PDAs
Problem for PDAs
Generic problem for all PDAs
Touch screen problem
By jtsilverfox on Aug 15, 2008
I too have the problem where it gets stuck in the alignment/target mode. Sometimes I finally get out of there, only to get stuck a couple of screens further. Sounds like I need a new screen. Where might I get a new screen and the procedure on replaciing it. I've had it apart and I don't see any way to easily disconnect it, but maybe there's a trick to undoing the connectors...
Help?
Same Problem
Jan 11, 2009
-   after hard boot screen locked on alignment -   cscotb
Jan 10, 2009
-   have the new screen but dont wont to force old one out ? how do i lossen it-   Guest
Solution #1
posted on Aug 16, 2008
Somewhat Helpful)
Nataly
Rank: Apprentice
Rating: 74%, 3 votes
Change the LCD (and not the touch screen) is what i've done and it's very easy.
If you had it apart you should have seen the connector of the screen.
Just look for a LCD on ebay, for example, and you'll see what the connector looks like.
Changing the touch screen is surely more complicate as you have to unglue the touch screen.
So as i've found a LCD for a quite cheap price i did buy it and change it, everyting is fine now.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 01, 2008
Somewhat Helpful)
mvd_trade
Rank: Apprentice
Rating: 75%, 1 votes
I too have the same damn problem. I reset it several times and it keeps looping in the alignment/target mode.
Changing the LCD doesn't make any sense to me, mine seems to be fine. The touchscreen seems to be okay too, when I tap the center of one target it changes from bottom right to upper left. It ocasionally shows the center target and when I tap on it, it starts over an over again... bottom right, upper left, bottom right, upper left, bottom right, upper left, CENTER!, bottom right, upper left, bottom right, and so on....
I'm getting angry : (
Was this helpful?
Yes
No
Popular Solutions for PDAs
Questions and Unsolved Problems for PDAs
Answer
I want a product similar to Palm m505 to store data only.
Answer
how do i fix my black berry if it has a red light and wont turn on.
Answer
unable to connect to internet even with installed profiles. only wap. unable to connect to already... (More)
Answer
wifi setting can't be turned on. wehn i tapped the wi-fi to be turned on in the wireless manager, it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PDAs:
Top PDA Experts
Rank: Guru Guru
Solutions: 557
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
