Question about Canon LaserShot LBP5050N A4 Colour Laser , 9600x600 dpi, 8ppm colour/12ppm mono, LAN, USB Printer
Hi! I have a Canon LBP5050n and try to print documents. i get a meggase up saying out of colour registration has not been performed and to calibrate the printer. Any help would be appreciated!
SOURCE: Canon PIXMA iP5000Inkjet printer
Greenishness output is due to a lack of magenta (cyan and yellow combine to make green). The magenta print head nozzles are probably clogged with ink. Canon would have you buy a new print head ($75 ?). However, you can clean it yourself.
First get out some paper towels or heavy tissue paper (maybe napkins); something that doesn't give off a lot of lint is best. Also get a roll of cloth or rubber tape, duct tape works great. Get a bottle of something like 409 or one of those 'orange' cleaners that you use to clean your counter top. You'll know it is the right type of cleaner when the ink continues to come out of the print head during this procedure.
First you'll need to protect the circuit board area on the back of the print head by covering it with one or more pieces of tape. This is to prevent the cleaning fluid from getting behind the circuit board and shorting it out later when you place the print head back in the printer.
Place the print head straight up as it is in the printer on a folded, flat piece of paper towels while gently pressing down. The remaining ink should begin to appear around the edges of the print head as it is being absorbed. You'll have to continually move the print head to other clean spots on the tissue as it soaks in. The tissue helps by drawing out the ink (capillary action) and by keeping the individual colors from going into the other color nozzles. Make sure that the tissue you place the print head on is always flat and not curled or folded; this could damage the nozzles.
Spray the cleaner into the top of the print head where the cartridges normally reside. I will refer to this as the cartridge reservoir. Spray enough cleaner into the reservoir to cover the round spongy contacts that connect and align with the ink cartridges. This will soak into the print head just like the ink from the cartridges and begin pushing the old ink out the nozzles onto the tissue.
Continue squirting cleaner into the reservoir and moving the print head to clean spots on the tissue until only clear cleaner comes out onto the tissue. For the clogged nozzles this may take quite a while and lots of tissue, but the cost of these supplies is certainly less than the cost of a new print head! Don't run water through the print head!
Now carefully remove the tape and place the print head back in the printer and replace the ink cartridges. You don't have to wait for the cleaning fluid to dry and, in fact, you don't want to. As soon as the ink cartridges are in place the ink will begin flowing through the nozzles. Now run a alignment test and nozzle check to test out the system. Then resume printing those family pics, nudes, charts, etc.
Posted on Dec 11, 2007
ohms
  • 1879 Answers
SOURCE: Epson 2400 printer prints dark and with slight colour cast
try these :
1. nozzle check
2. image set to RGB color (Photoshop)
3. check driver settings
4. try another file
5. try another application
6. ¨supported / recommended¨ epson paper & inks
7. another computer (to pin down where issue is happening)
8. all else fails - the printer needs service (better check your warranty status)
Posted on Jan 03, 2008
  • 52 Answers
SOURCE: Canon PIXMA iP4200 - not printing in colours
hi i am a Canon certified tech for this machine.the orignal problem you had most likely was not your printhead but since you washed it most likely it is ruined. the problem most likely is the purge unit. the purge unit is the unit to the far right of the machine. this unit cleans and purges ink from the ink tanks to the printhead. to do this it uses 2 pads one for black and one for color. these pads can be flushed with water to soften up any ink. i would also replace the printhead which can be ordered by calling 1-800-OK-CANON or by going to their website. one other tip, refilled ink cartridges cause more clogging of printheads and purge unit then OEM ink. this is because the ink is thicker then the OEM ink. hope this helps to clairify.
Posted on Jan 05, 2008
  • 619 Answers
SOURCE: Canon Printer won't print black ink.
Hi , printer need head cleaning until the black ink visible and dark black appear. Replace also the retaining tank with absorbent pudding.
Posted on May 09, 2008
SOURCE: Canon LBP-5000 Printer and Calibration
You have problem with one ot he (reffiled ?) toner.
Posted on Jul 28, 2008
How to use printer Canon LBP 5050N if one of the colour cartridge is empty
printers need all cartridges to work properly
replace the empty cartridge with a full one and proceed with the printing
Dec 31, 2015 | Canon LaserShot LBP5050N A4 Colour Laser ,...
Out of register color correction
1st option is also right go for solution.
2nd is Patch sensor, laser dirt, hvt, or ITB unit..
Oct 02, 2012 | Canon LaserShot LBP5050N A4 Colour Laser ,...
The canon lbp5050 is the biggest piece of **** we have ever bought. The DELL 1720dn which itself was a piece of **** at gave us at least 2 years of trouble free printing. This piece of **** is only a...
First tell us about the actual problem not the SH***T, and we can probably help... I've been using DELL computers and Canon printers for years and when used COOL HEADED! there not so bad...
Aug 18, 2011 | Canon LaserShot LBP5050N A4 Colour Laser ,...
My printer wont print keeps saying load paper but tray is full. i have checked for broken bits and stray paper but all seems okay.
there is a small lever that lifts up when paper is inserted; this closes a switch; look for it in the paper try compartment.
Jul 11, 2011 | Canon LaserShot LBP5050N A4 Colour Laser ,...
My canon LBP 5050N printer refuses to print anymore. It says it has a paper jam but I cannot find any paper when I open the rear end of the printer. I have a new iMac and had to download a driver. ...
The canon lbp5050 is the biggest steaming pile of **** we have bought. The only dilemma when trying to fix it is wether to use a 10 pound or 16 pound sledgehammer when smashing the **** out of the usless thing. My advice is DO NO BUY THIS PRINTER
Jul 07, 2011 | Canon LaserShot LBP5050N A4 Colour Laser ,...
There is a red light flashing beside the triangle symbol on my cannon lbp5050n. What does this mean?
Hey!
If that happens look in the system tray for a yellow tiangle,click on it and it will tell you the problem!It might just be a empty toner!
Hope it helps!
Jun 28, 2011 | Canon LaserShot LBP5050N A4 Colour Laser ,...
How can modify canon lbp 5050 printer driver to remove chip
You can,t unless you have the source code of the printer software,that is not an open source code,like for say,Open Office Word editor or XAMMP.
Dec 17, 2010 | Canon LaserShot LBP5050N A4 Colour Laser ,...
The Ready Light is on. We select Pri8nt. Then
maybe there are problems on the sensors of the printer. i suggest that you have to call a technician to fix that problem.
Jul 04, 2010 | Canon LaserShot LBP5050N A4 Colour Laser ,...
Canon LaserShot LBP5050N A4 Colour Laser , 9600x600 dpi, 8ppm colour/12ppm mono, LAN, USB Printer Logo
149 people viewed this question
old marine
old marine
