Question about Xerox Phaser 6125 Laser Printer
How do I Solve the probelm of LOW DENSITY ON YELLOW
  • 85 Answers
Yellow cartridge must be replaced
Posted on May 25, 2011
HOW I CAN CLEAR C2555 CODE ON MY C250 KONICA MINOLTA MACHINE
Code
C2555
Description
Abnormally low toner density detected Yellow TCR Sensor
• TC ratio in the developing machine, which is determined by Toner replenishing amount control mechanism, is 5 % or less for a given number of times consecutively.
Remedy
0 Open and then close the front door.
1 Perform image troubleshooting procedure if image density is low.
2 Clean the TCR Sensor window on the underside of the Imaging Unit if dirty.
3 M6, M7 operation check PWB-M CNDM2-10 to 13 (M6) PWB-M CNDM3-10 to 13 (M7) C-20 C-21.
4 Reinstall Imaging Unit.
5 Change Imaging Unit.
6 Change PWB-M.
7 Change PWB-MFP.
Nov 19, 2017 | Konica Minolta Office Equipment & Supplies
Magic color 7450 error code 36 density low k...how can this be solve
Abnormally low toner density detected Black TCR Sensor
• TC ratio in the developing machine, which is determined by Toner replenishing amount control mechanism, is 4 % or less for a given number of times consecutively.
1 Perform image troubleshooting procedure if image density is low. 2 Clean the TCR Sensor window on the underside of the Imaging Unit if dirty.
3 M7 operation check PWB-M CNDM3-10 to 13 C-23.
5 Change Imaging Unit /K.
6 Change PWB-M.
7 Change PWB-P.
Feb 06, 2016 | Office Equipment & Supplies
C2555 solution
C2555: Abnormally low toner density detected yellow TCR sensor
replace yellow imaging unit
Jan 15, 2013 | Konica Minolta Bizhub c203 Copier
Hi, I don't know if I should get single or double sided ram for this mother board, and is low density ram ok? Thanks, Wayne
This mainboard uses DDR400 memory
A High Density module is by far much slower than Low Density module at the same speed rating say PC3200/DDR400. High density modules are FAR CHEAPER, less than half the price when compare with low density modules and hence high density modules will NOT work on 90% of today's PC chipsets. LOW DENSITY modules have 100% compatibility with ALL systems and ALL chipsets. HIGH DENSITY modules only have 10% compatibility and are VERY SLOW.
So AVOID those 'High-Density - 128Mx4 config 1GB modules which is usually UNBRANDED and is NO NAME!
With this in mind it is far better to use low density Ram. Most RAM cards today are double sided, it all depends on the capacity of the RAM card.
Please rate this solloution as it it much appreciated.
Thanks.
Oct 31, 2010 | Gigabyte GA-8S661FXM-775 MATX MBD SIS661FX...
WHAT IS DENSITY SENSOR IN LASERJET 8500
The Density Sensor is located inside the right upper door and senses the colour calibration pattern for each colour formed on the transfer drum during a calibration cycle. Press GO. Print a configuration page and then troubleshoot as an Image-quality problem as instructed in the user manual. Check the transfer guide for cracks and replace if necessary. Check the event log for errors numbered 54.00.0<X> the X indicates, 5-sensor abnormality, 4-Cyan, 3-Magenta, 2-Yellow, 1-Black. The last 3 error codes should be seen on the Configuration page.
Dec 29, 2009 | HP LaserJet 8500 Color Printer
I need a JU-253-403P floppy drive or equivalent
[International Portal Floppy Drive , www.ruanqu.net] is "TEAC low-density jumper floppy drive, SONY low-density jumper floppy drive, YE-DATA low-density jumper floppy drive, EPSON low-density jumper floppy drive, MITSUMI low-density jumper floppy drive, Panasonic low-density jumper floppy drive, Mitsubishi low-density jumper floppy drive, CITIZEN low-density jumper floppy drive, NEC low-density Jumper floppy drive "global distributor. ]
Mar 05, 2009 | Panasonic (JU257A607P) (JU257A607P)...
Emachines T2240
low density works alot more often then high density, HD is just cheaper and thats mostly why it't not compatible with as many boards.
Good luck,
Lee
Jun 11, 2008 | E-Machines T2240 PC Desktop
I need to reinstall my driver.
Nov 14, 2007 | Panasonic (r) Ultra-Compact Digital...
Xerox Phaser 6125 Laser Printer Logo
201 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
