How do i hook my PC to my TV using an S-Video 3 RCA cable?
  • 134 Answers
First you shuold know the brand of the video card like: ati,s3,nvidia,asus,trident,and more and get the more detailed information of it...another your tv has to be set in video to be able to receive it..
Posted on May 26, 2011
MY TV will not show color on the tv .I have a protron PDS2315 .I don't have the cables that came with the DVD player Does that make the deference?
Hi zapchenk,
First of all, thank you for posting your question here at Fixya.com.
The most common caused of "No color" fault when viewing movies through DVD player are :
1. Wrong TV/DVD format - If your TV is a NTSC system format and not knowingly your DVD player is set to PAL/Secam system format, then there's no color generated to your TV due to incorrect video frequency signal coming from the DVD player.
Solution : You have to sync/match the system format of the TV and DVD player. Check first the system format of the DVD player through the menu. Try to change it from PAL/Secam to NTSC.
2. Wrong hooked up - Since the problem is in video, you have to check the video hooked to your TV and DVD player. HDMI jack is the best option to avoid wrong hooked up because it come with Audio and Video in just one cable. If you are using one RCA cable to connect the video, make sure that it is hooked up to Video in of the TV and Video out of the DVD player, it is usually color yellow RCA jack. If you are using the component video hooked up, you must have 3 RCA cable for video alone. It is color coded as green(Y), blue(Pb/Cb), and red(Pr/Cr) RCA jack.
My advice is to check first the system format and then the video hooked up.
Hope I helped you.
Have a nice day!
Good luck and take care!
Kind Regards,
Jdvillanueva
Dec 10, 2011 | Televison & Video
How do I hook up a dvd player?
Hello Andy, Hi!, you can hook up your DVD in 3 ways. 1. using standard RCA cables, 2, using Svideo cables, and 3. using HDMI cables. Depending on your player. I suggest you buy the RCA cable. they are color coded so the yellow goes to the player Video out to the TV video in, red and white cables goes to the Left and Right channel of the player audio out to the TV audio in. thats it.
Dec 21, 2010 | RCA F27242GY 27" TV
How do I hook my tv up to my acer netbook? I dont have a tv port but do have a port for a second moniter and have the cord to hook it up but it will not work...
If the TV doesn't have a VGA input, you have two options. If the TV has component video inputs (3 RCA jacks color-coded red, green and blue, not just a single video jack coded yellow), you can use a simple adapter cable. Here is an example.
If your TV only has a single yellow video input jack (called composite video) you can't use the simple cable. But you can get a VGA to video converter. This device takes the VGA signals and converts them to the form the TV can use.
Hope this helps. Thanks for using Fixya!
Mar 30, 2010 | Acer Aspire One PC Notebook
Rca television (f38310)
using your cable box connect the audio and video outputs to the tv via the RCA inputs1, 2, 3, or component inputs on the tv and then select the coresponding video input to view your cable. If you do not have a cable box you can connect your cable to the antenna A or B input jack on the back of the set and set the tv input to antenna
Mar 23, 2009 | RCA F38310 38" TV
How to get video/audio input from Xbox 360 & digital cable input
Hook them all to the tv and with audio out from the tv run that to the bose 321.
Mar 14, 2009 | Bose 3·2·1 II System
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
Rca vcr
there a a bunch of different ways. 1) if you don't have a cable box hooked up to this tv,plug the main cable wire into the vcr input then the vcr outout to the tv.2) if you do have a cable box, plug the main cable into the cable box input, then the output to the vcr input, then the vcr output to the tv. put both the tv & vcr on channel 3 for this connection. [ you must have the vcr on channel 3 to record from the cable box!] 3) if you have aux line/video or source inputs on the back of your tv,you can hook up rca cables [ red, white,& yellow ] from the rca outputs on the vcr to the tv inputs.
hope this helps
wg
Feb 04, 2008 | RCA VR637HF VHS VCR
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Sharp vc-a422
This is easy in a nutshell. from the cablebox into the VCR RF connection (ant in) then from the VCR RF into the TV RF in. The from the DVD composite video out and audio out into the VCR composite video in and audio in. This make the VCR the hub of your setup the VCR should be set to channel 3 and you can switch between the VCR and the DVD by using the VCR remote. Now for the cords: 1) Cable to VCR RF = Coaxial 2) Composite Video and audio out = RCA patch cable 3)Composite Video and audio in = RCA patch cable That is it. If your TV can support multiple inputs then use it as the hub. Cable Box to VCR RF (Coax cable) VCR to TV RF(coaxial cable) or VCR to TV Composite video, or TV Component Video (RCA Cable) DVD Player to Composite video, or TV Component Vido (RCA Cable), or Svideo (Svideo cable)
Sep 12, 2007 | Sharp VC-A420U VHS VCR
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | iLO V27DMBX Television
Computers & Internet Logo
David Payne
David Payne
