Question about Dishwashers
I have a bosch sps 6462 gb/06 which has stopped mid-cycle. The operation light is on so I know there is power going into the machine...what should I do?
  • 1073 Answers
SOURCE: DU1100 Stops mid cycle.
main control cpu unit failing
needs to be replaced
Posted on May 11, 2008
IFIXALL
  • 868 Answers
SOURCE: machine runs for 4 hrs and 2H shows
Problem machine ,replace the control electric
Posted on May 21, 2008
micromaster
  • 3614 Answers
SOURCE: bosch dishwasher sps546 will not fill. switches on ok
you have to remove the cover of your unit in able to access the valve/.pump
Posted on Jul 08, 2009
SOURCE: I have bosch dishwasher SPS
It needs a new impeller which comes with its housing for the main pump ... :)))
Weavey
Posted on Aug 10, 2009
Problem with my bosch wash mch
Check timer to insure the cycle is completing sometimes the vacuum sensing line gets plugged and cycle may not complete
Robert
Mar 04, 2015 | Bosch Washing Machines
Bosch next 500 series stops mid-cycle
I had a similar problem, after ruling out the following
kink in drainage hose
no blocking of filter
drainage pump ok
ok we eventually found out it was the heater, sounds strange I know as you would not necessarily relate the heater to mid cycle stop an drainage problem....but it sorted ours
ours hope this might help
help regards R
Apr 15, 2014 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch 2467/GB/06 no display no go
Check power on wall with some other gadget, check plug fuse....
Apr 27, 2013 | Bosch Classixx WFO 2466 Front Load Washer
Bosch nexxt essence won't spin
Either a blocked filter or worn carbon brushes
Oct 11, 2017 | Bosch Nexxt Premium WFMC6400UC Front Load...
It is a Bosch WFF2000. The programme stopped mid
circle at bottom right take it off there is a filter there remove it and look of obstructions.WATER WILL POURE OUT!
Jun 23, 2010 | Washing Machines
Bosch Maxx 1000 front loader starts but stops mid-cycle. End light flashes. Can't get any response from the machine until power is removed either through 'off' on rotary dial or the power outlet. I have...
Have one of these machines and when on the drying cycle the drum started pushing the machine around the kitchen and making a very bad sound so we stopped it before it blew up. On looking at the internal workings we can see a screw and part of the plastic housing that held it in place fell to the floor. It appears to be part of a frame that holds a metal brace in place that holds the drum in place and ensure that it joins the door to the machine. To me it looks as thought the machie is capable of washing but if we use it to dry it will damage itself and breakdown. Anyone else had this problem and any solutions.
Nov 13, 2009 | Bosch Washing Machines
Bosch WFMC2100UC Washer stops in mid-cycle
Hi, it seems its about time to replace the motor carbon brushes.
Thanks
Aug 31, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
Bosch shu5315 06
it sounds as though the circulating pump may not be operating. if so fault is often due to the pump capacitor being faulty and this is a cheap part.
Jun 05, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
2nd Bosch washing machine same problem
Since you faced the same problems with two new machine's, it sound like a manufacturer problem and you should ask for another new washer or to get your money back !!!! Good luck !!!
Aug 18, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Dishwashers Logo
159 people viewed this question
Top Dishwashers Experts
