Question about Kenmore Elite 45986 Front Load Washer
Missing soap/bleach divider, dispenser
Would like to order new insert for my washer that separates the bleach
  • svrm4dsrt Aug 18, 2008
    awesome thank you so much!!!
    Genius:
  • 1,028 Answers
Go to sears .com ..look for parts link ..type in complete model # ..choice of image or parts list
Posted on Aug 16, 2008
6ya staff
SOURCE:
How can I get a laundry cap out of the drain where you put the laundry soap, bleach and softener?
Can you see the cap?
Is the soap tube a separate piece that you can remove?
What's the year, make and model?
A local repairman would be able to solve the problem, as a last resort.
Nov 30, 2014 | Kenmore Washing Machines
Clean soap dispenser
Hello macmamaj - I am happy to assist you. First, I will need the model number to better address the issue at hand. Thank you.
Jan 27, 2013 | Frigidaire Affinity ATF7000E Front Load...
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
Jan 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
Inserting detergent/fabric softner/bleach
First check in which tray the water is flooding then put in that tray and then start the main program
May 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The bleach dispenser did not dispense bleach during Tub Clean cycle. The drawers were clean (only have had washer 3 wks)
I just called LG and they said for this model WM2101HW the bleach will only dispense from the soap dispenser during the tub clean cycle
Apr 16, 2010 | LG WM2101HW 4.0 cu.ft. Washer
Sears / Kenmore top-loading washer does not dispense bleach
Remove the tray and check the proper operation of the solenoid for the door.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2009 | Kenmore 23822 Top Load Washer
Can I use non-chlorine bleach in our new Bravos washer?
Use only chlorine bleach, using any other kind of bleach that isn't recommended can cause damage to the washer and void any warranties.
Mar 24, 2009 | Maytag Bravos MTW6600T Top Load Washer
Bleach Dispenser not relaesing bleach during cycle
I have the same model # and same problem!!!
Worked fine for few months and then it started.
Sears technicians came twice but couldn't fix the problem. Now they have ordered a new dispenser door. Sears said they changed the design. Will see if the new door will work. Hope that helps.
Jan 12, 2009 | LG WM2455 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
75 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
