Question about Panasonic KX-TS500 Corded Phone
My colleague had set her phone and divert her calls to my desk, my phone keep ringing all the time, I do not know how to reset it back, could you please help. My phone model is KX-TS500
  • 201 Answers
SOURCE: Program manual
Your phone will work on a few different Panasonic phone systems. If you are looking for manuals on KX-T7720 and KX-T7720 all you will find is a user guide for the phone. You need to determine the model number of your phone system before starting to look for a programming manual.
Posted on Jul 17, 2007
night71
  • 328 Answers
SOURCE: ring tone
Here is the instructions The full manual can be found here.
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Business-Home-Systems/System-Phones/Digital-Hybrid-IP-PBX-Phones/model.KX-T7633
Posted on Oct 29, 2007
  • 108 Answers
SOURCE: Panasonic KX-T7730 Diverting Calls back
If you set call forward all calls then lift your handset press the FWD/DND button, dial 0 , you should get a tone, then hang up. If you set Follow Me then dial 8 and your extension number instead of the 0 . Good Luck. ....Mike
Posted on Aug 08, 2008
cnavarro
  • 2460 Answers
SOURCE: Night switching for KX-T7630
You have 4 different modes of calling available to be programmed: DAY NIGHT BREAK and LUNCH. Your installer has to set up the ICD groups, but you can create a LUNCH group which looks like the day mode but rings all phones. The codes are accessed by dialing on the intercom *780x where 0 is day 1 is night 2 is lunch and 3 is break.
You may use the NIGHT mode in the daytime, but if you have voice mail, it will play the night greeting instead of a day greeting.
Carl
Posted on Sep 09, 2008
cnavarro
  • 2460 Answers
SOURCE: Digital panasonic kx-t7633
The 7633 has a FWD/DND button. Is it blinking, lit solid or dark? It's designed to be pressed 3 times for FWD DND or OFF....It's programmed as follows, assuming that 500 is your voice mail access code:
From the intercom dial *7101. That sets DND. Dial 710x 500 # to set call forwarding where x-2 for all calls 3 for BUSY for for NO ANS 5 for BSY/NA. 7&8 are FOLOW ME commands and they have a different set of instructions ie Dial *7107 plus your extension to have calls come to the phone you're at and *7108 plus your extension to cancel it. I have never seen it used. *7100 cancels all forward and DND arrangements from your phone..
This is just hte command set for ALL CALLS. You can also set up forwarding for Outside Calls and Inside calls seperately and you can program buttons to do the forwarding.
Your Panasonic dealer has 2 manuals that you would find interesting, one is the TDA Operating Manual and the PTPM Manual. The operating manual has a complete set of programming instructions for the manager and users of TDA systems, the PTPM has a complete set of programming features that can be performed from a Panasonic 76XX display phone.
THe pdf's aren't huge and they can be sent to your email address if you provide one under the Ask Me button.
Carl
Posted on Oct 01, 2008
My phone rings 3 times and then goes to voicemail. Many times I cannot get there in time and I would like my phone to ring five times before going to voicemail,
Look at your call forwarding or divert settings, change the settings to cancel all diverts or to divert to voicemail only when the phone is off or not answered. Chances are that all calls are currently being diverted to VM
Jan 21, 2015 | Office Equipment & Supplies
Xperia arc s LT18i only rings 3 times before going to message bank
hi, im not sure on your exact model but you need to change the call diverts, so its something like this,
1 go into settings
2 call settings
3 call diverts
4, no in here it has options like divert when busy, etc etc, it should also divert when not answered, click on this and choose status and it will tell you what its set to, then it should give you the option of changing the settings, some let you change to 30sec before answer, give me a shout back if you get stuck and ill find out how the menu works on your phone and talk you through the process
Jun 05, 2012 | Cell Phones
I don't understand at all, how to set a program or what is a way we could divert any call to my deskPanasonic phone while I am away of office. Since I have desk phone positioned at my receptionist desk, i...
This is a service provided by your service provider. Since I don't know what service you use or what country you're in I would advise you to contact your provider who will be able to tell you how to set it up. It's generally fairly simple to do, just press a few buttons. In Ireland where I live it tells you how in the front pages of the phone directory. It might be worth having a look at yours to see if it does also.
Dec 16, 2010 | Cycling
My Nokia 2600 rings for about 10 seconds and I miss calls because I cannot hear the ringtone, even though I have turned it up to the max. I am not deaf.
Hi, some ringtones are quieter than others so try another ringtone, and if you want it to ring longer go into the settings then call settings then choose call diverts and then turn them all off, then turn the one on that says when out of reach and not available this will then keep the phone ringing when its on but when its off it will go to answer phone.
if you dont need to use or never use the answer phone just turn all the diverts off then the phone will keep ringing for ages when someone calls you
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 30, 2010 | Cell Phones
How do i extend the ring time before the phone N73 diverts to voicemail
Settings - Call - Call Divert - Divert if not answered - Activate - To voice mailbox number - set delay time
Apr 06, 2010 | Nokia N73 Cellular Phone
I have this problem, which unfortunately I don't know how to fix. All the calls that come to my mobile are immediately redirected to message center. The phone doesn't even ring.
You must have changed the call divert settings on your phone to your message center number and this is automatically diverting all your calls to your center number.
You need to go to your settings and cancel all call diverts to solve this problem.
You can also solve this problem by master reseting your phone.
Thank you for using Fixya,
Kenneth.
Mar 21, 2010 | Nokia Cell Phones
How do i set number of rings before call goes to voice mail, my phone just keeps rings nokia 1600
Menu>Settings>Call Settings>Call Divert>Divert when not answered>Set delay time
Dec 08, 2009 | Nokia 1600 Cellular Phone
PHONE WILL NOT RING
Hi it sounds like your problem is that the call diverts are set to divert all calls what you need to do is goto settings then goto call settings then look for call divert settings what you need to do is cancel all diverts and then go through them one by one and just
activate divert if off (activating this one goes to ans phn if phn off
activate divert if busy ( goes to ans phn if your on phone call)
activate divert if out of reach (goes to ans phn if no signal)
After doing these settings then your phone should ring when someone calls you.
Before you activate any divert setting select cancel all diverts then get someone to ring you and make sure phone rings the screen will now display whos callind and the phone should also ring.
Let me know if you need further assistance ok let me know how you get on
Feb 15, 2008 | Pantech C120 Cellular Phone
Adjust ringer length Nokia 7250
Hi the only way you can make the phone ring longer is to goto settings scroll down to call select call then select call divert then select cancel all diverts after you have dont this then select divert if busy turn this on then divert if out of reach turn this on the select divert if not available now leave them like that then when your phone is switched on it wont goto answer unless your on phone to someone else or you hang up on someone.
With the settings like that it will goto answer phone if phone is off or if you have no signal or if you are on phone to someone else but now your phone will ring for aslong as someone rings you for.
Jan 15, 2008 | Nokia 7250i
Ring time too short
try resetting your phone to its factory settings...
Dec 19, 2007 | Samsung SGH-U600
Panasonic KX-TS500 Corded Phone Logo
21 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
