SOURCE: No vacuum suction during normal floor cleaning operation
That door is called a valve door, and it may have broken, part #38718013. Or the valve arm, rear broke, part number 38719048. The spring part # is 38358001. Usually it is the valve arm that breaks. You would have to take the top cover off, then you can see the parts.
SOURCE: Hoover z400 clogged
There should be a bottom plate covering the brush roll that you can remove, if you can't dig out the what is in there, try using your hose and suck it out from the bottom, maybe you will be able to get it out.
SOURCE: Does not **** up detergent with the attached slim line hose
It only picks up under low pressure condition eather by adjusting wand or changing tip.
SOURCE: Problems with Dyson DC14 Animal Bagless Vacuum
Two possible solutions come to mind. First off, there is a clog in your hose. If you have another vacuum, try using the hose on that one to **** it out.
If that doesn't work, you may need to have the clutch replaced. Check your warranty. The clog wont be covered, but the clutch will be,
SOURCE: We need a replacement pen for our LeapFrog
Below is a distributor for Leapfrog in Australia. They should be able to assist you.
Funtastic Toys
Telephone 1-800-660-655
Email: info at funtastic dot com (This is spelled out to avoid bots from accessing the email address.)
url: www.funtastic.com.au
If they cannot help the main number in the US is 1-800-701-5327. If you cannot access 800 numbers the main US corporate number is:
(510) 420-5000
Thanks for using Fixya.
Testimonial: "Thanks, very helpful"
