Question about Kitchen Ranges
Stove element westinghouse 678 wall oven how do I replace element
4 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Replaced element, oven is still not heating
You may still have a bad Electronic Range Control (ERC). This is your timer that you mentioned. The oven is controlled by the ERC. There is a separate circuit for the BROIL and BAKE functions. Does the BROIL element still work? Or, are both elements not working? You may want to double check all your connections from the element to the control board as well. Sometimes the wire lugs can oxidize and not make good contact. Check the ERC to see if there any obvious signs of failure. Burned components are common. These boards are considered "non-serviceable" and usually requires replacing. You can attempt component-level troubleshooting if you are savvy with electronics. There's usually a basic block diagram that comes with your appliance mounted somewhere inside the operator console or on the back panel of the range.
The ERC for your range would cost in the neighborhood of about $100 - $140 to replace. Prices will vary between model versions and will also depend on where you get it. It is a very simple repair job if you wish to pursue this yourself. I can give you step-by-step instructions if you need further assistance. I hope this helps you.
PS The reason all your surface elements still work is because they are controlled by infinite switches behind the control knobs. There is a separate switch for EACH burner.
Posted on Feb 20, 2008
SOURCE: westinghouse self cleaning oven manual or owners manual
for the 8 button control ovens, white-westinghouse
turn both knobs to the lock setting (it looks like a padlock)
select the timer button (a clock with a line under it)
Increase the timer to 3 hours for heavy cleaning, 1 hour for light cleaning.
Then press start, (looks like a man running)
After cleaning let the oven cool down for 45 minutes
Hope this helps!
Posted on May 12, 2008
SOURCE: steps required to replace 2200watt
Symptoms= Oven light ok, thermostat light ok, oven not heating at all or to a low heat. May also have tripped the circuit breaker on the switchboard
Probably the element
Switch off power to the oven at switchboard
Open the oven door just a little and pull the door up to remove it.
Lift the panel at the oven back wall over the fan.
See the coiled element, you may already see a defect in the surface of the element.
Remove the screw at the base of the coil
With a small sharp screwdriver flip out the clip on each side of the element at the top
Feed the element out of the holes
Note that the green wire is attached to the frame of the element and the red wire to the core of the element.
The other side of the element may have two white wires
Disconnect all these wires, maybe using a pliers.
You can check this element with a simply multimeter, buy a new element and refit opposite to removal
Posted on Oct 03, 2010
We have a GE electric stove with a JDP 39 oven element which has burned out. How do we get the bottom heating element out to replace it?
UNPLUG the stove or turn off its breaker.
Inside the oven, trace the element back to the rear wall. There should be one screw on each side next to where the element goes through the rear wall. Unscrew that screw on each side and pull the element toward you - it'll come easily, bring its wiring behind it (this is why there must be NO power to the stove!). Detach the wiring from the element... DO NOT allow the wires to pull back through the wall, or you'll have to pull the whole range out to retrieve them.
To install the new element, just reverse that procedure.
Jul 31, 2014 | Ovens
Replace fuse in an old Westinghouse 229 fan-forced oven.
Not sure, but if you're lucky the stove will have a schematic inside. Take the back off, see if one is glued to the back or in an envelope. If back is 2 pieces try top behind controls first. Unplug 1st!
Mar 14, 2014 | Dryers
Trying to change element on westinghouse PAK806 stove with ceramic cooktop. cant figure how to lift hob.
Hi I have a Westinghouse PAK806. The oven works fine, heat and fan, but none of the plates will turn on.
Any ideas?
Jul 13, 2011 | Ovens
Can i change the element myself on a Westinghouse avondale? Dave
unplug oven and unscrew element from inside oven...pull out of rear of stove...if having problem bring out..the rear panel behind oven can come off to help you...remove wires going to element and re-install on new element and put together
Jan 21, 2011 | Ovens
I have a 1950's westinghouse electric stove and I am looking for parts. Specifically the heating element for the oven?
I have a 1950s westinghouse electric stove for sale with the original owners manual in mint condition... please email me if you are interested... mgsromaniello@yahoo.com
thanks and i look forward to hearing from you
Jul 27, 2010 | Kitchen Ranges
I have a Westinghouse 678 freestyle.the element remains on. It may be due to the setting of the clock or timer. i do not have a manual to regulate either as this was not left by the previous owner. could...
I also have the same oven, it turns itself on at random at heats up, also is the oven door easy to remove for cleaning, I dont have a manual either
Jun 29, 2010 | Ovens
Kenmore electric stove oven top element (broiler works but bottom element will not heat
the element is easy to change. just slide out the stove from the wall. take off the rear cover and just unplug or unscrew the leads from that element and replace. first make sure you unplug the stove it's self from the wall. it does have 220 volt and will hurt you.
Sep 05, 2009 | Kitchen Ranges
How do I replace the bottom element of a White Westinghouse 18-203101 oven?
Hi thanks for the question. disconnect power to the stove. 2 screws on the element . remove . pull element out . replace element. thanks the appliance doc. Please rate my answer. thanks.
Oct 07, 2008 | Kitchen Ranges
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
