Question about Canon PIXMA MP780 All-In-One InkJet Printer
Canon PIXMA MP780 - will copy only in greyscale and color - not in black and white
This printer was working fine, then one day it stopped copying in black and prints out only copies in greyscale and slows down to a crawl. It does okay with color. When printing out something in the computer, it prints in black and colors and comes out at the higher speed. I like the printer and
don't want to throw it out, but I need to copy letters and items in black at the regular speed. Does anyone out there know what the problem is and how to fix it?
  • Richter8 Aug 16, 2008
    Cleaned the cartridge/nozzle two times using the printer utility installed as suggested. I copied black printing on white paper - it still came out slow in greyscale. I cannot get it to copy anything black at regular speed.
    It still prints out black and colors when you're printing from something in the computer. When printing something from computer it comes out at regular fast speed.
    I've printed out this sheet from the computer and it comes out fine.
    In order to fix the problem I had to call Canon Technical Support on the East Coast. The Canon technician told me what steps to take to correct my problem. The
    problem was solved by Canon.
  • 1,800 Answers
Look i think that someone has miss a lil bit with ur AIO printer
try to start from zero okay
i will give u this:
this will guide u very well to fixe ur printer and u will ot throw it out the window hehe
here is the link
follow me, rate me!!
Posted on Aug 16, 2008
  • Jalal Sordo
    Jalal Sordo Aug 16, 2008
    if th link not wroking try this one
  • 594 Answers
Here is the link to your printer. it has the troubleshooting guide and drivers and such. i don't know much about the gray scale and why it is doing what it is but i thought you might think it would come in handy.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=10444
please do not forget to rate and comment on your experience today.
  • Cameron Viseth
    Cameron Viseth Aug 16, 2008
    i am glad i could help you get to where you needed to be to get the help. if you could can you still rate me?
  • Canon Master
  • 6,487 Answers
Try first fo clean the cartridge/nozzle using the printer utility installled on your computer then after that try to print a plain text and see if its working fine already...
Good luck........
  • Mark Gil
    Mark Gil Aug 16, 2008
    Try to update the printer driver .........
SOURCE:
CANON mp 830 NOT PRINTING BLACK EVEN THOUGH BOTH BLACK INK CARTRIDGE IS HALF FULL. i have taken the print head out, cleaned the contacts and still the same. what else can I do?
Copy machine makers are notorius for forcing users to use a bit of the more expensive color mixed in with black. I can't print in black, it is called greyscale, therefore it has color in it. If you only print in greyscale, you'll notice your color cartridges going lower over time.
Mar 01, 2013 | Canon PIXMA MP830 All-In-One InkJet...
Can i put canon 8bk ink in the 5pgbk slot?
Unfortunately No.
Im guessing you have 2 black ink slots?.
When copying greyscale or printing greyscale it will use the big black however when printing colour it will always use the small black cartridge.
hope this helps
Apr 05, 2011 | Office Equipment & Supplies
Can not get printer to print in black and white
Hi, May be you printer had been set auto color. To set it manually, go to printer setup in your computer. Select you file you wish to print the click print. On pop up printer set up you should see Canon MP 210 series printer. Then Click properties, you can see now the printer options like media, quality, paper source, color, greysacle and priview. Click greyscale to get monochrome printing.click Ok and Ok again. You should get a black white ( BW) printing result. In addition, to duplicate the file to get hard copies from your printer press Black button before do copying to get non color hard copy.
Dec 07, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Attemping to copy a black and white image and either very small color or black lines appear over the image all over the copy I want printed.
In the advanced print options select the option to print in high quality greyscale. This method will solve the problem
Nov 30, 2010 | Dell 962 Photo All-In-One InkJet Printer
The ''odometer'' shows greyscale as colour
Any machine I'm familiar with has a default colour setting that you can set to either colour or black & White. Check in your printer properties. If the machine is set for colour, even if you are printing all black text for example, it will "make" the black from the colours, thus registering it as a colour document.
Jun 22, 2009 | Canon Office Equipment & Supplies
Unable to add a functioning (second) printer, for greyscale.
Clicked on Start/Control Panel/PrinterI. Clicked Add a printer. Obtained (Copy 1) of my HP Photosmart C7280 all-in-one printer. Right clicked on (Copy 1)/properties. Opened Ports tab. Saw comment "Print to the following Ports. Documents will print to the first free checked port." A listed USB Virtual printer port, showed three printers -- my first printer, my copy 1 (& my fax printer) -- was unchecked. I placed a checkmark in this Port box. Both the original printer, and my copy 1 printer are printing just fine. *I have not checked to verify that my fax is functional.
I did rename the original "color". I renamed Copy 1 as "grayscale", and --under printer preferences, checked, under "color options", to print in greyscale.
Mar 30, 2009 | HP Photosmart C3180 All-In-One InkJet...
5 PGBK vs. 8BK ink cartridges
No there is no way you can adjust it just to use the small black. When copying greyscale or printing greyscale it will use the big black, When printing colour it will always use the small black so there is no way around it!
sorry, hope this helps
Oct 14, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Cant print black or do black and white copies
He's not saying that the black cartridge won't print (which would warrant cleaning the heads, or messing with the cartridges) -- I have the same problem that MarkDan is having as well... no matter what you select as the output from any "Print" dialog window, the HP 21xx and 12xx series printers _always_ print in full color. You can choose Black and White, Greyscale, Color -- doesn't matter what you choose in the dialog boxes, it utterly ignores you, and will always print in color.
I have no idea why it does this, but it's eating a _ton_ of color ink for no good reason. I have searched all over the Web and on HP's site, but solution has been found.
Jul 30, 2008 | HP PSC 1210 All-In-One InkJet Printer
Printer
My Brother MFC-5460CN printer is doing the same thing. I installed a new black cartridge (I have it set to default greyscale) from a different company and it worked fine the first four or five days, but then it started printing light again.
Jul 22, 2008 | Brother MFC 6800 All-In-One Laser Printer
Default copying to black and white on a Konica Minolta Bizhub C353
I have a Konica Bizhub C353 - to set the deault copier setting to Black as opposed to Auto:
** first select black on the copy screen **
* Utility/Counter >> User Settings >> Copy Settings >> Default Copy Settings >> switch from "factory settings" to "current settings"
please note: you may need to do this twice (and be sure before you go into user settings that you select black on the copy screen)
I don't think the factory wants you to know how to do this - I couldn't find it in any user manuals and figured it out merely by trial and error!!
May 12, 2008 | Office Equipment & Supplies
Canon PIXMA MP780 All-In-One InkJet Printer Logo
100 people viewed this question
Clive
Clive
old marine
old marine
Ekse
