Question about Fisher and Paykel CT560QX 23 in. Electric Cooktop
The stoves getting too hot. Even when the regulator switch positions low, the stove get red hot, and i have to swith it off to reduce heat.
2 Suggested Answers
SOURCE: I have a Fisher & Paykel CE901 36" electric
Sorry, I don't have a solution, but a similar problem. My CE901 is 6 years old. One of the regulators broke after one year. The repair (under warranty) caused an electric fire a couple of weeks later. After much complaining, I got a replacement cooktop from F&P. Now, 5 years later, one regulator stopped working, no longer turns on the element. (I guess that's better than no longer turning it off.) You are not alone. Seems like F&P is incapable of producing a simple regulator that works reliably.
Posted on Jan 02, 2011
The stove is on a 2004 boat - I assume the stove is original. The burners light, but it just took me ages to boil a cup of water in a sauce pan with the lid on. Do old stoves lose their efficiency?
Gas stoves don't usually loose heating efficiency. Check that the gas control is allowing it to go from low to high. Being LPG, there may be a pressure problem. LPG have a regulator on or close to the bottle. Being on a boat, I would get a competent / licensed Gas Tech to check it. Better to be safe. LPG appliances on a boat can be very dangerous if not serviced or repaired properly.
Sep 17, 2015 | Force 10 Two Burner Built In Propane...
Cook top indicator lights stay on long after it has cooled off. The largest cook circle sometimes doesn't reduce heat when the dial is changed
Cook top indicator light will stay on as long as the stove is hot I think. Also, the burners don't heat real steady? or evenly or true to their settings even, quite often. they also take a really long time to cool down as well as to adjust temperatures, so it may just be that it is taking an awfully long time for it to cool down in order to adjust.
Apr 04, 2015 | Cooktops
Fame to low on my whirlpool stove
You mean the flame is low. You need to clean the burner jet hole orifice and also check if their is a gas pressure regulator which you can adjust the pressure a lithe more higher.
May 10, 2012 | Whirlpool Stove / Oven / Range Cooktop -...
Nov 28, 2010 | Fisher and Paykel 36 in. CE901 Electric...
I cannot adjust the temperature on the elements of my stove top.
Hello Skyemahan,
I work on stoves with various problems all the time, and have never encountered a problem exactly like yours. You may get other answers, but here's my two cents worth: When I don't trust a stove, I replace it. Period. Hopefully, your's is old and you're ready for a new one. A new stove is much cheaper than a house fire.
Best Regards, --WoobieDog--
Jul 10, 2009 | Cooktops
Poorly functioning Shipmate stove
Hi
Normally pressing red buttons on stoves is for lighting the oven. You press the button, light the pilot light, leave it depressed for a minute and then that heats up the thermocouple, which opens a valve and allows gas to the main burner.
Shipmate Stoves are still in business, so you could contact them. The link also suggests places for Shipmate propane gas stove spares.
Shipmate stoves Google Search
Mar 27, 2017 | Brown Stove Works 23 in. TL03-3 Gas...
Stove top will not heat oil hot enough to fry foods. Burner continues to re-cycle on and off while switch is on high. Burner gets red hot for a few seconds then turns off for a few seconds, then back on.
You may have a cracked element, they expand when heated and cause a separation in the element. You really have to put a voltmeter on it to test it under load. If the voltage remains constant while the element is heating and cooling, then indeed you have a bad element.
If you don't have a voltmeter, or don't want to perform this test, buy a heating element and replace it, if you have the same problem, you'll have a spare element
May 14, 2009 | Jenn-Air JED8430 Electric Cooktop
3 wire cook top to a 4 wire outlet
Older 3 wire connectors where Wht=Neutral Ground Return, Red=One Phase Hot, Blk=Second Phase Hot, of 220VAC stove connections.
Newer Electrical code standard has a forth wire that is bare copper for a separate safety ground return.
I suggest you but a 4 wire pig tail cable for your stove top, available at Depot or Lowes, and connect 3 wires of this 4 wire cable just like the 3 wires are now connected. The 4th bare copper safety is attached to any metal part of the stove. Find a screw you can loosen to wrap it around and tighten.
Mar 02, 2009 | Jenn-Air JED8230 Electric Cooktop
Wiring Wrong
REDS ARE THE 2 HOT 11O VOLTS EACH AND BLACK IS THE COMMON FROM THE CIRCUIT BOX .THE RED ON THE STOVE SHOULD BE 1 HOT AND THE GRAY MAY BE THE COMMON BUT YOU ARE MISSING A HOT LOOK FOR YOUR WIRING DIAGRAM ON THE STOVE AND IT WILL SHOW YOU THE COLOR CODES FOR WIRING IF YOU CANT FIND IT SEND ME THE MODEL NUMBER AND I WILL SEE IF I CAN GET IT FOR YA.......BILL
Jan 11, 2009 | Cooktops
Only high setting works on burner
Sounds like the Switch or the element are bad, try trouble shooting them. It's a stove top??
Eddie Rentas
Tupper LAke NY
Jul 17, 2008 | GE 30 in. JP340 Electric Cooktop
Fisher and Paykel CT560QX 23 in. Electric Cooktop Logo
37 people viewed this question
Top Fisher and Paykel Cooktops Experts
Paul Carew
Are you a Fisher and Paykel Cooktop Expert? Answer questions, earn points and help others
