N computing L230 restart automatically - Computers & Internet
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem hope this helps
Posted on May 25, 2011
  • Brian Sullivan
    Brian Sullivan May 25, 2011
    another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory to check what is running when your computer is running scroll to the bottom toolbar right click select task manager applications and processes if you see something you dont need running select end now to check how much ram you have click start right click on my computer select properties you will see all of your computers details another way to check how much RAM you have click start all programs accessories system tools system imformation all of your computers imformation will be there try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart don’t do anything while the chkdsk utility is in progress any imput may damage your computer then defragment your hard drive another way of running chkdsk click start control panel administrive tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start place a tick two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start should schedule this task when restart
    do not do anything while the chkdsk utility is in progress any input may damage your computer
    also you might download and use this registry cleaner it is totally free to usehttp://download.cnet.com/ccleaner/ hope this helps
Problems in n computing L230 model not working in windows 7
Hi!
Please download and install the latest software for your operating system from here:
http://www.ncomputing.com/softwaredownload
Hope it helped.
Aug 27, 2011 | NComputing L230 Network Terminal
After installing SP1 on Windows 7 home basic stopped connecting terminal L230. The client sees the server but when trying to connect an error about can not connect. On the server side I see that the L230...
Hi
Not clear whether you installed SP1 on the client or the server.
Try resetting or powering off and on the L230 and let it reintroduce itself to the network.
Also restart the computer that had the SP1 installed on it.
If none of the above resolves the problem, enter Network settings on the client and ensure that Neywork Discovery and File Sharing are not turned off. If they are off, enter Network and Sharing Center and use the Drop Down arrows on the right to turn them and any other desired options on.
Hope this helps.
Aug 24, 2011 | NComputing L230 Network Terminal
Como hago para resetear a la configuracion de fabrica un ncomputing L230. no encuentro nungun boto de reset
The L230 does not have a factory reset. If you need to clear a forgotten password, simply call NComputing's Tech Support at 888365-1210.
Jul 19, 2011 | NComputing L230 Network Terminal
Model ncomputing L230 host un reachbull eror coming not conneceting. please immediately solve the problem and give us reply immediately mob:9963266130
The L230 does not have a full IP v4 stack in it so having it connect across Class A subnets can be a challenge. Try to get the Server and the hosts on the same subnet.
Jul 16, 2011 | NComputing L230 Network Terminal
My n computing terminal server windows 2003 is getting restarted , i have connected around 15 users please help me to solve this problem.
It is getting restarted on it's own? If so, it sounds like you have a driver conflict and you've setup your system to simply restart when there is a crash. Enable the crash dump to capture the Blue Screen information the next time the server restarts. Please provide the version of vSpace you're using.
May 06, 2011 | NComputing L230 Network Terminal
Can i used printer to ncomputing L230 in a
yaes use this printer only usb not lpt port
Feb 01, 2010 | NComputing L230 Network Terminal
L130 on Windows 2003 SBS
it is better to restart your computer, because some services has dependencies
Jul 09, 2009 | NComputing L230 Network Terminal
L230
if you connect power usb hub or use 1.1 usb web cammera
Dec 27, 2008 | NComputing L230 Network Terminal
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
