Question about Galaxy Radios DX- 88HL Base CB Radio
What are the buts & nubs go to make the cb work which ones trun or push ?
Assuming you're talking about the Galaxy DX88HL, and assuming the mad has been done to reach the 11 meter band, you press the band button in, that put's you to the E-H banks, select the E/A bank which is high bank E. with the frequency counter on, it should read 26.965 for channel 1. If it reads 26.975, then your +10KHz switch is on, turn it off. you'll then be properly set for 26.965 (ch.1) - 27.405 (ch.40). You also have 5 "hidden" frequencies, these are at ch. 3, 7, 11, 15 and 19. To get to the "hidden" frequencies, go to any of the channels listed and turn on your 10KHz switch. Those frequencies are not attainable on radios that do not have a +10KHz switch or a clarifier capable of sliding that far over. To do repairs and for a full list of schematics, diagrams and so forth, I suggest this site, it has the most coverage of the Galaxy DX88HL as well as other galaxies that I've been able to find. http://www.cbtricks.com/radios/galaxy/dx88hl/index.htm .
Posted on Dec 27, 2011
What is the dead key adjustment # on a midland 5001z cb ?
amps like the smaller wattage so they can push out more power but some amps like the 3 watt figure so they can push out more power. go to www.cbtricks.com and look up your radio. the schematic is there but I don't remember if there is a service manual for it.
Dec 27, 2012 | Midland 1001Z 40-Channels Base CB Radio
How to trun the power up on my galaxy dx 55v
AM CARRIER POWER HIGH: VR-13 pot. for RF power adjust
AM CARRIER POWER LOW: VR-16 rf power adjust
Oct 22, 2012 | Galaxy Radios DX-55V Base CB Radio
Transmit problem
you have a short circut some where..use the eraser on a pencil and push solder joints...
Aug 03, 2012 | Connex 3300 240-Channels Base CB Radio
How do i tell what i blew on my cobra 29ltd it wont trun on and i changed the diode
If no power and have replaced protect diode--check voltage 12 volts from source thru inline fuse, to inside radio up to the switch---if power (rear two lugs of switch) on one side but not the other with turned on--bad switch is possible.
Apr 06, 2012 | Cobra 29 LTD CB Radio
Power window on Ford Expedition will go down but not up
the internal platic nubs I call them get warm to very hot when the windows are used repeatly. I know this happens when the weather is cold and you are at a drive thru window or as such.Running the window up & down a time or two within a few minutes get the contact hat as the nub as I call it will start to shrivel up receiving a mushroom size bottom shrinking the nub into a smaller size. Ech switch has two nubs, One for uop and one for the down position. The nub for the up position is the one that gets the hotest.. I had on customer lately who di not have the money to purchase a new switch so I removed the switch and swapped the nubs from a rear door window and installed them to the front drivers door control switch. Also the Ford factory switch for yours are sold on Ebay everyday far less than the dealer will charge you. If you do decide do repair your own thid switch is very fragile to open. Two tiny pairs of eyeglass screwdrivers are needed to open the casing. Ince its opened you will need a terri cloth to catch all the small peices that fall out of it. Really a new switch is much easier to replace
Feb 14, 2010 | 1999 Ford Expedition
The start and select buttons have just recently stopped working
Beneath the button is a little "nub" that is typically made of rubber or plastic. This nub connects the the internal circuit board that tells the gaming system that it is being pushed. With use, these nubs wear out.
You can try and find replacement buttons for them on ebay or at a local gaming shop.
You MAY be better off replacing the controller. Sad, but all things wear out eventually.
Hope this helps! Rate my solution!
Jan 05, 2010 | Sony Dual Shock 3 Controller for...
The safety switch on the back, how does it sit so it can work?
If you look in the waste basket part, there's probably a plastic part on one of the sides with a little nub that sticks up. The nub should correspond to a slot in the shredder itself and push down a button. These buttons are notorious for breaking. Make sure the nub is lining up properly with the switch. You may need to replace the switch (you can put the number on the switch into goggle and find one for a dollar). I've seen people override the switch by jamming a q-tip or something in there but then you're overriding a safety feature and that's not a good idea.
Oct 31, 2009 | Aurora Electronics AS662C Shredder
Need to change mic jack . wires came unhooked which wire goes where ?
If it is a 5 pin then..
Looking from inside the radio at the mic jack, with the nub down. Starting from the left is pin 1, pin 2, pin 3, pin 4, and pin 5.
here is the colors that should be attached to each.
1 is white.
2 is sheild.
3 is black.
4 is red.
5 is blue.
Here is a 4 pin explanation:
Again looking from inside the radio, with the nub down. Starting from the left, Pin 1, Pin 2, Pin 3, Pin 4.
Pin 1 is red.
Pin 2 is white.
Pin 3 is blue.
Pin 4 is black.
Apr 20, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Bamboo fun tablet pen not working
to change to nib not nub, you get tweezers and firmly grip the tip and pull then slide a new one in
May 23, 2008 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Canon Poershot sd300 digital elph. It just wont turn on period.
Try this: with the battery installed and battery door open, take a pencil, fine tip screwdriver, or anything long and skinny and push the tip of it into the little nub circled in the picture here. There's a spring inside that little nub... keep the spring depressed and try to turn on the camera. If it works, then either a small piece of plastic broke off the battery door or the nub got broken/pushed in too far for the battery door to trigger it. Try using a dab of hot glue to keep the nub pushed into the down position.
Apr 04, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Galaxy Radios DX- 88HL Base CB Radio Logo
108 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
