Question about HP JBL Platinum Computer Speakers
Jbl speakers they were working fine/we had to restore computer and now speakers not working/we i look under control panel-sounds, i'm unable to set the volume because it's grayed out-something about no device detected or something like that/any suggestions?
  • Anonymous Sep 18, 2008
    i got a virus, got comp wiped, speakers not working, dont have a sound drive or somthing? need a website where i can download a driver for free?
  • Anonymous Sep 24, 2008
    i cant hear my computer speker
  • 185 Answers
I think while u restored ur system to previous date but in that date,the problem is ur audio driver is not working properly,it is better to re-install it again and enjoy listennig musics again from ur computer.
Posted on Aug 16, 2008
Should the power supply be hot to the touch
your psu should not be getting to hot to touch try blowing it out using a fine air blower from an air compressor making absolutely sure there is no moisture in the airlines you will need to open up your computer blowing dust from the inside out
or you might remove it to blow air through it
take a note of where the wires connect if you decide to remove it
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope this helps
Nov 12, 2011 | JBL CREATURE II Computer Speakers
I can not increase or decrease volume on my JBL encounter speaker system
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
hope this helps
Apr 11, 2011 | JBL Encounter 2.1 Computer Speakers
I have Jbl speakers plugged into the computer. When i turn them on, i get no sound at all. When i try to go find them, the computer says that i do not have any system speakers.
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps don
Mar 10, 2011 | JBL Audio Players & Recorders
My jbl platinum speakers doesnt work again.may i get the driver pleaseeee....
also
hope this helps
don
Mar 03, 2011 | HP Compaq JBL Pro (401508-001) Computer...
Compaq JBL Platinum Series Speakers not working on Windows Vista
change the audio and sound device setting in the control panel. try to change the speaker setup
Oct 05, 2009 | HP JBL Platinum Computer Speakers
Just wondering what the power supply output JBL Media 3 Speakers
I have a pair of Media 3 JBL computer speakers. I am using a generic 12V DC adapter rated at 1000mA with a positive tip polarity, and it works fine.
Aug 15, 2009 | JBL Audio Players & Recorders
Sounds like my speakers are in mono
Go into the control panel and choose a different speaker setup.
Jul 02, 2009 | JBL CREATURE II Computer Speakers
I couldnt adjust the volume with the JBL encounter speakers when i plug it in my laptop, but when i plug it in my iPod, i works perfectly... Can anyone help?
If you are using windows then go to
  • control panel
  • open-> sound and audio devices
  • a window will open showing your sound configuration
  • towards the bottom of that window, you would find speaker volume-click it
  • on the next window, click the button saying restore deafults
Now check the sound.
Hope, this helps.
Otherwise tell me.
Mar 29, 2009 | JBL Encounter 2.1 Computer Speakers
Sound is not working on my hp laptop
I had the same problem; my laptop's speakers suddenly stopped working but I could still use the headphones and sound was fine.
I played around a while and searched the net; and I got them to work:
Open Control Panel- Sound, Speech, Audio Devices-------->
1) Audio Tab
2) Under 'Sound Playback' hit Advanced
3) At the bottom where it has Speaker Setup change it to "Laptop Stereo Speakers" (mine was initially on "Desktop Stereo Speakers" for some odd reason)
Problem solved, Thank God (Alhamdulilah)!
Hope it works out for you :)
Dec 04, 2008 | HP Pavilion dv6000z Notebook
Compaq JBL Platinum Series speakers
Make sure that you got 12v 1.0 A adapter. Not .01 A. They have one at newegg.com atrix DVCPA1AA power adapter-12v 1.0 A. you should not need drivers for speakers. Make sure you got it pluged into right port if you got the adapter. Also make sure under control panel under sound that you got it setup for two speakers.
Jun 29, 2008 | HP JBL Platinum Computer Speakers
HP JBL Platinum Computer Speakers Logo
67 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
