Question about Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
Hi the top draw of my fisher & Paykel 2 draw dishwasher is displaying an F2 with a spanner display, can you please help. Vicki
  • bvney1 May 25, 2011
    Hi i did that now it has a F9 display
    turning off the power didn't help. Thanks for all your help anyway.
    Vicki
  • Fisher and P... Master
  • 19,396 Answers
Hi Vicki.
F2 means that there is a problem with the rotor attached to spray arms on one side, and to impeller pump on the other. The electronic control detects rotation thanks to a hall sensor located at the base of the rotor. If rotation is not regular you get F2.
The problem is usually given by debris stuck in the rotor mechanism, and it is fixed taking apart and reassembling the rotor and arms. The sensor can also be faulty, but this happens quite uncommonly. Usually the problem gets fixed disassembling, cleaning and reassembling rotor and arms.
The video below shows how to disassemble upper part of the rotor. If cleaning that area does not fix the problem, sensor and part underneath must been accessed. At that point the repair will become more complicate and you may require a professional. Try cleaning the rotor, most of the time that is enough to fix the problem.
Regards.
Ginko
http://www.youtube.com/watch?v=UXzuJvKIIgU
Posted on May 25, 2011
  • Ginko
    Ginko May 25, 2011
    Hi.
    F9 is top drawer control board failure.
    Disconnect power and ensure that the drawer and parts have been reassembled properly. If that does not fix the problem, then the top drawer control module was faulty, and this has caused also the original F2 problem instead of a real issue with the rotor.
  • Ginko
    Ginko May 25, 2011
    Hi.
    I checked service manual and I
    found a more extensive explanation. F9 is not necessarily the
    controller, but there may also be a problem with the motor. Since you
    have had a code indicated rotation problem, then the motor may also
    cause the issue. F9 may also be a temporary fault, as explained in
    previous comment.
    If F9 goes away disconnecting power, then the
    fault was temporary. While power is OFF, check that there is no lose
    wiring harness. A disconnected wiring harness may result in F9. If F9
    comes back, then the appliance needs a major repair.
    F9 :Power Supply/Controller fault.
    Isolation relay disabled,
    disconnect then reconnect power enable relay.
    Action
    - If previous fault was F3, F8 or F9 then this F9 is a consequential fault.
    - If fault was displayed after power on, check solenoid coils and
    motor stator.
    - Check lid actuators.
    - Check electronic controller for signs of damage, overheating or blown components.
    - Test solenoid coils and motor winding resistances before eventually replacing a controller.
    - Check top
    controller chassis and power harness are properly connected and no wires are loose. If controller is not receiving power from
    bottom tub F9 will be displayed.
    - Replace controller only after testing all the parts listed above.
    Reply
    Hi.
    I checked service manual and I found a more extensive explanation. F9 is not necessarily the controller, but there may also be a problem with the motor. Since you have had a code indicated rotation problem, then the motor may also cause the issue. F9 may also be a temporary fault, as explained in previous comment.
    If F9 goes away disconnecting power, then the fault was temporary. While power is OFF, check that there is no lose wiring harness. A disconnected wiring harness may result in F9. If F9 comes back, then the appliance needs a major repair.
    Isolation relay disabled, disconnect then reconnect power enable relay.
    Action
    - If fault was displayed after power on, check solenoid coils and motor stator.
    - Check top controller chassis and power harness are properly connected and no wires are loose. If controller is not receiving power from bottom tub F9 will be displayed.
    Reply
On the 2nd draw will start washing but not even a minute flashes the F2 error and stop washing, what this means?
Hi Francesca, The link below is a short youtube video on how to simply fix f2 on your fisher and paykel dishwasher.......CHEERS..
https://www.youtube.com/watch?v=qP_X9iG0f-g
Mar 29, 2016 | Fisher and Paykel Dishwashers
How do I find out if my warranty is still good.
Firstly open the top draw and on the left hand side between the two draws there is a plate with the model number and you dishwashers serial number .
Once you have that info you can either go on the Fisher and Paykel web site or ring your local distribution or service agent
Cheers I hope this helps
Aug 16, 2014 | Fisher Paykel DD24DCW7 | Double Dishwasher...
Top drawer can not be open
If this is a double drawer dishwasher and bottom drawing is functional but top drawer won't open means the controller on top drawer is faulty or power circuit is locked. If turning the mains power off and back on makes no difference then controller could be the problem. One way to test is to take the controller from bottom drawer and replace that in the top drawer. This requires a lot of patience and experience with electronic stuff. If you are not brave enough to test then call the technician. The controller is about $200 to buy. Make sure the mains power socket is taken out before working on the dishwasher internals.
FISHER PAYKEL DISHWASHER DD603 Parts
Feb 10, 2014 | Fisher and Paykel Dishwashers
F2 and a spanner appears after it is turned on to operate
Hi
F2 error is displayed when control won't sense motor to be rotating, usually occurs due to frozen/bad motor or stuck motor rotor or the RPS sensor or a bad stator assembly. If the motor rotor spins freely and both impellers are securely attached then the issue is with the RPS sensor. If the motor won't rotate then it is the motor rotor that has to be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a 10 year old dishdraw (Model No DD601v2). It is displaying a fault message "F1" on the top draw display and will not start. What fault is this indicating?
Normally F1 should display in both drawers.
But this is a bit unsual. Please confirm if you are still able to operate the bottom drawer.
Nov 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My dishwasher is showing signs of a spanner
I am slightly unsure if your double drawer dishwasher is the prefinished model (self standing with LCD display) or the integrated model with no LCD display.
The spanner symbol on the top drawer is telling you that a fault code is actuated. But I am not sure where this symbol is on your unit if it is built -in (integrated model).
You will have to check which red light (from the left) is coming on.
I assume there are 5 lights on the inside of drawer.
With the bottom drawer - again you will have to check which light from the left comes on sometimes as you mentioned.
If you have a user manual you should be able to tell what Fault code it is - something like F1 or F2 etc. Is it continuously beeping when the red light is on? How do you turn the beeps off?
The scrubbing bush symbol on bottom drawer may not be a problem. It appears the drawer is programmed to a particular option. But I am not sure where this symbol is showing if you do not have an LCD display panel. You can reset the option - possibly auto lock or auto power or dish cleaned (depending on your model) if you follow the user manual.
happy to take you through a possible cause of the problem if you post answers to my questions above.
Jan 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
HI I HAVE A F2 CODE ON MY TOP DRAW OF MY DELONGHI DOUBLE DRAW
You will need.to remove the draws and dry the under tray as it has a flood.warning sensor to detect water, this is due to lime.building up.around the tub top.seal and will.need.cleaning off as it causes leaks to run down into the tray
May 12, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher and Paykel DD603 service manual
Check to see if the Child lock is on...Check your email
Aug 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Logo
201 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
