Question about Nokia E71 Smartphone
Hi there. If got a Nokia E71. Since yesterday my phone kept on saying that my internet connection is wrong and that I must change it. Where must I go to change it. And Who can I contact to find the Lock Code To Reset my phone to the original Factory Settings. At this point I think that it would be better to Reset my phone to the original Factory Settings, then to just keep frustrating myself. It feels like I could hit the Phone against the wall. Please HELP!!!!
    President:
  • 2,047 Answers
Usually if you got the phone brand new the default code is 12345 unless it has been changed. Internet connections differ depending on the one you want to use. You can simply check your phone settings locate connection settings and edit from there. But usually if you are trying to use your mobile network the settings should be sent to you by your network provider. Call your network provider to send you browsing settings.
Hope this solution has been helpful?
Posted on May 25, 2011
    Genius:
  • 1,622 Answers
Hi, sorry about your phone. you don't need to hit the Phone against the wall.
Here are ways you can reset your phone:
Due to the amount of data it handles, a slow down in your phone may arise or a conflict in applications may occur, or worse, a total malfunction in your Nokia E71 may happen. A hard reset should be done only as a last resort as it will wipe out most data and new applications you have installed. Before heading out to your Nokia Care Center, try the following steps first, otherwise, it might be time for your cell phone to be handled by the technical experts at Nokia.
SOFT RESET:
Back up data from your phone and memory card before doing any kind of reset. To perform this please refer to resources below.
Switch on the phone.
When it goes on standby mode, press "*#7870#". Make sure you press the "*" key - some people forget this. This triggers a software reset and restores the default factory settings without losing your data. Although this action doesn't remove your personal data it still is a good idea to do back up when performing any kind of reset.
Enter the default code "12345" when requested.
HARD RESET NO. 1 - Do this if soft reset procedure above doesn't work.
Back up data.
Press "*#7370#". Again, make sure the "*" is pressed before the "#" key. This also triggers a software reset that involves reformatting the phone. When Nokia E71 is reformatted not all data are lost due to a new feature called UDP - User Data Preservation. You won't know though what will be retained and what will be removed so perform a back up no matter what.
HARD RESET NO. 2 - If hard reset no. 1 doesn't work then do these steps.
Back up data if you still can.
Make sure your phone is switched off.
Press the keys "3", "*" and the green/talk button simultaneously. This action forces a hardware reset and also re formats the device.
Without releasing the 3 keys mentioned above, press the "on" button.
When you feel the phone vibrate, release only the "on" button but not the keys in step 3.
When you see the Nokia boot up screen (handshake screen) then you can let go of all the keys.
Consigning your internet problem, acquiring your setting for your internet,
you will need to contact your service provider for help...They will help you out with that..
Take care...
E71 not being detected in nokia pc suite
Go into settings and change the default connection mode to "ask" or "prompt" then when you connect you should be able to select other options.
Apr 11, 2012 | Nokia E71 Smartphone
How can I activate my GPRS on my phone?Globe
-Hi,
To set up your internet connection in your Nokia E71 click here
Hope this help, please rate and leave a comment if the infimation was helpful, thanks!
Aug 27, 2011 | Nokia E71 Smartphone
How to unlock my nokia E 71 code
To get the Unlock code at here Prounlocking.com and Unlock it from Network Lock,then you can use it any GSM Network Sim card.
Nokia E71 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Nokia E71 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia E71 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia E71 without any sim card.
2 - Don't bother as to what is displayed on your Nokia E71.
3 - Compose #pw+CODE+1#.
4 - The Nokia E71 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E71 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
Aug 01, 2011 | Nokia E71 Smartphone
How to connect internet for E71 Pro mobile phone please?
hi, call your operator for gprs setting the will send an gprs setting save it.... switch off and on your phone this will work....
thanking u
Dec 29, 2010 | Nokia E71 Smartphone
Hi by accidentally I drop my nokia E71 cell phone in water the next day I kept it dry in sun now when I'm trying to call anyone its saying no network coverage do anyone have idea to solve this problem
Have you tried getting a new SIM card? I would definitely try to replace the SIM card, it could have easily been the SIM getting damaged in the water. Give it a try, they will give you one from your cell phone carrier.
Oct 18, 2010 | Nokia E71 Smartphone
Hi my e71 has a blank screen. it switched off automatically and screen has not returned since. How can I fix this?
Use Nokia Software Updater and connect ur phone,,,,,,using internet,,,,,,update phones software.//
Hope all will be OK
VOTE me.,.................
email me: ibrahim01911100005@gmail.com
Jan 12, 2010 | Nokia E71 Smartphone
The keypad comes out wrong.?
GO TO TEXT OPTIONS AND TURN IT FROM T9 TO ALPHA. THEN BURN IT
Nov 17, 2009 | Nokia E71 Smartphone
Nokia E71 Smartphone Logo
153 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
