Question about Konica Minolta Bizhub 362 Copier
Minolta Bizhub 362. Brand New. After configuring IP address, it asks to switch off and on again. when switching on, displays "please wait". Do not go further.
  • mmhtrading May 25, 2011
    Switch off and on again
  • Zaheer Ahmed
    Zaheer Ahmed Oct 27, 2011
    after restarting the machine, basic screen shows or not?
Svp erreur code C211 de konica minolta bizhub 362 comment faire
Posted on Oct 21, 2012
    President:
  • Konica Minolta Expert
  • 347 Answers
Restart the machine and wait for some time.If the basic screen shows and machine can make copies then its ok if not then again go to the administrator mode, network setting, check the ip if there is no ip then some of the options are missing.call your technical services representative or tell me in detail by email
xeerie@yahoo.co.uk
i will try my best to help you..
Posted on Oct 27, 2011
What can do to configure my bizhub c300when network setting did not display?
Go to Admin mode, then network, TCP/IP, then enter the IP address, subnet and gateway. SET FOR STATIC IP not DHCP!!!!!!!
Default admin pw 12345678
Feb 13, 2015 | Konica Minolta Bizhub C300 All-In-One...
Want to change ip address of bizhub 362
we are deals in repairing/ amc/ rental of all types of konica minolta
or canon photocopier in delhi & ncr
Gaurav Pahuja 9811139117 , 9990258388
Jul 29, 2011 | Konica Minolta Bizhub 362 Copier
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
Dec 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Scanned documents on our bizhub 362 no longer save to folder on our server. We are not sure why, as we did not change any settings on the server or the bizhub. Help???
Check the ip address of your server in copier.if its change then enter the correct one.If user name and password of your server has been changed then re enter the new in copier machine.(in one touch settings)Check the folder name it should be the same as entered in copier machine.Make sure your server and copier machine are connected with each other.Check the cable or check it by using ping command.
Aug 04, 2010 | Konica Minolta Bizhub 362 Copier
I HAVE A KONICA MINOLTA BIZHUB C351, I WAS MESSING WITH THE NETWORK CONFIGURATION AND NOW I CAN'T PRINT, IS THERE ANY WAY TO RESET IT TO FACTORY CONFIGURATION??? ANY HELP PLEASE...
First of All, Assign an IP address to the machine, if you already assigned the IP address, then Ping it from one computer to check its connectivity, now remove all the printers and printer drivers from your computer, and re-install the printer. if you want to reset the machine, then press the "utility/counter" button and turn the machine ON,(keep the button pressed) now from that machine reset the machine.
Feb 27, 2010 | Konica Minolta bizhub C351 All-In-One...
How do i determin the ip address for c350 bizhub, I trying to connect to a dell through a hub
If the printer really is connected to a "hub" (not a "switch", not a "router"), then you'll have to use the controls on the printer to *ASSIGN* an IP-address to the printer.
If the printer is connected to a "switch" or a "router", it should _automatically_ obtain an IP-address. Use the controls on the printer to *VIEW* the IP-address that it obtained.
Dec 26, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Bizhub 350
You are getting a failure sheet. This happens when the scan doesnt go through. I think you are reffering to SMB scanning, which needs to have the following setup on both the MFP and the copier.
Host ID or NAME - IP address or hostname with DNS resolution.
Share Name - This is your SMB share name or folder share name on the remote PC
User Name - This is an account that is configured on the remote PC
Password - This is the password for the account setup on the remote PC.
Some things to keep in mind: Third party firewalls can block the bizhub from writing files.
Set share permissions to full control. (under sharing tab> permissions buttion)
Set NTFS permissions to at least write access. (if you have a "security" tab on the shared folder.
Or, you may see something like "allow network users to change my files" on the sharing tab. This basically does the same under different configuration scenario.
One last thing. If you havent changed anything since the problem started, it is probably just something like an expired password on the account that is setup for the copier.
Good Luck.
Jun 05, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent? If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g. d53b002.jpg
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
May 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Getting the ip address
To print out machine current ip address, go to utilities, user setting, printer setting, print reports, configuration.
Mar 12, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta Bizhub 362 Copier Logo
316 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
