Question about Philips Televison & Video
I want to wall mount a Philips 32PFL7962D/05 LCD TV, but the manual shows 4 ixing points, one in each corner, that do not appear to be there on the back of my TV. Where are the fixing points supposed to be? The bracket I have been given appears to match those I have found on line that "guarentee" to fit my TV
SOURCE: how to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
Posted on Feb 09, 2008
  • 213 Answers
SOURCE: Thin Yellow Vertical Line - Samsung LNT4665F LCD TV
it sound like the the part that you need to replace is assy pcb maine-amlcd p# bn94-01199e 306.20 core of 50.00 or the ip board P# bn44-00168a but be vear care whan you do this job the cable the some time to git offf the pcb mount. good luck this sould help you out.
Posted on Mar 30, 2008
mfspencer
  • 58 Answers
SOURCE: Thin Red Line on LCD TV
Unfortunantly you have a bad lcd panel or control board, but the only way to get the lcd control board is to order the panel. Philips does supply lcd panels for most of their models but they are very expensive. Sorry for the bad news but I hope it helps you.
Posted on Apr 02, 2008
SOURCE: removing base from tv
I researched this problem on the net and found the solution. Someone on one of the posts said the base can be removed by taking out four screws - all from the back of the TV. One screw is the one closest to the power plug, the next screw is beside it, the remaining two screws are the corresponding screws on the opposite side of the base panel (still on the back of the TV). Once these screws are removed the base comes off including the mounting bolt and the rectangular shaped plastic panel. There are no electronics or any components inside the base panel, only the bolt and plastic base which are held on by the four aforementioned screws. It was very easy to remove!
Posted on Feb 25, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Posted on Mar 01, 2009
How do I change my tv to hdmi without remote
press mode and then either channel or volume button thenit should work
May 13, 2015 | Philips Silver Tilt/Tilting Wall Mount...
How to resert colour on philips tv model 37PFL5522D/05
there will be an option on your controls that allows you to reset.
go to colour
select factory default
Aug 12, 2013 | Philips Silver Tilt/Tilting Wall Mount...
Remove base to wall mount
Place the TV face down on cushioning. There are four short hex head screws that hold the TV to the stand. There are two on each side of the mounting point (close to the bottom of the TV). (Turn counter-clockwise to loosen.) Next slide the base down from the bottom of the TV. The appropriate sized hex key was supplied with the TV (and the base was installed). If you want to, you can unscrew the support post from the base - it has 4 long hex head screws. This will let you put the base parts into an appropriate container for storage.
For a clear picture, see the manual for installing the base and work the steps in reverse. See here for a copy of the manual: http://www.managemylife.com/mmh/owner_manuals/search?query=LC46SB54U+ .
To put on the wall mount, you will need to remove the covers from the 4 mounting locations on the back of the TV and use the screws from the wall mount bracket kit.
I hope this helps.
Sep 16, 2010 | Sharp LC46SB54U 46 in. LCD TV
Wall mounting
Hi, are you saying you want help with mounting your LCD TV onto the wall.
http://www.hometheaterblog.com/hometheater/2006/05/how-to-wall-mounting-a-lcd-or-plasma/
http://www.youtube.com/watch?v=lCNyc-KgCDY
If you need more help, please ask.
Regards - Anthony
Feb 10, 2010 | Proscan 37LC30S60 TV
Philips tv mounting problems
did you ever find a solution for this? the same thing happened to me, and now philips wont repair the mounting hole. I am so mad and will never buy another Philips again!
Dec 26, 2009 | Philips 42PFL3704D LCD TV
I have an Olevia 332 b11 LCD tv. I want to mount
There should be at least 4 mounting holes (VESA mount), and they should be used.
Dec 17, 2009 | Olevia 332V LCD TV
I have a 37
Metric M5 screws, the wall you buy will be supplying with mounting hardware.
http://www.toptvmounts.com/
http://www.mountsdirect.com/
http://www.mountsmadesimple.com/
Just Google " wall mount for xxxxx"
Nov 24, 2009 | Televison & Video
Can thris protron tv be mounted on a wall?
it can be mounted, they sell a universal hanging kit, you will see 4 holes in the back of the tv, thats where you put the screws for the mount
Jan 11, 2009 | Protron PLTV-4250 42 in. LCD Television
Samsung 101cm lcd Mounting??
Yes they are the mounting holes but I would not trust a universal mount to hold an expensive TV set on a wall.
Nov 26, 2007 | Televison & Video
Televison & Video Logo
101 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
