Question about HP LaserJet 2420 Printer
An hp 2420n has show an errror. the attentionled flashes and it display the comment: close top cover. i however do not see anything wrong with it. i also have problems determining which cover is mentioned. i do not have any manual at hand for any diagram. the top cover , is that the one at the front, the L-shaped one? as far as i see, it is closed properly. it can however hbe that the switches are not actuated proeprely. where and howmany switches are there present and how can i check on them? the printer services a school library and it provides a significant inconviniance. thanks
  • 85 Answers
Top cover (above) has a sensor that senses and is not closed or that the sensor is defect.open top cover(where you can find cartridge) and so can reinchidel will recover
Posted on May 25, 2011
My HP LaserJet 2420n Printer is starting but I am not getting the LCD display and LEDs are not getting on and printouts are not coming.
If the printer is printing normally, problem with Display check display connectors,replace it,,,,, if printer is not recognising by system replace formatter assm..
Sep 15, 2011 | HP LaserJet 2420 Printer
HP 2420n printer
When you put paper, does it recognize that paper is inserted?
Mar 19, 2008 | HP LaserJet 2420n Printer
Describe your how can i configure ip in hp Laserjet 2420n
You can configure your hp Laserjet 2420n through it's Embedded web server.you can have the brief overview about it in printer manual.here is the link for the manual
http://www.retrevo.com/support/HP-2420n-Printers-manual/id/2080bh743/t/2/
May 26, 2011 | Computers & Internet
Hp 2420n printer having no display
i have the answer
mail me printerman007 at gmail.com
Mar 13, 2010 | HP LaserJet 2420n Printer
24" CRT HP A7217A Monitor stopped working
hello sir your vertical or horizal IC damaged.......... thats why its showing multi colour ...... just do one thing sir.......... fit your new IC
if your problem not solved..... type in comment
Apr 29, 2009 | HP A7217A (White) 24" CRT Monitor
Printer stopped printing durring project "Assert Error b52b00b4"
From the HP website:
ISSUE: The printer displays an assert error code. Assert error codes indicate that the printer has an internal condition that may respond to a hard reset of the printer. Beyond that, service may be required. This document applies to the following products:
  • HP Photosmart p1000/1000, p1000xi printers
  • HP Photosmart p1100, p1100xi printers
  • HP Photosmart 1115 Printer
  • HP Photosmart 1215, 1215vm, 1218, and 1218xi printers
  • HP Photosmart 1315 Printer
SOLUTION: Hard reset of the printer A hard reset of the printer may clear the error. Here is how to perform the hard reset:
  1. Shut down the computer.
  2. Open the top cover of the printer and remove the print cartridges.
  3. Close the top cover of the printer.
  4. Press the power button on the printer to turn the printer off.
  5. Disconnect the communications, (USB or Parallel), cable from the back of the printer.
  6. Disconnect the power cord from the back of the printer for one minute.
  7. Reconnect the communications cable to the printer.
  8. Reconnect the power cable to the printer.
  9. Press the printer power button to turn the printer on.
  10. Open the top cover and reinsert the print cartridges.
  11. Close the top cover and print the calibration page.
  12. Restart the computer.
Mar 18, 2009 | HP PhotoSmart 1115 InkJet Printer
Is HP Laser Jet 2420n
Duplex on this printer is manual, that means that you will have to re-insert the paper by yourself.
This if you have the 2420n, the 2420dn instead is the duplex model.
Here specifications, look where it says duplex, 2420n had only manual duplex (the printer wait for you to re-insert page).
Feb 17, 2009 | HP LaserJet 2420n Printer
THE EXLAMATION MARK AT THE TOP OF THE PRINTER IS FLASHING AND THERE IS A LINE GOING AROUND THE SCREEN ON THE DISPLAY PANEL, THE PRINTER WILL NOT RESPOND TO ANYTHING, THANKS
there is a flag switch located to the left hand side of the top cover that causes this issue
if you look at the left hand lip of the top cover, you should note that it does not meet flush with the top of the control panel, there is a cutout for the lever for the flag switch that appears to not move as smoothly as designed, my guess is a mismounted switched or a misaligned axle for the switch
you can actually access the switch lever itself when the top cover is open, just reach in and wiggle it until it depresses properly, you may have to do this (or at least check it) every time you open the top cover
Oct 19, 2008 | HP Photosmart D5160 InkJet Printer
HP 2420n
Hey there. here is a link with the service manual.
If U can't find how, ask me.
http://www.qhaclaims.com/ftp/TEMP/LaserJet%202410%202420%20and%202430%20SM.pdf
HP LaserJet 2420 Printer Logo
109 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
