AEG Lavamat 528. MAin motor does not turn on wash or ring cycle. Inlet valve does open at start of wash cycle, and pump does pump out water on ring cycle. How does one go about testing the motor or program switch to isolate the problem?
  • 1294 Answers
SOURCE: aeg lavamat 538
Your door will not open if there is water still in the machine. Try "spin only". If this fails, get a bucket, remove your outlet tube from the wall drain, put into bucket. Wall plug off first. After all the water is drained try the door, do not force it.
Then check your outlet filter; the water does not go thru for there may be a block in your filter, or tube from the tub to drain area. Or finally in your pump. Dont forget to refix drain pipe in wall in exact position.
And rate me pl.
Posted on Dec 01, 2007
rizla
  • 1463 Answers
SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Posted on Mar 03, 2008
SOURCE: aeg 76669 oko lavamat machine not
can you switch back to off - then to orginal programme - only the start light may show - what i did then was press all of the 4 button for rinse, spin short wash and held them in place - fro upto 10 secs - machine seemed to reset itself and it worked
Posted on May 19, 2008
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Posted on Jun 24, 2008
  • 4 Answers
SOURCE: error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
Posted on Jul 08, 2008
Have a aeg oko lavamat 88730 update runs for short time then shows C1 what is wrong with it and how do I fix it and how much
C1 is fault in prewash cycle and means no water inlet.
Could be: vaIve does not open or interruption, flow rate to low.
So, I suggest to check an following parts: water inlet, clean sieve, inlet valve, pressure sensor, wiring.
Dado
Jun 12, 2016 | AEG Washing Machines
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
No water
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Jan 14, 2013 | AEG Lavamat 72640 Front Load Washer
AEG washing machine wont work
It ispossible that the machine does not start off the cycle because there are errorsdue to feedback from the inputs. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect.If thewater flows then the flow should be good, if not the inlet valve is bad orthere is dirt in the filter. Also check the flow at the inlet of the waterline. Once the water comes into the system the WATER LEVEL SENSOR - normally apressure switch- must activate at the preset/chosen level to give the signal tothe program controller to switch on the motor. What is most important for themotor to start functioning is that the door switch must be ON when the door isshut or this will be an error for starting the motor for rinse and wash.Check thislink to replace the inlet valve:http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html Finallyafter the wash the drain valve will be activated, the water is allowed to comein to rinse and then finally the dry spin with the drain valve/pump activatedso as to drain off all the water from the clothes during the spin.Make surethat a fault in any of the cycle will relate to the specified action, so checkthe command from the program module and then the executing device be it thevalve or motor or pump. Please check the link below:http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jul 04, 2012 | AEG Washing Machines
Dos not start
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Jun 28, 2012 | AEG Lavamat 72640 Front Load Washer
Aeg W1039 will not spin
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Thank you for using fixya.
Sep 23, 2011 | AEG Washing Machines
When I start the AEG 74950 washing machine, everything looks ok but the water it is not coming in
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jul 26, 2011 | AEG Washing Machines
I have a AEG 74620 lavamat washing machine and the error code C2 is appearing. The load wont finish. Any idea what the issue is?
Jul 13, 2011 | AEG Washing Machines
E10 PROPLEM AEG
Your Machine manual is HERE
E10 is an inlet fault.
Check the water valve is turned on. If you are only getting a dribble of water in, then clean the inline filter at the hose inlet.
If no sound of inlet water - replace inlet valve (available as a spare from online stores)
Sep 30, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
LAVAMAT MOTOR DOES NOT RUN
If there is water getting into the machine, then the motor, motor control unit, pressure switch, timer control and wiring harness must be tested. If the machine is a top load the motor coupler may replace the MCU of variable speed motors, that must also be tested then.
If cycle is not operating at all, with no water getting through the inlet check lid switch, door latch, inlet hose , inlet valve, membrane switch, Timer board and MCU if present.
Aug 02, 2009 | AEG Washing Machines
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
