Question about Gigabyte GA-EP43-UD3L Motherboard
My pc starts up without pressing power button, cant switch it off with power button so iff i switch it off on the power supply and switch it back on it immediatly starts up not showing anything on screen and it is definetly not graph card
  • Gigabyte Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem hope this helps
Posted on May 25, 2011
I have acer power desktop with 015 GV-M3 cpu.when i press the power on it wont start.The power goes on and off only.Pls help
Chances are that iff the power turns on then off, the power supply is shot and needs to be replaced.
Jun 01, 2011 | Computers & Internet
How can i reboot my PC without keyboard?
Here are some of the steps to you can reboot your pc without using a keyboard:
1) Long press the power button
- Press the power button for about 3-5 seconds. If the power LED or power supply fan shuts off, that means you have successfully turn off your pc. Press it again to turn on.
2) Unplug the power cord from the power supply
- Force your pc to shutdown by unplugging the power cord from the power supply of your pc. Put it back again and press power button to turn on.
Note: Please make sure you have saved important activities before doing this as this will immediately turn off your pc.
Hope it helps.
Thanks!
Feb 22, 2011 | Computers & Internet
Acer 4810 tz is like dead. I cant turn it on anymore, neither with battery (charged) nor without.. Please help! Antonio
There is an easy fix solution that works most times when your PC/Laptop suddenly does not turn on. Dont ask why or how but follow it.
1. Disconnect all the power supply, that is remove the adapter cable and remove the battery.
2. Press and Hold the power button for 10 to 20 Seconds(very important 10 secs at least)
3. Put back the battery and connect the power adapter and try switching on your laptop.
Aug 01, 2010 | Acer Aspire 3610 Notebook
GOT NO IMAGE , JUST BLACK
check the connectors to ur moniitor...from PC box...
also do this....
power off the machine
switch off power supply/remove power cable from wall outlet.....remove the power cables...from PC power slot.......keep pressing the power on button in the PC for 3-4 mins....WITHOUT POWER....and/or
press the PC switch on button and release it after few seconds many times.....
Power in RAM is locked...and it's locked ur Windows DLL files....
Dec 14, 2009 | HP iQ775 19" TouchSmart Desktop PC
Screen locks on start and computer does not
ur OS may be corrupted...
u need to reload OS or
try to do this...
Dec 14, 2009 | ASUS Motherboard P5GC-VM Intel 945GC...
When start switch pressed, PC does not turn on.
It sounds like the power supply is going bad. I would try replacing the power supply first.
Dec 02, 2009 | Compaq Presario 5000 PC Desktop
Computer won't turn on
Try a different power outlet, or plug directly into the wall.
This does sound like a bad power supply. You can get replacement power supplies just about everywhere computers are sold. It'll set you back about $50 and is relatively easy to install.
-=/ Daft Tech /=-
Oct 23, 2009 | Computers & Internet
Power button not working
if you can open your pc and can open several files then hung up you have a prob. ithere on hardware or software start on safe mode if you can work with the files without interaption you have a prob. with the system uninstall the new hardware that you install then start the procedure again. or go to system restore restore your pc on early times.
Aug 01, 2008 | Computers & Internet
My Computer starts then turns off...
hi buddy!
be sure that the power suppy can can handle all the components thier plug. and check the power button if there is no short circuit ok. also try the other power suppy if you encounter the same problem just reply i am willing to help you ok.
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Jun 23, 2008 | Antec TruePower 550 (true550) 550-Watt...
Gateway power supply
switching unit in powersupply sounds shot, if you want to test primary switching, un plug power from back, take main motherboard power socket off the board, take a paper clip and put it in the GREEN wire in the socket, and any BLACK wire, now (without touching the socket or having it touch anything else) plug power into the PSU, if the fans all fire up and spin, then the switching is fine, i would look at a fault on the board
Dec 03, 2007 | Computers & Internet
Gigabyte GA-EP43-UD3L Motherboard Logo
83 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
