Question about Acer Aspire 5500 5570-2609 Laptop
There has been liquid spilt on my keyboard and now the buttons dont appear to be working.will i have to replace the whole laptop
  • Acer Master
  • 32,281 Answers
You may only need to replace the keyboard provided the laptop is not damaged.
Replacement keyboard are available from this WEB site.
Keyboard replacement, LCD screens for mobile phones, Ipodsand computer equipment.http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Posted on May 25, 2011
My GATEWAY pc laptop keyboad letter WEOPB BACKSPACE and #0 dont work.im now using on-screen keyboard.what shall i do.please advice.tnx
Seems like you have spilt liquid on the keyboard?
the liquid causes connections between the circuit board in keyboard which causes the keys to not work properly.
u can try take off the keys and get to keyboard, you might be able to clean it with isopropyl alchohol and a cotton bud to fix it.
if you cant get the keyboard out then there is nothing you can do!
Apr 07, 2011 | Computers & Internet
I spilt a little water on it yesterday! It continued to work fine. But now today, the battery light is off and on flashing even though I have it plugged in and it will not turn on.
1. Unplug the AC adapter.
2. Remove the battery.
3. Disassemble the laptop & clean all internal components.
4. Assemble it back & test it.
When this is done, you should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no liquid seeped into them. Dry them if needed.
When you are done, re-assemble back the laptop.
If the liquid fell on the keyboard & you found out that the keyboard is no longer working, then you will have to replace the keyboard.
If it still does not work, the motherboard might be damaged & needs to be replaced.
Oct 06, 2010 | Dell Latitude E5500 Laptop
I have a friends laptop, which he spilt a cup of tea over, he wants it repaired, when i got it it would not come on at all, but after a few hours of playing about with it, i got it to boot up into...
First thing is to not try powering the laptop on after the liquid fell on it. Next, you should remove the battery off the laptop immediately. When this is done, you should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check the hard drive's connector to the motherboard for any liquid damage & clean it.
Aug 26, 2010 | HP Pavilion dv9000z Notebook
I spilt alcohol on my laptop and now the keys dont work
replaced ur keypad from the nearest hp service centre.
Apr 25, 2010 | HP CPQ175KB Keyboard
Hi my acer travelmate 2700 has had a liquid spilt on it the keyboard is faulty i replaced this and the issue i have now is that after around 10min the laptop shuts down i belive due to over temp the fans...
Well I would check that there was nothing moved like a sensor, or dislodged a plug? or something, when you changed keyboard?
perhaps some of the liquid has found it's way into the MB..?
Jan 27, 2010 | Acer TravelMate 2700 Notebook
I need help fixing my sisters with my sisters laptop enter button
You're going to have to replace the keyboard... The Liquid has burned out the contact pad on the Enter button..
It could have as well ...reached the motherboard .. you should have it looked at, it will cause further damage.....
If Left On Motherboard... It Will Blow Capacitors And IC Chips, It eats away at the Solder...
Nov 28, 2009 | Samsung NC10-14GW Notebook
Cannot type certain letters
Verify that the key is not working in more than one application. It is possible that some keys may not be used in all programs. This generally always applies to the Function keys F1 through F12. If not all keys are working in all programs and you have Windows, attempt to boot the computer to a MS-DOS prompt or Safe Mode and test the keyboard in DOS.
If it appears that a substance has been spilt into the computer.
If any type of liquid has been spilt within the keyboard you can attempt to clean it . however, because of the dramatic decrease of cost with computer keyboards, it is recommended that you simply replace the keyboard to help prevent frustration and possibility of failure again in the future.
Thanks,
CF
Jun 25, 2009 | Sony VAIO VGC-LS20E Notebook
Replacing keyboard for advent 7108 laptop
I have had the same problem several times over and it is VERY likely that the liquid has reached other components (specifically the motherboard) and will corrode anything that the liquid has come to rest on. The keyboard itself is easy enough to remove and replace, but the only place I am finding parts for advents is in the UK. This means replacement of the keyboard COULD be costly and in the long run the computer may fail due to corrosion especially if it was pop or juice or any other acidic liquid. Here is the link I found for a possible solution.  http:/www.adventspares.co.uk  if they dont have it, these guys might... http://www.techno-mart.co.uk/advent.html
Good luck, and I hope you havent damaged your motherboard! Kirk
Jan 30, 2009 | Computers & Internet
Spilt Liquid on the key bord how Can i take out the Key bord?????
In the upper front of the keyboard you can twist or remove the cover after you remove the cover unscrew the four or three screw that hold the keyboard and then detached the keyboard and clean or dry it.
Apr 16, 2008 | Acer Aspire 3680 Laptop
Viewsonic Tablet PC keyboard issue.
Try reseating the cable that connects the keyboard first.
If that doesnt help there may be liquid around the connector and it needs to be cleaned off to keep the circuit from shorting out. You will need to find someone with the appropriate chemicals and may have to take the laptop further apart to clean it all up.
This is why when anyone gets a liquid spill i recommend getting it torn down right away and cleaned up, as it can damage things you cant even see. If the liquid has been in there too long it may not be repairable.
Dec 21, 2007 | HP Pavilion dv4000 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
61 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
