Question about Fisher and Paykel GWL11 Top Load Washer
Washer takes 1:45 min for 1 load
When I wash a load of clothes (whites,jeans,or other) my washer takes about 1:45 to complete! How can I fix this problem?
Thanks,
MJ
  • easonsrus Aug 19, 2008
    Like mjw577, about a month ago our washer began taking 1:30 minutes for ANY load (we've had it for a little over five years). I've tried advancing the wash cycle by pressing the wash progress lights (noted in the manual), I've tried selecting the time saver cycle (though I'd never used it before), I've checked that the delay start button is not on. I unplugged it for a couple of minutes and then plugged it back in, hoping for a reset default to original settings, in case something had been inadvertently changed.Nothing seems to make a difference.
  • 639 Answers
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
BUY SPEED QUEEN NEXT TIME AND HAVE IT FOR 25 YEARS! WASHES IN 35 MINUTES! THAT'S WHAT I HAVE!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
Whirlpool Calypso Washer Mdl#30942 gets stuck during rinse cycle. Machine runs, then stops, but does not rinse completely. Last 35-38 min cycle is problematic. What is wrong and how to fix it?
It's hard to tell by your description of the problem, but it sounds like it could be the timer If it's not running while in spin mode, or as simple as a belt if it's running and not spinning fast enough.
Nov 28, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
Washer leaves white lint like spots all over dark clothes.
This happens to me as well but only when I overload my washer or when my washer needs to be ran thru its cleaning cycle.
Mar 10, 2014 | Whirlpool Cabrio Washing Machines
A co-worker sold me this washer: model MAV6250Aww, ser# 20480262zu; that had just sat in storage for a while. Washed clothes came out with a lot of lint- even after a repairman "cleaned" it out. Any...
These washer are notorious for linting, there is no real solution, reduce wash time to bare minimum, try sorting clothes into different categories, whites separate washed from dark clothes, use good quality detergent. The only way to fix this problem completely is a neutral drain kit, I do not believe Maytag sells one.
Oct 20, 2013 | Maytag Atlantis MAV7260B Top Load Washer
It doesn't self balance and spin out all the water from clothes. the clothes are very wet, especially jeans. And the washer rocks bad during the spin cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 20, 2010 | GE WSXH208A Front Load Washer
My Maytag Neptune FAV6800AW top load washer only runs for the first few minutes of the cycle, it will not spin..it just stops..we've tried two cycles, the quick wash...it starts at 33 mins and then stops...
I'm and owner and will try to help. Are you handy and do you want to try a DIY fix?
From the wash times is sounds like the washer is agitating the wash load (tumblers are rotating the wash basket load) is that correct?
If so see if the machine will complete a Spin Only cycle with no clothes in the wash basket. Set the Spin setting to Spin/Hang dry seting and start the cycle. It should take about 10 min complete. Does the Spin Only cycle complete with no clothes in the wash basket?
Some handy links if you are going to DIY.........Service Manual for reference.
Sep 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Washer - Discoloration on Clothes
hi, i think your stains are grease from a failing drum bearing, it is a common problem, the bearing needs to be changed, hope this helps, thanks for using fixya
Feb 15, 2009 | Washing Machines
My pant legs get very twisted in the washer
these machines are sensitive to loads. try only doing the jeans seperatly.
Oct 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Clean clothes that smell bad
Peace,
ngafm at your service!
You may have a small amount of water or lint lift in the machine somewhere that is not completely dumping out !
This is sometimes common on front loaders! Or the pump is weak!
I tell my customers to try running the washer without clothes once a week with hot water and a 1/4 cup of bleach!
. BUT the first load you do after this must be white in case there is a drop of bleach left in the system, that it does not spot bleach a white spot on your colored clothes!
If not this does not remedy the situation you will need hands on service!
please rate me here at our site before you sign off!
Thank You!
Sep 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore washer leaves dark streaks on light colored clothes
I suggest you first take a clean, white cloth wetted with a stronger solvent such as 'Oops,' carburator or brake cleaner (with these two, DON"T overspray, they will damage plastic and paint) and wipe the drum inside to make sure there is not some gunk adhering that is gradually depositing itself with each wash cycle.
If you have a shade-tree mechanic in the family, they may have gotten a gob of grease on clothing that transfered to the inside of your machine.
If you don't find enough on the cloth to have caused the problem, I think you have lost a seal on the drum-side of the transmission.
Jul 01, 2008 | Kenmore 43042 Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
47 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
