Question about GE 35GT740 35" TV
The cable plug on back of the ge commerical skip tv is broken, can I go toi Radio Shack or Lowe's and buy one and repair myself? If so would I need a sholder? Thanks
You can just buy the cable jack and will have to insert in the designated slot. the cable jack will have to be soldered
Posted on May 25, 2011
How to change the region on the tv
your going to go to a place sale electronic/tv. your going have buy a converter, the converter changes from pal to usa configuration, take the old cable with you and the new cable you need to convert.
radio shack, big box stores, tv repair places, where the deal with tv and installation service, walmart mite have it, electronic wholesaler,
you r also going to buy power adapter for cycle change or plug in, you just plug it into power cord and than plug into wall. the converter will transfer the 50 cycle to 60 cycles that the united states uses.
you find online, walmart, radio shack, where they may sale tv or call tv repair shop ask for help.
Oct 09, 2015 | Computers & Internet
Can't drive due to not being able to turn off alarm, remote broken
Pull extra electric wire from the positive side of battery but
most of the time the inline fuse is viable take both cables off
put them togeatherdor15 seconds and replace buy a radio saver
and the radio shack plugs into lighter holds the radio channels you like and also radio code holds that schould disable alarm
Jan 07, 2013 | 1999 Toyota Camry
How can I set up with my lcd Sony tv
If your home theater receiver has a digital optical input, run a digital optical cable from digital optical OUTPUT on TV to digital optical INPUT on receiver. If receiver is older and only has analog inputs, you can get an 1/8 inch to RCA cable(red/white), and plug 1/8 inch side to an output on back of TV and plug RCA side to aux input(or CD or cassette input) on back of receiver. DO NOT PLUG INTO PHONO INPUT! Either one of those cables can be found at Walmart, radio shack, or best buy, etc. Digital Optical cable is definitely the best choice, but I just used the 1/8 to RCA setup to hook up a Sony led to my brother's early 90's Pioneer receiver(not the ideal setup, but will work). Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
How do I repair where the coax cable connects to my 13 in TV
go to RADIO SHACK and get a RF MODULATOR ,this will do the trick , good luck , AJ
May 22, 2009 | GE 32GT740 32" TV
Broken Antenna Port
If you have already identified where the connection was on the board you will have to access the board to be able to solder back to the points where the old connector was. Once you have identified the two solder points (One should go to ground and the other if you can with the tv on touch it and see if a picture tries to come in or get rid of the snow). Then buy a matching transformer from radio shack or Home Depot, Lowes. Normally this would go on the outside antenna. But you want to take it and clip and strip the ends that have the forks. Solder this to the board, one to ground and the other to the point that would have been center on the old broken piece. This will have a 72 ohm or a connection that your antenna will connect to.
Jan 11, 2009 | Toshiba TP50G60 50" Rear Projection...
Broken cable tv port on Mitsubishi CS-27209
Yes but repair shop charge alot
for this , and it's easy repair .
You can buy some solder , 40 watt soldering iron , Male coax plug from Radio Shack and
resolder two connections and save 100.00
RADIO SHACK HAS THEM
IT ,
Dec 16, 2008 | Mitsubishi CS-27209 27" TV
Colors on the tv are dark
the screen control on the flyback transformer needs to be turned up a little
Nov 10, 2008 | GE 24GP653 24" TV
Lost Remote
bon succes!!!:) on est avec toi!!!!
Nov 06, 2007 | Radio Shack (15-2147) Remote Control
GE 35GT740 35" TV Logo
37 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
