Question about Polaroid DRM-2001G DVD Recorder/HDD Recorder
I have to reset my router every time i want a wireless connection
I have ATT Uverse with a Gateway 2wire router. Everything was fine until about two weeks ago when I started having accessing my wireless connection. When I try to access it tells me my connection is too weak. I finally figured out that if I reset my router I can log on. Now I have to always reset my router to get a wirelss connection. Any ideas?
Thanks
  • Anonymous Jan 10, 2009
    I have the same problem. It doesn't have to be reset EVERY time I want a wireless connection, but anytime my pc shows limited connectivity, resetting the router solves the problem. This can be a annoying to family members watching tv at the time!
    Problem Solver:
  • 6 Answers
Maybe try to put your router in the center of the house so you can get better connection....
Posted on Nov 27, 2009
  • salty2980 Nov 27, 2009
    Also make sure to update all of your drivers, go to your computers website and search your model number and you should find drivers under downloads.
How to get my 2wire ip number
There is a problem: you are connected on LAN side of the modem, so your IP is privat and are not visible in the Internet. It?s like 192.168.x.x .On the WAN side you have another IP that's could be public: 5.35.85.x .To see the public IP use a specific web site like: http://pingme.info/
Jan 01, 2015 | Gateway At&t 2701hgv-b 2wire Hi Speed...
How do I get my samsung bluray player to connect with my AT&T uverse 2wire router through PBC(WPS)?
login to your 2wire router using a computer that is connected , open a browser and type 192.168.1.254 on the address bar, once logged in look for wireless setting you'll find WPS setting /button click on that then push the WPS on your bluray player this needs to be done within a few seconds for the router and the bluray player to pair.
Jul 12, 2014 | 2wire Wireless-G 802.11g ADSL Gateway
Ethernet (wired) connection to computer works but "wireless" light does not come on and my laptop cannot locate a wireless access point or network device. It has worked in the past but after...
You will need to get a hold of att. They will need to have you unplug the 2wire and then reconnect. They will need to reset the gateway from their end. good Luck.
Sep 07, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
Can't get tv to connect to new wireless modem, but everything else did connect
What is the model no of your 2wire wireless modem not all 2wire wireless modem can support cable tv might as well contact you cable service provider
just feel free to add comment if you have furthur queries:
can also call: AT&T ' Uverse
Call +1 800.288.2020
if your under the uverse service of AT&T
or try going to this site for more 2wire infomation
http://support.2wire.com/
Aug 12, 2011 | 2wire (2701HG-B) Wireless Router
I have an AT&T Uverse provided 2Wire 3800HG-B gateway in the basement. My desktop PC is on the 2nd floor and connects to the internet at 11Mbps when the TV is not on. When we turn the HDTV on, we lose...
Turned on the TV, but not the Uverse box and still lost the internet. Determined that it was the Panasonic Home Theater wireless speakers which operate at 2.4 GHz causing the interference. Next step is contacting Panasonic to see if they have a solution for that issue.
Oct 02, 2009 | 2wire (1000-400108-001) Router
How do I connect to XBox live w/ ATT 2Wire?
to connect your xbox live wireless to 2wire gateway router you need to go to your xbox menu and click on settings then click A on joystick.Go to network settings then select ip address configure automatic ip. DNS should also be automatic. Under advance tab you'll see wireless you need to click connect.if you are prompt to wype encryption its the 10 digit number enclosed in a bracket on the buttom of 2wire router go to
Aug 19, 2009 | 2wire 2700HG-B Router (2700HGB)
Lost connectivity to network printer when switched to ATT u-Verse
Is the printer connected via wireless? When I recently connected up a new wireless printer to my UVerse network, the printer manual said that establishing the first connection works better via an Ethernet cable directly to the Uverse router. After the printer is set up once, then I could remove the ethernet cable and connect to the printer via wireless from all my computers.
For all wireless PCs that were previously connected via wireless to dsl, you need to create a new network connection for each one, then enter the key that is listed on the side of your Uverse router when prompted. Sometimes it takes a few minutes to establish the connection.
I am amazed that ATT was so unhelpful on these issues. I was one of their first Uverse customers in Texas, and several times over the last years, techs would visit my house to solve a problem or hook something up, explaining to me as he went. That their helpful attitude is deteriorating is a real shame.
Mar 11, 2009 | Computers & Internet
I want to use 2 wire ATT UVerse -- BUT NOT WIRELESS
the 2wire att uverse router, does not broadcast wireless signal if there is no wireless computer connected to its network. regarding the unchecking of the ssid, it will only hide the network name of your router, but technically, if a computer will try to connect to your router, it will still "send" wireless signal to a computer within its range.
you do not have to worry about the wireless signal being sent, if nobody connects to the router via wireless cionnection.
Jan 11, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
2Wire USB 802.11g adaptor on XP: drops wireless periodically
when you get your computer connected, set the wireless channel to 6 and disable wireless zero configuration that will stablize your connection
Dec 03, 2007 | 2wire (1000-100052-000) 802.11g/b Wireless...
Polaroid DRM-2001G DVD Recorder/HDD Recorder Logo
1,616 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
