Question about Garden
Please advise petrol & oil to be used for JCB PM42PA lawn mower, manual mislaid.
  • 302 Answers
SOURCE: change oil in riding lawn mower
look at the side of the engine down low. There should be a pipe plug screwed in that has a square head. Put a drain pan under the area and remove this plug and the oil will drain out. It's best if the engine is warm. You should get 1 1/2 quarts of oil out of it. Let it drain for about 5 minutes and then re-install the pipe plug. Add 1 1/2 quarts of 30W oil and then cut the grass !
Posted on Aug 27, 2009
Testimonial: "Thanks. It worked!"
rockitman187
  • 2559 Answers
SOURCE: JCB LS45 lawnmower - 2 stroke or unleaded petrol??
JCB LS45 specs Manufacturer: JCB
Blade Length in cm: 42 cm
Blade Width in cm: 40 - 44 cm
Cutting Width in cm: 42 cm
Electric Start: with Electric Start
Grass Collection Bin: Back
Horse Power: 3.5 hp
Mowing System: Rotary
Power Supply: Petrol 2 Stroke
Type: Walk behind mower
Posted on Apr 04, 2009
  • 86 Answers
SOURCE: Poulan PO175H42STB lawn mower operator's manual
Check searsparts.com web site type in your model you can most likely get what you want
Posted on May 12, 2009
MNfisherman
  • 11896 Answers
SOURCE: nannie what can be wrong with my power devil
Check air filter, check screen in bottom of fuel tank,
New spark plug and also check the spark.
If there is a weak spark, the coil may need to be replaced.
If you have good spark, clean air filter, and clean fuel tank screen, then the carberator will need to be pulled of and cleaned out with solvent
Posted on Jun 23, 2009
  • 3 Answers
SOURCE: Craftman Lawn mower continues to burn oil at a fast rate
Are you getting a lot of smoke? If so the oil is getting past the rings and burning.
Is the JCB M25 strimmer petrol only or 2 stroke please. can't find manual. Many thanks, Margaret
it is a petrol engine and the carby listed indicates that it is a 2 stroke
the oil /fuel mix ratio is 50:1 with a fuel octane rating of 91 ( do not use e-mix fuels ) recommended oil from the manufacturer specifications is a synthetic 2 stroke oil
Brand of manufactured oil optional
Jul 30, 2017 | Garden
Why does my 6.5 hp kohler lawn mower keep pulling oil into carb air filter
Its to stop the dust blocking the filter. The filter should be cleaned with petrol every 4 to 6 months to remove the dust & oil build up, cleaned in/with petrol and re-oiled. Its also good to clean the filter housing each time you clean the filter
Sep 26, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
My JCB 5.5hp mower starts then chugs and stalls after about 10 seconds. I do try to adjust the choke but to no avail. Can anybody advise please
The carburetor might be dirty. I would clean the carburetor and replace diaphragm if your carb has one. Sounds like the engine is not getting enough gas to stay running. Hope this helps!
Jun 12, 2012 | Garden
I have a JCB 5.5HP which has started leaking petrol badly through the carb. I have checked the float and needle which seem to be working ok. It really does flow out both when I get it started and when it...
The ONLY way IN for fuel is the Float Valve, Now if petrol is coming out of the float bowl, then, the Valve must be faulty OR the Float mechanism, or spring, itself.
Jun 07, 2010 | Garden
What do i have to put in my jcb self propell mower 5.5
hi unleaded 4 star a little bit of two stroke oil acts as upper cylinder lubricant so a spoonfull in a gall is good for the motor anyway hope this helps
Aug 18, 2009 | Garden
Webb Diplomat 350 Petrol Lawn Mower stops running 10 minutes
The 'DIPLOMAT' series of WEBBs is bad news, its NOT a WEBB! Webb were swallowed by qualcast-atco-suffolk, who dunped Webbs tooling, & dressed up punches & commodores in thin disguises, dumped the briggs & stratten engine for their own alloy job, & charged a rip off premium for the Webb decals!
The qualcast suffolk alloy engine suffers from a WIPAC electronic ignition unit. As it gets old, it fails, sometimes completely, sometimes as it warms up. Once cool, it works for a while again.
Not too hard to replace, but hard on the wallet, £69 genuine, £40 fake! On the whole its not too bad an engine if cared for & oil changed often. better to look on ebay for a cheap used HONDA engine & transplant! R-E-L-I-A-B-L-E !............I did! ( £35 honda gc series, 5,5hp! )
Jul 27, 2009 | Garden
Hi, I have recently bought at auction a Honda HR194 Mower
Hey Graham:
Here is an owner's manual for your lawnmower.
sysdoc.doors.ch/HONDA/31VA5030.PDF
Enjoy!
Steve
May 09, 2009 | Garden
Horse Power: 3.5 hp
Apr 04, 2009 | Garden
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
