Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
Recording (?) light on front of case continuously flash's, as if it is writing to the HD. haven't found anyway to stop or correct that.
  • 1,719 Answers
The Hard Disk activity LED indicator blinks only when there is some Read/ Write activity. In your case if the LED is blinking frequently, it certainly means some activity. It could by due to the following reasons: -
1. Antivirus program automatically scanning the disk
OR
2. Probably due to some virus activity.
So, I suggest that you may check the Antivirus program settings for any automatic/ scheduled scans (as some antivirus programs automatically start scanning the external drive). Secondly, if there appears any virus activity (which is likely) you should update the Antivirus program and scan the system. If you dont have the Antivirus program installed on your PC, to disinfect the system you may install antivirus, update it and scan.
AVG 2011 Antivirus FREE Edition
From the above link AVG can be downloaded and installed for FREE. Its basic antivirus protection.
Install AVG and scan the system.
Hope it helps! Good Luck!
CreativeTECH
Posted on May 25, 2011
The recorder says d v d 3 and will not work
DVD-3 is a typ of format in DVD writing. [Double layer writinng]. Your set might haven't the facility to read these type DVDs.
Apr 16, 2012 | Televison & Video
Sony kf-ws60s1 front red light flashes 6 times after lamp replacement. Need thermal fuse part number
hello!
your issue has nothing to do with "thermal switch". while you have replaced the lamp, you could lose a piece of plastic hardware, in front of the lamp housing. It pushes auxiliary interlock switch, right under the front of the lamp compartment. If you take lamp out, use flashlight and shine inside. There is a little switch at the bottom. Try to make the lamp housing push it, without breaking anything. you could get "generic" lamp with housing, which is not correct. Anyway, that's the deal. Also: don't forget to install lamp door and turn the handle clockwise! there is another switch. I've seen people who forget to put that door back! Really!
good luck,
Alex.
Mar 06, 2012 | Televison & Video
My tascam dr 100 gives a 'writing failed' file error' message and stops recording
Try using a smaller memory card. This only happens to me when using a 4- or 8-gig card. 2-gig and below, No error.
Feb 24, 2012 | Tascam DR-1 MP3 Player
My sdhc card shows a 'locked' icon when i put it into my gopro 2 recorder
SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 01, 2012 | GoPro Go Pro GoPro HD Helmet Hero...
Severe crackling during recording
.i assume the crackle you'r getting it when you are using the built in mics? i;m still in the process of troubleshooting my 2g but this is what I've got so far....the line in dosn't suffer from the crackel, so it cracked here open , didn't see any obvious problems on the board so i disconnected the black wire from one of the built in mics and this is what i found: odd and strange..... the crackle went away but i haven't tested that in depth yet 2. when recording it looked like i was getting some thing on both tracks odd.. thought 1 channel would be dead. anyway i got tired and put it away and haven't gotten back to it yet but about time i did so hopefully this weekend . hopefully i'll have some more useful info.. now a note on my take so fare as to where the crackle is coming from , bear in mind i've only had about 3 hours with the 2g so far so still getting acquainted. i'm getting the feeling it might be associated with the ACG or the record level auto calibration or clipping etc.. because i noticed that it seems like its starting ,checking levels, and setting things the a spike and it resets and starts over again. how ever the pattern is to random from what I've seen so far to to be anything concrete
May 15, 2011 | Yamaha POCKETRAK 2G Pocket Stereo Recorder
At the power on the display is looked "welcome" and no operation is possible.I have controlled the HD and the DVD (I am a expert of electronics device). Is not possible shutdown the recorder...
Dear Cauci
I haven't a final solution for our problem. But I found a problem in the power supply. If you disconnect the CD-drive from the internal power supply and then connect to an external power supply, the recorder starts up normally.
Maybe it's help you. Please let me know, if you find a really solution.
Sincerely
Gianni Baiguera
Jan 02, 2011 | Sony RDR-HX825 DVD Recorder/HDD Recorder
The vieo stops shooting after 30 secs when in HD
Your cards writing speed may be too slow to continue shooting past 30 sec. You should be using, at a minimum, a class 6 card.
Feb 12, 2010 | Canon IXUS V2 Digital Camera
Deleting files on HD720p Aiptek camcorder
You are not doing anything wrong. For some reason, Aiptek doesn't give you this option on the camera. You have to insert you SD card into a reader and delete it that way. Ya, I know, doesn't make sense. Also, a feature I hate is it does place your videos into one continuous file. Only video clips, so each time you stop then start recording, it creates a new file. Anyway, I've had my Aiptek since 10/2008 and no problems so far. Great indoor videos. Not too crazy about the still pictures though.
Dec 08, 2009 | Aiptek A-HD 720P Flash Media Camcorder
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
480 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
