Question about Bosch Axxis WFL 2060 Front Load Washer
Having trouble removing the front panel of the Bosch Washing Machine Model Number WFL 2060...Able to get off the bottom screws and so bottom comes out but top is stuck...
    Problem Solver:
  • 14 Answers
Have you removed the screw on the right side of panel? If you did...pull to the right the panel!Good luck!
Posted on May 25, 2011
What are WFL 2060 fault codes
Bosch WFF washing machine error codes:
E1
- The door is not closed and cannot therefore lock.
E2 - Washer will not fill with water.
E3 - Washing machine not heating.
E4 - Washing machine won't empty.
E5 - Fault in the motor drive circuit.
E6 - Unexpected heating.
E7 - NTC thermistor open or short circuit.
Please note that the codes for the WFF range of Bosch machines differs from other ranges.
Sep 04, 2014 | Bosch Axxis WFL 2060 Front Load Washer
Bosch wfl 2060 washing machine makes a funny rattling sound when it should be spinning or draining. why
Check the filter behind the flap (Bottom right of kickplate) souns like you have a coin or other foreign object in the pump.
Feb 18, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Turn off beeping bosch wfl 2060
All you need to open the control panel and remove the connection to the buzzer unit.
If the washer works fine , the buzzer can be disconnected
Jul 03, 2012 | Bosch Axxis WFL 2060 Front Load Washer
Bosch washing machine
You should find the filter located behind a removable plastic panel at the bottom front of washer. Unscrew it anti clockwise to remove and clean it out.
Pl rate me 'very helpful' for the free help, thanks!
Jun 05, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Front dor seal has a tear in at at the bottom. It leaks as soon a
you will need to remove front panel 2 screws at bottom behind kickpanel removed with one screw next to filter cap one more screw behind soap draw ,then remove steel spring clamp holding door seal to outer cover push seal into drum so as not in your way pull down front panel it will then come towards you remove door lock connection and lift away fromt panel this will expose drum front there is another spring clamp on back edge of seal remove this and pull away seal reverse procedure to refit new one may need some detergent on back of seal to make refitting easier.
Feb 04, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Replacement front door for a Bosch Axxis WLF 2060
Visit repairclinic.com. Enter your model number in the search box and it should call up the parts you need.You'll be able to see actual photos of the parts on size grids so you can compare with what your's look like.
I did a quick search and it looks like you're looking for part number 1046685 .
Dec 14, 2009 | Bosch Axxis WFL 2060 Front Load Washer
My wfl2060 will not drain...drain is clear and pump impeller turns easily...this seems to be a common problem with this machine and no one has come up with a solution yet....does Bosch have a solution...
I had the exact same problem and just fixed it all by myself in spite of numerous repairmen who would tell me it is a pain and in the process ask me $200 (without part). Your drain pumpo is probably bad. I ordered the part from www.appliancepartspros.com/Bosch-Washing-Machine-Parts.aspx.
Check the exact part number (I called CS and they were very nice). I replaced the pump in less than 45 minutes with a screw driver and a pair of pliers (some thigh muscles and common sense too) and I am a woman. It is not complicated at all!
1- unplug your machine
2- tilt it and lie it down on its back after having drained any water that could be left using the small drain hose behind the bottom front door
3- remove the 2 screws that hold the bottom front panel
4- remove the screw that holds the pump (above the filter access)
5- from the bottom of the machine, unplug the electric wire
6- using your pliers (and a good grip) loosen the braces around the 2 hoses that connect to the pump
7- remove the faulty pump and replace it with the new one
8- screw the new unit
9- plug the wire to the back of the pump's motor
10- reconnect the hoses
11- plug your machine
and here we go! Mine is running again at the moment- and draining....
Jun 09, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Washing instructions
My book says for the Axxis WFL 2050/WFL 2060 : from the left while looking at it from the front: detergent for wash, stain remover, middle: fabric softener, fabric conditioner, right one: detergent for soaking agent. (Do not use chlorice bleach in this wasking machine).
Oct 11, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch washer carbon brush replacement
Remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws securing motor.
Lever back motor with screwdriver, remove motor..Carbons at opp end to motor pulley, remove and replace same.
Aug 27, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WFF1201
At the bottom of the machine on the front, there is a plastic cover (remove by turning the plastic screws a quarter turn anti-clockwise and pull off cover). The filter is behind this cover on the left hand side. It is unscrewed by hand anti-clockwise. Tucked into the plastic cover, you should also find the spanner to adjust the feet on the washing machine. good luck and rate me....
Feb 17, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
538 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
