HAVE NO HEAT, DON'T HAVE PROGRAMME MANUAL - Heating & Cooling
  • Walter Kunesky
    Walter Kunesky May 25, 2011
    Can you tell me the name of the thermostat and also the model number and maybe I can help.
  • 5,677 Answers
Hello, Many of the manufacturer's have information online. Just find the name of the unit and the Model number and use your Browser. Put in the name and model, hit search or use a variation like name, model and operator's manual.
You will find both free and paysites. You can usually get enough info to do what you want with the controls. You can also print the manual on your computer. I have done this with my Manual.
The Digital touch screens seem to be the hardest to do. Make sure to look in the Manual about Batteries for the unit. Sometimes your heat will not work if the Batteries are bad, but if the A/C worked then the Batteries should be okay. The Batteries should be replaced on a Digital Thermostat after a year or 2.
Most Thermostats have 2 small switches at the bottom. The fan stays on Auto and the button for heat and cool must be slide back to heat if that is what you want. With the Digital type you usually have to reset the Degrees when changing functions.
I hope my solution is very helpful to you.
Posted on May 25, 2011
Cc3 001 00001907
Hi, by program do you mean the brother solution center / driver or do you mean user manual?
Driver download page
Manual Download Page
May 15, 2013 | Brother Dcp-J125 Compact A4 Colour Inkjet...
Plug in byron sx83 stops working,when you take it out the socket then replace it works for a short whill then stops again
I have a different problem with the same model.
Firstly, I think the reason yours stops working is because when you first plug-in / switch-on the power, for the first 10-seconds, the bell is in 'programme' mode. Press the button to connect with the bell and it is then programmed. Sorted. However, if you unplug, have a power-cut, etc. then the button is no longer connected to the bell and needs to be programmed again.
FYI - when in programme mode almost any remote (which is what the button is) can be programmed to ring the bell (e.g. television remote)... so ensure you don't press any other buttons within the 10-seconds 'programme' mode!
My problem is, even after I programme my button to connect, it stops working after a short while. Please let me know if this is happening with yours and if you ahve any solutions.
Thanks,
Jason
Jul 05, 2012 | Cars & Trucks
I don't have a condenser in my pick-up trunk, so I don't have AC, is this also why I don't have heat or heat/AC fan does not come on
checked the fuse for the blower motor. if the fuse is good check for power at the motor. the blower motor is behind the golve box.
Apr 26, 2012 | 1998 Chevrolet K1500
Hi Colin, I need to find a manual for my dishwasher. Its aMatsui M12FDW09 any advice would be great thanks. Dishwasher start to make strange noise and the water is not coming through to start the first ...
Hi Colin,
Please click the link below to download the manual for the Matsui M12FDW09:
http://www.partmaster.co.uk/company/partmaster/manuals/M12FDW09_IB_GB_FINAL_091110.pdf
The manual is in English. Please ignore the Japanese text on the cover. Unfortunately, it's unlikely having the manual will help you identify the cause of the fault.
I'm assuming the flashing light you are referring to is numbered 1 in the control panel diagram on page 2 (the 5th page of the PDF manual). This light simply indicates the dishwasher is in the pre-rinse stage of the wash cycle. Your description suggests the solenoid has failed, so the water inlet valve isn't opening and no water is entering the dishwasher.
I only repair Matsui washers on call-out as they are a Dixon's Stores Group (DSG) only brand in the UK, so I don't see that many of them and can't get service manuals. I can diagnose and fix them when they're in front of me, but I couldn't tell you from memory how to get access to the components and test them.
I hope this helps you a little, even though it doesn't really solve your problem.
Regards, BElectric
Oct 20, 2011 | Dishwashers
My sansui air con does not produce heat even if I set the temp at 32. I cant find the manual. What am I not doing right
I do not know what A/C unit you have but Heat Controller is a name. It would not suprised me the it doesn't have heat. Most window A/C don't.
Jun 30, 2011 | Heat Controller Room Air Conditioner
Need instruction manual for Hoover optima 7 spacesaver washing machine. Builder thrown them away. Don't know what temperature for which programme
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 24, 2011 | Washing Machines
What do all the symbols mean on the Kenwood Breadmaker. I have put all the ingredients into the bread pan but don't know how to start! I want to choose Programme 5
You'll need to download a free instruction manual to solve that issue. Use your model number + the word MANUAL plus the abbreviation PDF to perform an Internet search
Example: KHB178 MANUAL PDF
Happy Hunting!
Note: Breadmakers model numbers are usually located on the backside or bottom of the unit, either on a printed decal or raised plastic embossment, and usually followed by abbreviations such as mdl, mdl no, model, model no, type, style, art, art no, article no, cat, cat no or catalog no.
Jun 23, 2011 | Kenmore Kitchen Appliances - Others
Amana PTH153B50AM AC & Heat pump. fan works AC & heat don't. I was told by the guys who installed it to unplug it to reset the termostat but that don't work either. I turn it on cool &...
Jane, what you really need is the Owners Manual for you discontinued model AC/Heat Pump.
Call Amana Customer Support 1-800-843-0304 and they can furnish you one. Either by email attachment or by snail mail.
Hope this helps you. Please let me know.
Jun 20, 2011 | Amana PTH153B50AM Air Conditioner
I cant sign in in my skype account..whenever i enter my password..there is a word flashing in my computer SKYPE stop working..what will i do?
Don't waste your time. Control panel Remove Prog Programme.
Download latest skype update and re-install. Happens 1or2 times with mine, I'm already grey, don't need the agro these days.
May 26, 2011 | Computers & Internet
Instruction manual
Hi SJ, I don't think you need to worry too much about using the massager; you pretty much just plug it in and go from there (assuming you're in the US). Don't use it more than 20 minutes and don't use it while bathing. Additionally, should not use the massager on
  1. sensitive or inflamed skin
  2. varicose veins
  3. the front of your neck
  4. **** areas
  5. sleeping people
You can also check out their attachments and see what they're used for at their website: http://consumer.wahl.com/product.cfm?sid=13&ID=30. If you still would like the booklet, message me at jjones at thesexsite dot com and I'll scan it for you. Hope this helps, Johnathan
Jan 19, 2009 | Wahl 2 Speed Hand Held All Body Massager...
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
