Question about Dishwashers
Hello, I have a f1 NTC-break problem with my Whirlpool ADG 3340 IX dishwasher. What can I do about that?
3 Suggested Answers
SOURCE: adg 3962 IX showing fault code f2 with flashing
The machine has a switch inside that activates when a set amount of water is loaded.
If this switch then breaks (switches off) during the wash the machine assumes that the water has leaked out.
Run it through a couple of washes, check for a leak and see how it goes.
Hopefully it will be fine.
F2 indicates a flooded base.
Press and hold the start button until the start light goes out. (This resets the appliance)
Select a new programme and try the machine again.
If it comes up with a fault F2, take the panel off below the door and check for water in the base.
Be careful when you take the panel off, the exposed edges are razor sharp.
Drain any water in the base, reset and try the machine again and watch for a leak through the inspection panel.
Posted on May 24, 2010
tbirdfan1
  • 3051 Answers
SOURCE: I have a Whirlpool Dishwasher model no. ADG 6340
Hello there and thank you for choosing fixya
This is a very common problem with these types of machines the water inlet valve has a solinoid for the hot and a solinoid for the cold that opens and closes the water on demand .
When they start to pulsate like this it is trying to close the valve but it cant this is normally due to the valve being clogged with debris or the valve is failing all together and simply needs to be replaced
So what i would do is first if you can look into the inlet valve with a flashlight and see ifit looks like it has stuff in it and if so clean it out and try it again if this doesnt work than you can assum that the valve will need to be replaced here is what the one of the valves should look like or close to it .
$50.60 Quantity:
In Stock
Posted on Jun 05, 2011
ADP 4305. Where can I obtain a service manual?
Thanks for the detailed description of the symptoms that we should make it easier fault detection.
I conclude that there is a mistake F1 (1 x flash,1s pause,1 x flash).
Before anything, erase the failures by pushing the START button for longer than 1.5 second.
F1 - NTC break
Temperature out of the normal value (-3°C till +85°C)Temperature inside higher than +85°CNTC defectiveDishwasher is frozen, less than -3°C If temperature is less than -3°C, fill the appliance with a cup of warm water to warm it up before you start it. The failures F1 (NTC break) and F9 (continuous water inlet) are checked and indicated immediately after start program. Because that, too small quantity water is taked.
First, I suggest to measure the resistance of the NTC, which must be about 58,1 kOhm at temperature 20°C. Also, check wiring between NTC and board.
Dado
Oct 09, 2015 | Whirlpool Dishwashers
Why Whirlpool ADG-6558/1 IX stops sometimes the wash cycle after 15/30 min?
reset the panel by hitting normal-- heat dry NOT at the same time until all lights flash then push cancel and it should start. element is going bad
Jun 02, 2014 | Whirlpool Dishwashers
WHIRLPOOL ADG 6340 ix - At start and during the cycle water drains in pulses and for long time and water intake is in pulses and for long time. The cycle finishes OK but it takes long time, 30 min cycle...
since the water drain is on a float be sure there is no blockage of the screen drain area in the bottem of the dishwasher under the lower rack.the make some cleaner rinses to clean out the screen.
Feb 21, 2014 | Bosch SHX5AL02UC Dishwasher
I have a Whirlpool Dishwasher model no. ADG 6340 IX.The inlet valve is pulsing and letting in water on every pulse. It just keeps filling, over fills and trips elcb
$50.60 Quantity:
In Stock
Jun 05, 2011 | Whirlpool 24 in. ADG6340iX Built-in...
Our whirlpool dishwasher ADP 7408 is displaying a F3 fault and wont work. What is the problem?
F3 error fault code
The heating cycle is not working. The error is indicated after several electronic checks are done over a 25 minute period. Therefore if the heater heats too slowly or the heater is open circuit or indeed the electronic control PCB is defective, each of these will indicate F3. The twist is, if the NTC is fluctuating in its reading it also can indicate F3 and not F1.
Nov 14, 2010 | Whirlpool 33 in. ADP6830 Free-Standing...
Adg 3962 IX showing fault code f2 with flashing
May 24, 2010 | Dishwashers
Whirlpool ADG 6556 flashing code
Refer user guide for the correct meaning!
Meanwhile Check all the dispensing compartments- salt - rinse-aid, free inlet water flow and the door close.
May 20, 2010 | Whirlpool 24 in. ADG6552 Built-in...
I have a whirlpool sixth sense dishwasher and
F3 error fault code
Aug 25, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwashers Logo
274 people viewed this question
Top Dishwashers Experts
