Question about Canon iR 2016i Black and White Copier
I wanted to print and scanned on canon ir2016i directly from my computer. how can i do that? how can i able the printer identify my IP?
    Sergeant:
  • 372 Answers
If u are on network then u can simply enter the ip address in system settings tab in additional functions.then load the driver ,it will autorun after detecting machine. the scanner is network scanner and will work only in network.
if u are single pc user then load the drive and connect the machine through usb printer port when the driver asks to connect. hola
Posted on May 25, 2011
Canon ir2016i printing issue
Check if 'secret' option or The ID Management feature is not set.
try different document.
try from another computer
try from another os
try with another cable.
try on another port eg. usb, network,
Apr 04, 2016 | Canon Office Equipment & Supplies
I have a canon pixma MX850. I have connected to my network. Printing works fine. When I go to scan, the printer ask to which computer. I don't understand the question, much less the solution. Ho
Many machines allow network printing but not network scanning. I think you will find that the MX850 driver and MP Navigator software simply does not support network scanning. I suggest you query Canon directly.
Feb 05, 2015 | Canon PIXMA MX850 Multifunction Printer
IR C5180 Will scan to a computer but will not print from a computer.
Have you checked that your printer driver is correct and that the IP Address for the driver and the machine are the same?
Aug 03, 2012 | Canon Office Equipment & Supplies
Hi How do I get my Canon iR2016i to automatically
You need to install a PDF printer driver on yourcomputer first. There are quite a few freeware PDF writer programs on theInternet you can download one such as CutePDF.
Scan your document then click on File - Print and select the PDF writer as theprinter device. Then name and save the PDF file. To download Cutepdf PDF printer driver (freeware) click onthis link :- http://www.cutepdf.com/
Jun 29, 2011 | Canon iR 2020i Laser Printer
SETUP OF NETWORK PRINTER IR2016I
Install network scan gear on all PCs and make necessary settings ( IP, discover,... ), it should work as PULL scanner.
May 29, 2010 | Canon iR 2016i Black and White Copier
How to identify this scanner on my computer ??
unless you have the i-send option you will need network scangear loaded onto your pc this is free to download from the canon web site www.canon.co.uk
Dec 14, 2009 | Canon imageRUNNER 2870 Copier
How to find the IP Address canon IR3570
you should be able to go through the print menu on the printer and look for something that says information or configuration and look for network settings and print this page.
ADDITIONAL FUNCTIONS>SYSTEM SETTINGS>NETWORK SETTINGS>TCP/IP SETTINGS
Nov 25, 2009 | Canon ImageRUNNER 3570 Copier/Printer
I want to print copies from my workstation how to i connect this to canon ir3300
For that it should have a network adaptor, if that is availabe just feed an ip-address in machines, and connect with your workstation and installed the driver of printer.
Jul 09, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Want to install network printer
If you're connected to the network, and the printer is installed and shared from a server - which is the ideal way of doing it, then you should just have to go to the "add printer" wizard, select "network Printer", then browse your network for it, and connect. If it's not, then go to canon's website and download the driver's and install locally on your laptop using tcp/ip port and proper Ip address.
Apr 06, 2009 | Canon iR 2016i Black and White Copier
Canon IR3300 would not scan when use the
give the same class ip address to your printe and computer and install ms office soft ware, and then microsoft tools click that we find the microsoft document scanning create shortcut to the desktop.
ping the printer for computer
run the network scan gear and click on the ip, enter the ip address in the blocks and then the discover.
then scan the document for the ir 3300 scanner.
Apr 15, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon iR 2016i Black and White Copier Logo
179 people viewed this question
old marine
old marine
