 | 1989 Chevrolet S-10 Blazer
The latch that holds my evenflo stoller closed has broken. Where can I get a replacement latch?
You should contact evenflo for a replacement part- or else you can order them if you follow the link - it takes you to the ordering page on their website for replacement parts- https://plweb.evenflo.com/product_search.aspx?txSearchModelNo=5881485a&txSearchDOM=2/4/2004
Apr 21, 2008 | Evenflo Aura Elite Travel System Wedgewood...
Evenflo Easy Swing Gate Logo
115 people viewed this question
Top Evenflo Baby Gear Experts
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Stitch85
Level 1 Expert
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
