Question about Epson Office Equipment & Supplies
My epson cx5500 theres no print out even theres an ink on them printer status was ok the printer was printing but theres no printout help me out on this plssss
SOURCE: Black stopped printing out. Dell 922 all-in-one ink jet.
HI thanks for that and i will try it.
Posted on Jan 15, 2008
PickLock
SOURCE: epson cx5500
Actually there's available resetter already. i tried it and it works. Regarding Waste pads, just pull the waste ink hose out of your printer and just do something to hold the waste ink that will squirt out of it..
Posted on Mar 10, 2008
SOURCE: My HPDeskjet F300 Series has
Go to Contol Panel, and in Classic View select Administrative Tools, Services, Print Spooler. Now, stop and start Spooler.
Posted on Sep 30, 2008
SOURCE: Using colour ink without black ink in Epson CX5500
good
Posted on Nov 20, 2008
  • 2666 Answers
SOURCE: Epson CX5500 with CISS ink supply not printing
It sounds like the waste ink counter needs resetting. Unfortunately the SSC Service utility does not yet support the CX5500 specifically but as there is support for some of the 5000 series it may work. As with any other 3rd party software it is "at your own risk" I've used it many times in the past with no problems. Failing that you will need to take or send it to a service centre for them to reset it.
You can download SSC from here http://www.ssclg.com/epsone.shtml Don't forget to read the help file before you use the utility (you have to install it first).
Hope this helps.
Posted on Jun 19, 2009
I had purchased an epson stylus printer cx5500 .
Ensure the nozzle check has 4 colours if it doesn't you will need to try head cleaning. you may also need to align the print head. All this can be found in the same place as the option for nozzle check.
If that is ok try a different paper type, ensure you are using relativly fresh ink
Mar 18, 2010 | Epson Office Equipment & Supplies
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
Epson cx5500 prints only with black cartridge???
Yes it will still print with black provided that your computer still detects the colored cartridge tanks.If you are certain that there is still some ink left on the colored ones, take them one by one and shake them hard as if you are trying to distribute the ink evenly. After that, you need to do a test print to utilize the colored inks.
Sep 20, 2009 | Epson Stylus CX6600 All-In-One InkJet...
CX5500 Doesnt Print.
most likely your print head is clogged up.
could be from the following:
generic ink
not using the printer a long time
or
when the printer says the inks are low, a big print job is done and some air is now getting sucked into the printhead.
also possible the tubes going to the wastepad are clogged up.
you will need to take the unit to a service center for repair, approx. repair if no printhead is needed about $65.
Jun 27, 2009 | Epson Office Equipment & Supplies
Ive replaced all the cartridges on my epson 5500 but still nothing prints. Any help gratefully received
Jun 19, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Printing problem
Your black nozzle is partially clogged. If the cleaning cycle does not work then you will need to take/send to an authorized epson repair center as this is not an owner serviceable part. Hope this helps.
Mar 16, 2009 | Office Equipment & Supplies
Epson CX5500 does not see cartage replacements as being full ,so will not print !!
Ok
If your printer cartages are full filled and will not able to print. Please follow the following steps-
1- Uninstall the printer driver and disconnect printer from PC.
2- Download the latest Epson Stylus CX5500 Driver 6.5b Windows 2000/XP  from given web link
    http://down3.driversdown.com/Printer/CX5500_W2K_65bE.zip
3- Install the printer driver from downloaded file and connect printer as setup ask.
4- Now remove the cartages from printer and clean the connecting points & inkjet point by soft cloath.
5- While cleaning the cartage's injet points you will must see the ink on cloath. If ink does not see on cloath may be your cartages are dry. try to clean them by little force.
6- connect the cartages to printer. tyr to print.
It will help you.
Nov 22, 2008 | Office Equipment & Supplies
EPSON CX5500 SUCKS ink....
Epson printers will clean the head if the printer is not used for a long period say a week. The only option is to switch on the computer and printer and give a noozle test every 2 -3 days. This will stop the printer from doing a head cleaning which uses the following amount of Ink
Black 1/8
colour 1/16.
Thus if the head cleaning is done 4 times your black is half empty.
thus as the saying goes either you switch on the printer every day or loose the printer
I also had the same problem and now this is what I am doing, and now the cartridge is giving a good amount of prints that too image quality
regards
N.kumar
Sep 28, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
