Question about Canon Cameras
Quantum turbo and 580EX11
I disabled custom function 1 and 12 in the flash. the battery shows that it is powering the flash, but the flash does not seem to be powered by theQuantum turbo compact external battery. Do I have to change the mode ETTL in the camera to multi or Manual? If I turn off the external battery I am giving the same recycle time. I think the problem is with the flash. Please help. Big wedding shoot tomorrow, was hoping to use the new external battery to follow my flash
  • califoto Aug 18, 2008
    I am not sure I understand. I have disabled custom function 1 and 12. I have checked the cord that connects the battery to the flash and that works and the hot she flash. They all work. The battery works and the flash as well. I am just not getting the quick recycle time that I am suppose to get.
    Master:
  • 638 Answers
One of the sensor is broken in your camera.that is why this problem is comming.get it repaired.it would not be too costly.
keep me updated.
Posted on Aug 18, 2008
  • 1,800 Answers
Okay okay
u shud just follow me
1/chek the connections
1/set master mode or 2/The 580EX II sync port is INACTIVE when the flash is set to Manual-Master mode as it comes from the factory, unless a Re-Wire Mod is done to allow this port to be active. an u might need to use one of those in case click here 100% reliable. follow me rate me..^^
Posted on Aug 16, 2008
  • Jalal Sordo
    Jalal Sordo Aug 18, 2008
    mayeb there is a problem with ur falsh he cant make a quick recycle
    there is a condestator inside it its might be damaged ot corpted if u still under warrantly sir return back.
My canon 580 EX II stops firing even with new batteries
You must disable the 580EX II form using the 4AA.
4AA must be needed when using hv power pack.
Just let the 4AA use & display the LCD panel.
More help, repairs & troubleshooting send me an email.
atdlee@netzero,com
Oct 21, 2012 | Canon Speedlite 580EX II TTL Flash
I purchased a Quantum Turbo sc battery pack charger and I am using a Canon 5D along with the Quantum Turbo sc battery charger. Batteries fully charged. Connections are correct and fitted tightly. All...
If you have the camera on continuous then it may be that the charging is not keeping up with the shutter. Check the recycle time on the flash and compare with the burst speed on the camera. The burst speed on the 5D is fairly rapid.
Nov 03, 2017 | Canon SPEEDLITE 580EX TTL Flash
I have a Quantum Turbo Batter and there is a
Solid arrow -> normal operation. Dashed arrow -> faster cycle, less time to achieve readiness of the flash but, on the other hand, lower number of flashes.
Oct 10, 2009 | Quantum Cameras
D300, SB-800 fires but no exposure.
Thats is odd.
When you hook everything up, do you turn on the flash last?
It sounds like the battery pack is giving the flash a different voltage then it should have causing incorrect readings and exposures.
I would send the pack back to Quantum(located in Ronkonkoma, NY) and have them check it.
Jul 13, 2009 | Nikon Speedlight SB-800 TTL Flash
Quantum Turbo Battery pack not enough power.
Load 4AA with Energizer Lithium Batteries.
Set 580EX II's function to 12-0 and 05-0.
Make sure 5D's is not set to HSS.
No white dome parked on flash.
No bounce.
Set camera to "M" with max sync if you like, but 60 is fine.
Set F-Stop no greater than F5.6
Set ASA/ISO no lower than 200 but not over 1000.
If you need more assistance, contact Alzo Digital, CT, USA.
Asks for service & repair from ATG.
Apr 08, 2017 | Canon SPEEDLITE 580EX TTL Flash
Quantum Flash Repair
Check voltage at cable of Turbo, should be over 245V.
May 30, 2009 | Quantum Q Flash T5dR Digital Flash Head...
When I turn on the battery it would turn right
buy a new battery as you've cooked that 1.
Feb 09, 2018 | Quantum Cameras
Quntum Flash Repair
Check voltage from cable of Turbo.
Jan 25, 2009 | Quantum Q Flash T5dR Digital Flash Head...
Cameras Logo
269 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
