Epson stylus photo 950 will not print at all, the printer takes the paper and the head moves like it is printing, but the paper has nothing on it
  • 92 Answers
Check first your ink level.. If it i ok,
Test it first for the Nozzle Check..
Go to Setup->Maintenance->Nozzle Check
it will test if the printer nozzle is clean,
check if the lines are complete, if not, clean your printer head
Go to Setup->Maintenance->Head Cleaning
it will automatically clean your printer head nozzles..
then, go for nozzle check..
if the lines are ok, you can now use your printer, but if not, go to head cleaning again, until the lines are ok..
Note: It's not advisable if you repeat the head cleaning for 7+ times.. it will damage your whole printer..
Posted on May 25, 2011
Epson stylus Photo 2200
When printing from your pc after selecting print a box will appear with several options including printer preferences. Select this and you will be able to select best photo and the type of paper being used.
Jul 24, 2010 | Epson Stylus 2200 InkJet Photo Printer
Tip
My epson cx5900 wont print anything. it takes paper in, the head moves by a few...
Two ways to reset your EPSON printer ink counter, ink cartridge, protection counter and more.
A. SSC Service Utility For EPSON Stylus Printers
This utility allows you to do many amazing things with your EPSON printers:
  • Work directly with CSIC in EPSON Stylus printers cartridges.
  • Reset or rewrite any chip using special add on device.
  • Freeze internal ink counters.
  • Reset internal ink counters even with empty cartridges.
  • Separate cleaning of color and black heads for all EPSON ink jet printers, powerful cleaning mode.
  • Hot swapping of cartridges supported.
  • Resetting of protection counter (even then it is already full).
  • More then 100 different EPSON printers supported.
This program helps people with high printing demands to save money (program works with both black and color cartridges). The software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Click here for the SSC Service Utility for EPSON Stylus Printers
B. Using the EPSON Ink Pad Reset Utility
"Parts Inside Your Printer Has Reached The End Of Its Service Life"
Generally, this error message is caused by the malfunction of non user-replaceable parts within your printer. If your product is displaying the "End Of Life Service" message, please view and complete the required information from the link below to proceed.
Click here for the EPSON Ink Pad Reset Utility
on Jun 08, 2009 | Epson Stylus C88 InkJet Photo Printer
Brown spots appear on the right of prints
I finally fixed it by printing in glossy mode on a thick and rough paper used for manual drawings. A bit of dust came off from under the print head and now it prints clean again.
Jan 16, 2010 | Epson Stylus Photo R200 InkJet Printer
Epson printer had paper jam which is now clear but the printing head just goes to the left and wont move. the printer and pare lights are lit up.
Some paper is probbally lodged btween head and printer wall, off with the power, can you then pull head to right and seek for paper fragments smashed aginst inside wall? then if all is well may need to run a clean, you should be right...
Nov 03, 2009 | Epson Stylus Photo 950 InkJet Printer
Epson r390 printer prints blank(no text on paper)
Check condition of head first. Move head to parking position (head cleaning position). From outlet pipe of head cleaning mechanics, do suction. It's there is ink, the head is not clog (and the flow of ink is ok). Make nozzle check. If nothing lines appear, the problem is in board (cause you just reset). Using resetter, do initial setting. Good luck.
May 31, 2009 | Epson Stylus Photo R390 InkJet Printer
Problem printing - Epson stylus photo 895
1 bring out the catridge of the printer to clean and make sure the ink flow during the cleaning.
2 insert and reset the catridge.
Oct 11, 2017 | Epson Stylus Photo 890 InkJet Printer
Paper jam
The print roller can be turned by hand but do not move the print head by head to the left or right -just make the roller turn either way. Try line feeds first. Steve Medley
Oct 27, 2008 | Epson Stylus Photo 950 InkJet Printer
Epson stylus photo 950 printer flashing lights
I had the same Problem and checked the solution:
This is a Printer Maintenance request.
Ink Overflow -
you sould change the waste ink pads under the printer mechanic.
Solution:
Sep 28, 2008 | Epson Stylus Photo 950 InkJet Printer
Epson stylus photo 810 won't print
Is it just not printing on the paper and feeding it thru, or will it just not do anything? I need more info?
Dec 05, 2007 | Epson Stylus Photo 810 InkJet Printer
Removing and cleaning Epson Printheads
I don't know how to remove the print head but if you want to clean it - check for mr.musculo solution from any market near you. Leave the print head in this solution (warmed at about 35 celsius) for several up to 24 hours.
Dec 03, 2007 | Epson Stylus Photo 950 InkJet Printer
77 people viewed this question
jasbo
jasbo
