Question about Farmall IH Tractor 706, 756, 806, 856, 1206, ITIH32
Ih 806 pto and hyd quit working - Farmall IH Tractor 706, 756, 806, 856, 1206, ITIH32
What year is my ih 706?
I think they were made from 1963 to 1967. Yours was made between '64 an '65.
Jul 02, 2015 | Farmall IH Tractor 706, 756, 806, 856,...
Remote valves not working.you can raise frontend loader but it want come down. also the bucket want work . change all hyd fittings.and check pump pressure thats good. need help.
Change the filter. If you can lower the loader by loosening a line at the valve, suspect the valve. All lines usually dump to tank at the valve. Make sure that line is ok. If any valves are electric, suspect them even more.
Nov 25, 2013 | Farmall IH Tractor 706, 756, 806, 856,...
I have a 806 keeps slipping out of high gear
Did you find a solution yet , I have and 806 also and it does the same thing
Feb 14, 2013 | Farmall IH Tractor 706, 756, 806, 856,...
How do i remove the PTO from an IH 856. The lower PTO shaft broke and the unit will not slide out
make sure all the bolts are out should be 1 short bolt and 8 long bolts to remove pto after that it is stuck to gasket. short bolt is in lower left corner of housing
Dec 26, 2012 | Farmall IH Tractor 706, 756, 806, 856,...
When engaging PTO it takes a few seconds before engaging bought the tractor new have changed hyd filters regulary. Any suggestions?
hydraulic filters wont help since pto is self contained unit first of all check pto lockup pressure my best guess is that clutches are probably getting worn
Oct 11, 2010 | Farmall IH Tractor 706, 756, 806, 856,...
My steering on my 806 Farmall gets stiff, but I mash my breaks and it loosens up. What can it be?
More than likely the issue is in the multiple control valve that feeds both the brakes and the steering. It bolts to the left front of the tranny, right under the battery. While you're in there, it's a good time to re-gasket the pump. Buy yourself an I & T book, # IH-32. You'll need it! Also, don't lose the spring and check valve when you pull the control valve off the tractor!
Mar 15, 2010 | Farmall IH Tractor 706, 756, 806, 856,...
I have a farmall M. that i can hardly turn this winter. it was ezy to turn this summer. is there a steering gear box that might be low on oil?
It could be that the grease stiffens in winter.
Speak to the supplier, it might be a common problem and therefore a simple answer ( e.g. replace the grease with a lighter type).
Dec 18, 2009 | Farmall IH Tractor 706, 756, 806, 856,...
Farmall IH  Tractor 706, 756, 806, 856, 1206, ITIH32 Logo
97 people viewed this question
Top Farmall Toys Experts
Wayne Fellows
Wayne Fellows
Phil Walker
Phil Walker
Jerry Radcliffe
Are you a Farmall Toy Expert? Answer questions, earn points and help others
