Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
5300 color printer ksn f463989
Will not print black,the day before was fine. i tried 2 new black ink cartrage it still would not work. i even tried an updated print driver did not work either. love the printer but. if you can come up with a fix email me at [email protected] thank you richard marcoux.
  • 2 more comments
  • richmarc Aug 16, 2008
    also clean heads and ran the calibration.
    please help?
  • flarman1 Aug 16, 2008
    The black ink is not printing. Need help
  • Anonymous Aug 18, 2008
    New 5300 only printed a few documents ( worked well) then seemed like it was out of ink, purchased new cartriges, printing very very faint.please help, toby carr
I have had the same problem twice in six months both times Kodak replaced the print heads so far not a happy Kodak owner,
Posted on Aug 18, 2008
SOURCE:
My printer will not print black even tried 2 brand new cartrages. i also tried the cleaning process on the printer and it did not help. all other colors print perfect.
the black tube or nozzles are clogged up. The printhead probably needs to be replaced.
possible reasons for this
generic ink
not using the printer for a long time
printing past the warning indicator of low ink and having air get sucked in the tubes.
Probably cheaper to buy a new unit.
Aug 27, 2010 | Brother MFC295CNAll-In-One InkJet Printer
We have had our Kodak Easyshare 5300 for about two years and I don't feel it has ever worked right. The photo print quality is poor, even though we've replaced the print head, put in countless new ink...
First thing to do is to try updating the firmware of the printer, just make sure that your printer is idle and has no error before proceeding, you can get the update at www.kodak.com/go/dowloads if you still have the same issue after that try deep cleaning the printhead 2x
Oct 31, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Empty Ink Cartrage message when cartrage still has a lot of ink.
I'm going to provide you a solution worth many dollars now you can use your left over half filled cartidges and in future also use the cartridges to the extreme.
1. Go to menu and select manual override for toner cartridges and then only replace toner when the print quality starts to suffer. This can save you thousands of dollars over the life of this fine printer.
2. download and read this
http://74.125.153.132/search?q=cache:9mwf_bY_x-AJ:www.refill4.com/refillinstructons/pdf_downloads/Full-RefillInstructions.pdf+brother+mfc+5840+override+cartridge+empty&cd=6&hl=en&ct=clnk&gl=in
Jul 26, 2009 | Brother MFC-5840CN All-In-One InkJet...
Black not printing on a Brother MFC-290C
in the printer display try head cleaning option, there must be something blocking the cartridge. hope this helps
Jul 17, 2009 | Brother Multi-Function Center MFC-240C...
Kodak EasyShare 5300- Won't print
I fumbled around a similar problem today. After printing photos you have to convert the printer to print to paper. If there is a green LED on the printer your are in PHOTO mode. Reach into the 4x6 printer and pull back the slide and the LED will go out. Now you can print on paper.
Mar 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Color ink cartridge says empty i just filled it
When you put in a "new" cartrage the printer sens an electrical charge to the cartrage to set it up properly. So I would treat this as a new cartrage, rather than a refilled one. Go to the printer menu and re install the ink cartrage in question, it should recognise it and start the function as a new one, good luck
Mar 24, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Kodak 5300 ksn#f212713 printer will not print center of page from computer& when coping not dark enough.I have new ink?
You need to get a new print head. Its free! Go on the Kodak website, under HELP, and follow the prompts. They will send one within 3 days.
Mar 24, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
When printing photos the images come out with faded colur and lines running throught them. I havre instar\alled new b/w and colour cartidges and still the same. Do I need to clean the 'heads' and if so...
you need to replace the printer head this is easy to do. first take out old ink cartrages. in the ink tray you will see a bulls eye. right above the bulls eye there is a small black tab. push tab to release printerhead.( call kodak at the customer service help line for new printer head they will ship 1 to 2 days) put new printhead in place and gently snap back into place replace with new ink cartrages.
Dec 24, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Lexmark x1190 no black ink comeing out
you may need to reinstall the cartridge once again and test
Sep 27, 2008 | Epson Stylus 880 InkJet Color Printer
Kodak 5300 aio printer won't print black
It is the print head. Cleaning the heads does not do any good, either does replacing the ink. What you'll need to do is contact Kodak's customer service line and they can replace it for you free of charge. On this site everyone seems to be saying it is consistently the black that stops, however, based on what Kodak said it is possible that either the black or the color can have this same issue.
When you call in they will ask you for your service number, which is located on the bottom left corner of the machine, when you lift the lid (as if you were going to replace the ink). They didn't ask me when I bought it, how much I used it, etc.
They will set up a case for you - it takes 2-3 business days for the print head to arrive. They will provide you with an invoice number as well. Be sure to document it all just incase the head never comes, or if there are additional issues after you receive it (and/or if it doesn't solve the problem)
Feb 27, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
46 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Ekse
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
