The Epson T13 printer Printer not ready it shows ink blank when ink is not empty after that it shows printer is not error.
Soulvisitor
  • 1113 Answers
SOURCE: Status Monitor says ALL ink cartridges empty
Using recycled ink cartridges in your inkjet printer is never a more economical way to do colour printing, unless you are willing to become a master technician on your particular product and have ready access to print heads and machine engine unit replacements, you will also need manufactures service software/website to reset waste counters/error codes.
It is expensive to print in colour full stop. Printing cost is at least 30cents inkjet and 10cents toner/laser per sheet
Laser b/w and colour is far cheaper per sheet, but setup costs are one time expensive but they are also a lot more reliable printing system.
Your machine will stuff up sooner rather than later when using non genuine consumable, and when it does it will cost more than the machines worth to even look for repair, so be prepared if choosing this road to purchasing a new printer every few cartridges if you are lucky.
If your using non genuine products and you want machine looked at by a professional the first thing you will need to do is install all genuine products in to your machine to allow correct fault diagnostics to be done, this is before any repair cost that maybe incurred.
Recycled/refills/aftermarket ink cartridge faults include – not recognizing ink, poor print quality, error codes, wont come to ready, erratic carriage movement, lines, waste counter issues and also paper feed problems, circuit board/connection faults caused by leaked ink .Not all faults are immediately apparent it takes time for the poison ink to replace that in the supply system then issues begin.
Cheap printing can be achieved using b/w lasers they cost less than 2 cent per sheet and have a brilliant reputation for print quality and dependability. Then if you need the occasional colour go to the shop, let them have the hassle, stress, time and expense of running the machines and the cost is still relatively cheap to you.
There are many consumers still printing with 10 year old laser machines, you would be extremely lucky to find a 3-5 year old inkjet.
If you must recycle well buy one that has already been proven to be adaptable to the concept, so that means go back to older units that went so clever.
Older Lexmarks, Epsons and HP were once easy targets, there was and is a lot of development gone into managing bulk ink deleivery systems, software has been cracked and parts can be sourced.
Inkmizer canon/epson bulk ink modified printers
Chipresetter be prepared for some frustrations and mess.
P.s. Most new machines come with starter inks that do not contain as much as new ones ussally 3ml instead of 5ml to enable cheaper selling cost, but also note that about 2ml of ink is in the tubes that run from ink carts to print head.
Posted on Dec 22, 2007
tigertail
  • 163 Answers
SOURCE: epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Posted on Apr 02, 2009
  • 11 Answers
SOURCE: Epson printer says "cannot recognize ink cartridges".
Are you using genuine epson cartridges? Many generics simply dont work on the newer printers. Once the printer decides the cartridge is empty, it sends a signal to the chip and that's it. You might hear ink, but if the chip says empty you can't use it. It also has the annoying habit of doing this when there's still 10-15% of the ink left.
I use reusable cartridges from http://www.ccs-digital.com They hold 2/3 more ink and the chips automatically reset to full if you remove and re-insert the cartridge. Instead of replacing the entire cartridge when it's empty, you pop out an internal ink tank and replace just that. So you know the chip has already been recognized by your printer. The ink tanks cost under $3. I think these are a brilliant invention.
Posted on Jul 07, 2009
  • 80 Answers
SOURCE: my epson stylus t13 have
Hello there,
This is called a false paper jam. normally, a reset is required for this.
Hold the power button for 30 seconds and this should prompt a shut down.
next, make sure that the rollers are clean inside. use a lint free sloth and some distilled water. Dampen the cloth (Q-tips works fine too, please do not use cotton) and rub the rollers.
Then as it dires up. turn the printer on and do a test page.
Please don't forget to leave a feedback and testimony if it works.
Posted on Mar 12, 2011
SOURCE: my printer Epson t13 has
do you have a ciss t13 printer?.. coz if you have , then the problem is in your hose installation is short, if its not then your michanichal gear is broke,.. you have to bring it to its service center
Posted on May 24, 2011
My Epson T13 keeps the red light blinking and doesn't even move? Please help us
your printer t13 need to resetter i have resetter but for sale 300php or $7 contact me in my facebook evltrix_19@yahoo.com.ph or on yahoo evltrix_19@yahoo.com.ph
Sep 09, 2011 | Office Equipment & Supplies
How to troubleshoot epson stylus T13 ink pad?
Epson t13 all problem solved EPSON T13 WITHOUT CHIP , INK LEVEL ALWAYS FULL,
NO NEED TO RESET INK LEVEL EACH TIME .
INK LEVEL AUTO RESET WHEN PRINTER SHUT OFF.
INK LEVEL LEVEL ALWAYS SHOW 100 %
NO WASTE INK PAD COUNTER MORE
NO NEED TO WORRY WHILE PRINTING MORE PRINT JOBS
watch video here
http://www.youtube.com/watch?v=CouogJKjXuY
Jun 06, 2011 | Epson Computers & Internet
EPSON STYLUS T13 printer's ink pads are at the end of their service life HOW TO RESET FREE
Apr 26, 2011 | Epson Printer
How to reset epson T13?
Epson t13 all problem solved EPSON T13 WITHOUT CHIP , INK LEVEL ALWAYS FULL, NO NEED TO RESET INK LEVEL EACH TIME . INK LEVEL AUTO RESET WHEN PRINTER SHUT OFF. INK LEVEL LEVEL ALWAYS SHOW 100 % NO WASTE INK PAD COUNTER MORE NO NEED TO WORRY WHILE PRINTING MORE PRINT JOBS now no more ink cartiledge not recognise problem
Mar 24, 2011 | Epson Printer
Reset epson T13
visit this link on how to reset epson t13 printer
http://pcmediks.blogspot.com/2010/09/epson-t13-and-me32-resetter.html
Nov 03, 2010 | Epson Office Equipment & Supplies
311 people viewed this question
jasbo
jasbo
