Question about IBM Wheelwriter 30 Typewriter
Please help i have urgent work to type but my IBM Wheelwriter3500 by LEXMARK is typing half characters
  • 300 Answers
Half characters? Top or bottom? Please remove the ribbon and reinstall it. Likely it got folded. Make sure as well that the correction tape is properly seated. Otherwise it can get in the way. Unless it is a multistrike, you should see the characters imprinted on it. Just like Columbo when he solved another ****. Good luck.
Posted on May 25, 2011
  • 1 more comment
  • faxmando May 25, 2011
    If it is printing only the tops of the letters the platen has worked loose. Press down firmly on both ends it should snap into place.
  • jpokoth2003 May 26, 2011
    i have check and rechecked those steps and it still prints half characters is there another possible problem. what if i blow the machine, or is it something to do with the whole print engine
  • faxmando May 27, 2011
    "i have check and rechecked those steps and it still prints half characters"
    Which half? Top? Bottom? Left Side? Don't keep me in suspense.
The character's one half disappears
Press down firmly on both ends of the platen, they do work loose, if it won't stay in place a latch may be broken. R. latch can be replaced L. will require a platen.
DickyO
Mar 26, 2014 | IBM Personal Wheelwriter 2
Will only type half a letter
See if letter is on the ribbon correctly full character or half, could be ribbon feed or the IBM have locks that hold the platen (RUBBER ROLLER) in place , I think they were blue squeezze parts on each side may they have come up and the platen is not seated properly.
Sep 16, 2013 | IBM Lexmark Wheelwriter 6 Series II
When I type half of the letters or numbers are printing
You didn't give a make or model but if it is an IBM wheelwriter press down firmly on both ends of the platen they do work loose.
DickyO
Jan 04, 2013 | Office Equipment & Supplies
IWhen i turned it on it only types half the letters/numbers etc
If it is only typing the top half of the letters the platen may not be fully seated in the side frames, push down firmly on both ends of the platen it should snap into place.
DickyO
May 11, 2010 | Lexmark Wheelwriter 15 Series II...
IBM Wheelwriter 1000 wont Return everytime
Probably no cracking required. Spray a little WD40 on the silver shaft that the carrier slides on, if that dosen't do it there is the carrier motor in the left rear that the bearings dry up in a little WD40 will work there as well.
DickyO
Jul 08, 2009 | Lexmark Wheelwriter 1000 Typewriter
Faint printing on checks
To my knowledge the 999 ribbon is the best avaivable. Try these things. put a little light (WD40 works well) oil on the back side of the print solenoid, then perss code and "Q" the display will show 1,2 or 3 set it at 3 and then try code "B" for bold print. These should help.
DickyO
Feb 02, 2009 | Lexmark Wheelwriter 3500 Typewriter
IBM Wheelwriter 3 typing incorrect characters
If you have another printwheel try that, if you still have the trouble try blowing out the area where it is in stalled. If that fails turn the machine off then back on, after it completes the POR mark the printwheel with some white out, repeat the POR see if the mark is in the same place, if it isin't you probably have a selection plate problem.
DickyO
Nov 11, 2008 | Lexmark Wheelwriter 3 Typewriter
IBM 1500 by Lexmark
It sounds to me like the impression is to heavy try holding the code key down and pressing the "Q" key until the "1" light is lit.
Aug 30, 2007 | Lexmark Wheelwriter 1500 Typewriter
IBM Wheelwriter 30 Typewriter Logo
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
